Old 03-03-2012, 09:21 PM   #1
enviri
enviri's Avatar
Drives: 2010 Yaris
Now that you said that...it does feel like the pedal travel is a bit longer...
Old 03-03-2012, 10:07 PM   #2
seth_man
seth_man's Avatar
Drives: 08 Liftback
piston diameter is larger on xd/corolla calipers, therefore move fluid volume is required to move the piston the same distance, it takes a longer master cylinder stroke to move more fluid and create the same pressure at the brake pad. in all reality we prolly should be upgrading to a larger bore diameter master cylinder to go with this caliper upgrade. our master cylinder bore diameter is 13/16" and the xd master bore diameter is 7/8"
seth_man is offline   Reply With Quote
Old 02-05-2015, 05:17 PM   #3
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
I'm gonna revive this thread awesome info!
Think I'll swap the master cylinder also! Corolla and XD are they the same?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 03-03-2012, 11:48 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
it really isn't too noticeable. If you want to order a master cylinder, tell us if it fits and I'll happily swap it
Old 10-05-2012, 02:50 PM   #5
enviri
enviri's Avatar
Drives: 2010 Yaris
update on bbk, did a checkup after 30k miles and the brake pads are still pretty damn new. everything is working fine and wearing nice and even.
Old 10-25-2012, 04:06 PM   #6
mario98c
mario98c's Avatar
Nice!
Old 10-25-2012, 04:15 PM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Awesome another brake option.
Old 07-08-2013, 09:48 AM   #8
kou
Drives: 08 lb
Just upgraded mine over the weekend. My first brake job on the yaris 102,000 and still had some pads left but warped rotors. Total cost $380 OEM pads for 2009 corolla rebuilt calipers for 2009 corolla and rotors from the yaris se. Wheel size is 15x7 et42.
Old 07-08-2013, 10:20 PM   #9
enviri
enviri's Avatar
Drives: 2010 Yaris
Woo!! 2 in the northeast! now go persuade james to do it lol
Old 07-08-2013, 10:37 PM   #10
kou
Drives: 08 lb
Haha I will try. Now I need some rear disc brakes.
Old 07-08-2013, 10:38 PM   #11
enviri
enviri's Avatar
Drives: 2010 Yaris
i'll keep a look out for you.
Old 07-08-2013, 10:41 PM   #12
ASG14
Camry Owner
Drives: '96 Camry XLE 1MZ-FE
Send a message via AIM to ASG14 Send a message via MSN to ASG14
AWSOME!
ASG14 is offline   Reply With Quote
Old 02-05-2015, 06:37 PM   #13
enviri
enviri's Avatar
Drives: 2010 Yaris
47201-52420 -> scion XD
47201-02490 -> corolla XRS 09
Old 02-05-2015, 06:45 PM   #14
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
will they mount properly on the Yaris is the question, for a rear disc swap corolla XRS should be the best
R-CaT
Project Yar 2ZR
Old 02-05-2015, 09:08 PM   #15
enviri
enviri's Avatar
Drives: 2010 Yaris
most likely not lol.
you *MIGHT* get away with using the scion's master cyl,
and i know the brake booster off an xd will plug right in...
44610-52620
the XRS booster assy looks sooo different.
44610-02441
Old 07-11-2015, 04:49 PM   #16
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Got to bring this UP if you are going for the master brake swap from the XD you need the Booster
R-CaT
Project Yar 2ZR
Old 08-03-2016, 01:48 AM   #17
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
Just installed the XD BBk (lol) and would highly recommend it. I did not swap for the XD MC or booster yet but plan to soon. The stock Yaris MC and booster are now the weak point and there is a slight but noticeable loss in break pressure when hitting the breaks hard (not that you ever need to in a Yaris other than to avoid an accident).
The piston diameter size difference mentioned earlier explains the slight fade in pressure perfectly. Also I had never changed my pads or rotors after 240,000 miles and over 8 years my Yaris. The OEM pads and rotors were in great shape considering their age, only a small crack on the pads and a hairline crack on one rotor.
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 08-11-2017, 09:12 PM   #18
Jerkratt
Jerkratt's Avatar
Soo.. Wakey Wakey XD MC & BB plug n play?
"It hurts more when its wet"
bbk, big brake, big break kit, brakes, jdm
07 YARIS Liftback FOR PARTS benjomothians DIY / Maintenance / Service 0 03-28-2011 01:10 PM
Aftermarket parts and Factory Warranty in Canada? jonathanq Canada 3 07-11-2009 12:17 PM
FS: C-One Parts new & used - Socal 03Z33 Items for Sale by private party 90 06-03-2009 10:08 AM
