Old 04-20-2013, 07:55 PM   #73
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Sorry Garm, I totally spaced about taking off the pan...hah
yariSB86 is offline   Reply With Quote
Old 04-21-2013, 11:01 AM   #74
yariSB86
yariSB86's Avatar
Ok, think I finally got all the right parts for this oil return install. Going to start with removing the oil pan :) (thanks Garm). Then prep the drill, make sure I have room. Then drill the hole. Wish me luck.
Old 04-21-2013, 01:49 PM   #75
good luck. It's aluminum, pretty soft, just be patient and you'll be fine!
Old 04-25-2013, 08:50 PM   #76
yariSB86
yariSB86's Avatar
Hey guys. Sorry for no updates as I've been sick, and still am. Damn sinus infection.
Anyways, I've managed to get the oil return line finished. Waiting on the oil pan seal to cure. Double checked all my piping/couplers. Pretty close to first start up, won't be until Monday or Tuesday. I'm working all weekend. It's coming along. Slow and steady.
Old 04-27-2013, 03:10 PM   #77
yariSB86
yariSB86's Avatar
I am in need of a base tune I can work off of. The car doesn't idle long enough for me to do anything. Does anyone have anything I can work with?
Old 04-30-2013, 02:52 PM   #78
yariSB86
yariSB86's Avatar
Update #1
So an update for how things have been.
Everything is installed and working as well as it can be for first start up.
No leaking oil, no exhaust leaks.
I need to pick up some heat shroud still. There is a really good place up the street that specializes in this so that's good.
I am having problems though. As I expected.
Only really big problem at the moment is that I need a good base tune to work with. The car doesn't idle long enough (maybe 20 seconds) for me to manipulate anything.
So I am going to ask anyone if they have a good base tune I can work with to just get things going.
Thanks
Old 04-30-2013, 03:00 PM   #79
kou
Drives: 08 lb
Are you using the aem fic? it should start and idle fine,did you install fic before turbo install or all at the same time?
Old 04-30-2013, 03:15 PM   #80
SB86, I'm emailing you a couple of base maps now.
Old 04-30-2013, 03:18 PM   #81
kou
Drives: 08 lb
Send them to me also please to see if what I have made so far is going to work.
Old 04-30-2013, 03:20 PM   #82
yariSB86
yariSB86's Avatar
@kou I am using the AEM FIC. And I did install everything at same time.
@Garm Thank you :)
Old 04-30-2013, 03:25 PM   #83
kou
Drives: 08 lb
Did you calibrate the fic? i am running all zeroed in all the maps and 810us for injector response time I am running NA to collect factory data for maf clamp and afr ratio voltages. Getting my downpipe made on sunday so should have some tuning info then.
Old 04-30-2013, 04:12 PM   #84
yariSB86
yariSB86's Avatar
Garm, that richened tune runs good. I like the 11-10 range for 8psi. Car still doesn't idle. dies almost as quick as I can shift. Like ive I push the clutch in, the car will idle to stall. I don't get it...any suggestions?
also, when i uploaded that tune, my tachometer stopped working...
Old 04-30-2013, 05:12 PM   #85
yariSB86
yariSB86's Avatar
I have not tried the bypass harness. yet.
Old 04-30-2013, 05:27 PM   #86
kou
Drives: 08 lb
Maybe BOV stuck open a little?
Old 04-30-2013, 05:33 PM   #87
I ran 8 psi with no tuning for 8 months. Didn't race or hit it hard, but the car ran "ok".
Old 04-30-2013, 05:49 PM   #88
yariSB86
yariSB86's Avatar
@tolmach - I did tap the upper oil pan assembly
@kou - I'll check, but i doubt it.
@Garm - With your "leaned" tune the car runs 12.5-10.0 at idle...Is that the way you have it intended?
Old 04-30-2013, 05:59 PM   #89
yariSB86
yariSB86's Avatar
Just started it up after it cooling down for a bit. with Garms "lean" tune it idles at ~14.5. Revd up to ~1500 it goes anywhere between ~13.5 - 11. When i lift off throttle it goes 10.0 - 20.0 then evens back to ~14.5-13.5
I can't test drive that yet, watching kids while the wife runs errands. But when i do, ill be sure and post the numbers.
Also Garm, are either of these tunes you emailed tuned with the 1zz injectors installed?
Old 04-30-2013, 06:07 PM   #90
yariSB86
yariSB86's Avatar
@Tolmach, It was really soft, maybe 2-3mm. I used a 1/4" - 3/4" unibit. Drilled for 3/4". I attached a -8 AN bulkhead fitting. And i drilled above the oil line.
List of Boosted Yarisworld Members - Redux CTScott Forced Induction Forum 40 06-29-2025 08:42 PM
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
