Old 03-03-2007, 10:27 AM   #73
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
put the trd sway bar on today and it looks nice. not sure if it does anything yet, but springs are coming next......
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 03-04-2007, 06:56 AM   #74
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
RocklandToyota,I have a few questions about your sig.Do those TC mats have a TC logo or Scion logo?Do they fit the Yaris perfectly,does the driver side mat use the 2 clips to stay in place?
Why did you use the XB neon light package,is it the same package for the Yaris,just cheaper?
eco is offline   Reply With Quote
Old 03-04-2007, 06:57 AM   #75
eco
eco's Avatar
Ohya,I have my rear TRD bar installed,and my ass is alot smoother,like a baby's.
Old 06-21-2007, 01:37 AM   #76
curik
Drives: 06 yaris AT
Hmm I wonder if the torsion beam is an independent type of suspension. On my Accord Euro (very similar to your Acura TSX in the USA) has independent rear suspension, and I could feel a huge improvement by upgrading the stock swaybar, there is more oversteer. But since the swaybar acts to limit the movements between the left and right arms, it requires the left arm to be independent to the right one. In our case, the torsion beam connects the left and right suspension, hence by adding an extra swaybar, it increases the "stiffness" of the torsion beam. However since torsion beam is a non independent type suspension, the increase of handling performance will be less than if it was fitted on an independent type rear suspension.
This could be the reason why he said adding a swaybar on a torsion beam suspension does not do s@#!. I actually own a liftback yaris and I am thinking to get the swaybar too. But so far I have not seen any convincing words which can make me click the buy it now button.
curik is offline   Reply With Quote
Old 06-24-2007, 06:57 AM   #77
blueskana
blueskana's Avatar
Drives: 2007 Yaris LB
How would a conventional, chassis-mounted, linkage-drop down arm system work with a trorsion-beam suspension design? I can see how the trd one basically just stiffens up the beam, but couldn't you take the sway bar, mount it to the body on poly bushings and connect it to the shock mounts on short linkage arms? If you are looking for a truly stiffened, 3-wheel cornering without having to have insanely high spring rates, wouldn't that do the trick? Am I totally smoking crack here or what? Somebody who understands this better help me out.
Oh, and this is my first post, Hello everyone! :)
blueskana is offline   Reply With Quote
Old 09-05-2007, 09:53 PM   #78
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
I gots me a sway bar that I paid "big bucks" for. :)
OgDogg is offline   Reply With Quote
Old 09-06-2007, 12:41 AM   #79
SDsurfrider
SDsurfrider's Avatar
Drives: 07 Sedan S
There are a bunch of good sources online dealing with suspension setups and how changes will affect handling. A quick google search turned up these examples:
http://auto.howstuffworks.com/question432.htm
http://en.wikipedia.org/wiki/Anti-roll_bar
I have a porsche 924s autoXer and these are from those forums(I know the 924s is not the yaris but it too has a torsion system rear susp):
http://www.wtrscca.org/tech.htm
http://www.kormanfastbmw.com/thandling.htm
http://importnut.net/tiretech.htm#hipochrt
http://www.cjtire.com/pdfs/Servicing...&%20Wheels.pdf
Anyways when I put on the rear sway bar on that car I immediately noticed a difference, more so because it is RWD though.
SDsurfrider is offline   Reply With Quote
Old 12-01-2008, 09:39 PM   #80
Milk Dud
Drives: 2007 Yaris
Tires with swaybar
I see you've been mentioning about descent tires to go along with the sway bar. Just wondering what sort of tires you'd recommend. I'm thinking of buying 16s and a sway bar for my girlfriend's 07 Sedan for Christmas. Also, anyone experienced any bad things with 205/55R16s on stock springs?
Milk Dud is offline   Reply With Quote
Old 12-01-2008, 11:34 PM   #81
uncleyaris
The sway itself is big difference. I organized a GB on them and you will not be disappointed!!!
Old 11-21-2009, 04:59 PM   #82
akirawm
akirawm's Avatar
Drives: YARIS 1.3
sway bar for yaris sedan ?
akirawm is offline   Reply With Quote
Old 11-23-2009, 12:27 PM   #83
MUSKOKA800
MUSKOKA800's Avatar
Yes, TRD and others.
