Old 03-21-2007, 07:41 PM   #73
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Relay question.
I installed my foglights a while ago but, today I noticed that all the wires feel out of the back of the relay. 4 wires going in to the back of the relay. I've no idea how to put them back together. Anyone? Thx.
rwseattle is offline   Reply With Quote
Old 03-21-2007, 08:06 PM   #74
Kitt
Kitt's Avatar
Low in should be the line that comes from your switch, low out should be ground, 30a in, from your battery and 30a out should go to your fogs... This is a standard type of relay, they usually have a diagram printed on its side, if you could post a picture of it i may help you better
Old 03-21-2007, 10:33 PM   #75
rwseattle
Rwseattle
rwseattle's Avatar
Pix
My PC is not downloading the relay pix. I'm not sure why. I will downloaden tomorrow at work. The relay does not show any wiring diagram. It only says YLE YL-388-S Automotive relay 12V/40A. I got 4 connectors and they're all the same size. I will post pix tomorrow. Thanks for your help.
Old 03-21-2007, 10:39 PM   #76
Kitt
Kitt's Avatar
It should have something like this...
post the picture anyways and i'll see what i can do
Old 03-22-2007, 04:48 PM   #77
rwseattle
Rwseattle
rwseattle's Avatar
Here's the pic
Hopefully this helps.
Old 03-22-2007, 05:01 PM   #78
Kitt
Kitt's Avatar
ummmm not that much tough... you will need a continuity tester then to find it out. The 2 connectors that have continuity are ones that will go to the switch and to the ground, the other two ones will come from the fuse to the fog lights...
and try to post a bigger picture to see if it helps, focused on the pins of the relay
Old 03-28-2007, 09:46 AM   #79
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Foglights installed and functional...the best mod for me yet!!!
Old 03-28-2007, 12:33 PM   #80
rwseattle
Rwseattle
rwseattle's Avatar
Thank you.
I found the correct connection. I did use the continuity tester. I will post pictures of working fog lights soon. I'm installing a front strut bar and will post pictures all together. Thank you for your help.
Old 04-03-2007, 01:54 PM   #81
rwseattle
Rwseattle
rwseattle's Avatar
Wink Lights
Here a pic of wrk foglights.
Old 04-09-2007, 12:19 PM   #82
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
very good, you finally made it
jimcat is offline   Reply With Quote
Old 06-16-2007, 05:06 AM   #83
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
Originally Posted by tiksman View Post
Yes you know the one with the light electric green Yarii
http://www.yarisworld.com/forums/member.php?u=1178
how much was it?
seanele is offline   Reply With Quote
Old 06-16-2007, 10:24 AM   #84
tiksman
tiksman's Avatar
Drives: 07 Red Hatch
Originally Posted by seanele View Post
how much was it?
It been a while since I purchaced. I think arround $80
tiksman is offline   Reply With Quote
Old 06-26-2007, 12:31 PM   #85
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
tiksman is no. 1
Old 06-27-2007, 02:55 AM   #86
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Thanks Jimcat for the fog light kit!!! It came in one day ahead of schedule hehe.Will install on Friday night
Old 06-30-2007, 06:22 PM   #87
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Ok. Got them installed today. So happy
Old 07-02-2007, 12:38 PM   #88
myt
myt's Avatar
Drives: Blazing Blue 07 YAris
Hey guys, I think that I am going to try and tackle this myself. Did you have to remove the bumper to install the fog lights?
Thanks,
MYT
myt is offline   Reply With Quote
Old 07-02-2007, 04:11 PM   #89
tiksman
tiksman's Avatar
Thanks,
MYT
No look at the first pics you can get to the fogs by just undoing the top of the bumper
Old 07-02-2007, 09:48 PM   #90
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I went though the wheel well and front bumper......not very smart but it got the job done and I ended up with a lot of bruises from my arm being squashed in there
Ebay OEM style fog lights installed fantabulousbaby Cosmetic Modifications (Exterior/Interior) 29 04-28-2009 10:14 AM
EBAY OEM BUMPER FOG LIGHTS Wayside General Yaris / Vitz Discussion 41 01-09-2007 12:52 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
"OEM" fog lights from ebay drell42 Cosmetic Modifications (Exterior/Interior) 5 07-28-2006 09:21 AM
Liftback Fog Lights on eBay Chris07LB General Yaris / Vitz Discussion 8 07-24-2006 07:06 AM