In the case of sway-bar, same part for sedan and HB.
I installed mine weeks before the other TRD parts.
BIG improvement! Reduced body roll (sportier) and reduced cross-wind effect on the highway (safety) providing a much more relaxing ride.
Old 11-23-2009, 01:02 PM   #84
Ultra Racing 19mm sway bar (liftback and sedan), same size and quality as TRD, $30+ cheaper:
http://shop.microimageonline.com/pro...0&categoryId=4
Ultra Racing 23mm sway bar (liftback and sedan), beefier, more anti-roll in turns:
http://shop.microimageonline.com/pro...5&categoryId=4
Old 07-14-2010, 11:24 PM   #85
birdman
Some say they make no difference while others say they do. Maybe it's more to do with variations in our nervous systems abilities to feel the differences or lack there of. All I know is that before I put mine on it didn't handle sharp turns without a fight where now it fights noticeably less. For my nervous system they were worth every cent.
Old 07-18-2010, 08:45 PM   #86
MUSKOKA800
MUSKOKA800's Avatar
Pokey drivers may not notice the flattened cornering by adding an anti-sway bar but it would be hard not to appreciate the increased cross-wind stability if you drive on the freeway with strong winds and semi's abound.
I'd like to sample the 23mm bar although it's billed as being for 'the track', not street.
Old 07-18-2010, 09:43 PM   #87
RedRide
RedRide's Avatar
I have the 23mm bar for steet use and I love it.
I can't see how it would be a problem for a DD for anyone who has any semblance of driving skills.
It also make freeway driving much safer because fast, emerency lane chages, etc are much more secure and stable.
Old 08-07-2010, 01:59 AM   #88
'LilRedYaris
'LilRedYaris's Avatar
Drives: 2007 Yaris Sedan
Send a message via Yahoo to 'LilRedYaris
Had the Ultra Racing 19mm rear sway bar installed on my sedan today. Huge, huge difference. Luckily, I got to test it fairly thoroughly today too. The Yaris is definitely tighter and surer on the road now. Steering and cornering are almost effortless. All I can say is: "Wow!". Kudos to Garm @ Micro Image for providing great products, customer service & support. Digging my YW T-shirt too.
'LilRedYaris is offline   Reply With Quote
Old 08-07-2010, 02:29 AM   #89
^ awesome, glad you like it! Definitely in my "Top 5 things they should have included on the car" list.
Old 08-07-2010, 08:20 AM   #90
sickpuppy1
Drives: 2010 Yaris Sedan
The "Ultra" 19mm bar from MI, like Garm said is same as TRD but less expensive is what I put on mine. I love it, Those who say it wont make a difference obviously have not tried it. Knowing that a sway/torsion bar is going to stiffen the suspension in the corners, I went with the 19mm since its my daily driver and didnt want the ride quality to suffer. Honestly, you would have to drive thru the same corner and be keenly aware of every bump to POSSIBLY tell any difference in ride quality. But the difference in handling is very noticeable! As you enter a corner, the rear of body will take a slight lean and then just set and go! Very interesting actually as if your paying any attention, you can tell by feel and by eye when it kicks in. Crosswind stability and driving by trucks and such are also much improved.
As I said, I had worried that ride would stiffen up too much,but that was unfounded as it really hasnt changed at all. I wish now that I had gotten the 23mm as pushing it into corners is much more fun,lol. My only concern now is how much sooner I'm gonna have to replace tires from all my "playing around" LOL Any of you still on the fence about doing this can be assured it is money well spent, and Micro Image has good stuff! I'm sure the TRD is good also, but i know who I'm getting mine from.......
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Progress 22mm Rear Sway Bar PRE-ORDER SPECIAL 03Z33 Items for Sale by private party 85 04-13-2007 11:48 AM
Sway Bar! dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 55 01-12-2007 03:31 AM
sway bar Lowfront Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 10-18-2006 08:51 PM
Sway bar chrisada_to2a Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 09-05-2006 07:34 PM
