Old 03-19-2009, 01:31 PM   #1
regal
I have basically been hypermilling since 1990 when I was driving a 350ci Cutlass on a student budget. I think the OPer is not understanding the concept. The whole idea is not to accelerate more than you need to. Yes some of the techniques are not practical but gunning the car between lights is not practical either, or speeding up +20 mph 30 seconds before your exit. The idea behind hypermilling is to use common sense, something that probably 95% of the US drivers have none of. I drove a 50 mpg 85 Jetta for a few years and the 50 hp engine had no choice but to hypermill. It takes much less fuel to go from 0 to 60 mph in 25 seconds than to do it in 7 seconds.
The other thing about hypermilling people don't understand is that it isn't always about driving as slow as possible. 5th gear is always more efficient than 3rd. Puttering around at 30 mph in 3rd gear will give terrible milage vs 55 mph in 5th.
Old 03-23-2009, 09:54 AM   #2
Naya
Drives: 2007 Toyota Yaris
Hello,
I'm kinda new to this whole car thing, so forgive me if any of my questions seem a little noobish.
I have a 2007 Yaris with about 30,000km on it. I've taken it for all it's scheduled oil changes and haven't had any issues until recently.
I noticed my fuel economy getting worse and worse over time. At first I just attributed it to the cold winter (it gets pretty frosty in Ottawa) but even now that it's coming to spring, it's getting worse. When I was doing mostly highway driving I was getting about 400km to a tank (this was up until Janurary). I am now getting about 350km to a tank, running it almost to dry. Most of my commute now is city driving, not going above 85km/h.
I took it to my local dealership and they said nothing was wrong. Most of these issues seem to have started happening after my last oil change, but that might just be a coincidence. I also noticed that when the engine is cold, the transmission is really sticky. If not warmed up for at least 15 minutes, it will sit at about 4000rpm doing 80km/h and refuses to shift until brought up to 90km/h (4500rpm).
Sorry if it seems like I'm just spewing out information, but I really have no idea what would and wouldn't be relevant. I'm hoping someone might be able to give me some ideas. My dealership has been no help at all.
Naya is offline   Reply With Quote
Old 03-23-2009, 02:52 PM   #3
supmet
Drives: 2007 4 Door Yaris
Originally Posted by Naya View Post
in the first year I had the car I was doing city driving (the same as I am doing now) and was getting 600-700km per tank (run almost completely dry).
I just found a quick calculator online and I'm currently getting about 26mpg.
I'm no hypermiling expert, but I'm pretty sure driving habits alone will never account for a 50% reduction/ 100% increase in FE. That is, unless you went from using EVERY hypermiler trick in the book, to ricky racer/constant wide open throttle over night, without knowing.
Something is wrong with your car.. Have you changed the air filter? What's your tire pressure?
Old 03-26-2009, 07:16 AM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I agree, while driving technique is hugely important, something has to have happened to that car to make the mileage drop by half with the same driver.
Have you had the OBD-II system checked for error codes?
Old 03-23-2009, 10:27 AM   #5
BailOut
Steals terrorist's lunch
BailOut's Avatar
Hello Naya,
The high RPM/no Drive gear change is normal while warming up. It is the same for all owners that have the automatic transmission (AT).
As for your drop in mileage I an going to ask you a seemingly stupid question:
Are you sure you have the shifter in the D position rather than the 3 position when you drive off?
Many AT owners get confused by the D placement and drive around in 3rd all the time, causing a huge hit to their fuel efficiency.
- Brian
Share the Road
Old 03-23-2009, 11:30 AM   #6
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
It's normal. Had my Yaris for over a year, and even with some insane hypermiling, never broke 35mpg (about 98% city driving, very short trips).
firemachine69 is offline   Reply With Quote
Old 03-23-2009, 01:48 PM   #7
Naya
Hi Bailout,
Thanks for the quick reply! It's not a stupid question at all (since I have made that mistake once before). I always use D and not 3.
Just as an example of the change in fuel economy, in the first year I had the car I was doing city driving (the same as I am doing now) and was getting 600-700km per tank (run almost completely dry). My fuel economy was insanely good. I don't expect it to ever get that good again, since I don't know what I did to luck out on that, but as it stands I'm getting about the same fuel economy as my friend who has a Dodge Avenger R/T. He's really getting a kick out of that.
Oh and FireMachine, I just found a quick calculator online and I'm currently getting about 26mpg.
Old 03-23-2009, 01:54 PM   #8
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Naya,
When you say you're doing mostly city driving now, is it very very short? You take a mileage hit when you do very short stops while the engine is not warmed up.
Old 03-23-2009, 02:21 PM   #9
BailOut
BailOut's Avatar
Naya,
This is not an easy question to answer sometimes, but have you changed your driving style over the lest few months? Been stressed out? Been working long hours? Been more angry? Any driving that is more aggressive than your previous style will cause MPG hits, and to achieve MPG as low as you are reporting points to heavy throttle usage.
- Brian
Share the Road
Old 03-27-2009, 09:37 AM   #10
Naya
Thanks for all the replies guys.
"When you say you're doing mostly city driving now, is it very very short?" - Yup. Usually about 3km there, another 3km back at the end of the day
"Have you changed your driving style over the lest few months?" - Not that I can think of. I actually make a game of it to see how high I can get the milage, so I'm very concious of how hard I accelerate and try to avoid braking as much as possible.
"Have you changed the air filter? What's your tire pressure?" - Haven't checked the air filter, but I did check the tire pressure and it seems to be fine. I'll check the air filter tonight.
"Have you had the OBD-II system checked for error codes?" - Not even sure what that is :)
When I brought it to the dealership they said they hooked up a computer to look at my fuel economy then took it out to an 80km/h road. I'm not sure of all the circumstances under which they drove it but they said that it was getting 27mpg and that was just fine.
Old 03-27-2009, 11:57 AM   #11
BailOut
BailOut's Avatar
Short trips like that will totally kill your FE as the engine never warms up and runs rich the entire time. This doesn't explain why your FE dropped, though. Was your commute (or any other usual driving) a longer distance before?
On a different note, with a commute that short have you considered bicycling it rather than driving it?
- Brian
Share the Road
Old 03-27-2009, 01:23 PM   #12
Naya
Now that it's finally warming up I'm looking at switching to a bicycle :) Canadian winters are a little frigid which is why I was taking the car in the first place. Now that the temp is finally above 0 I'll be switching to bike, and my other half will be taking the car back.
The reason I'm trying to see what to do about the milage is I was a bit worried because his trip is about 35km each way all highway. (To answer the question before anyone asks it, we had 2 cars, one of them got totaled, and a friend from work was able to drive him each day so I got the car.) With the milage as bad as it has been lately that would kill us on gas. I'll see how it does on highway starting next week.
Old 05-14-2009, 02:50 PM   #13
BailOut
BailOut's Avatar
Holy cow! Great job, voodoo22! That's a new world record for the gasoline Yaris!
- Brian
Share the Road
Old 05-14-2009, 06:41 PM   #14
mchllp925
Darrin
mchllp925's Avatar
Drives: 2008 yaris le h/b
Well, since I hit 15,000 kms, my FE has vastly improved.
Since April 2008, I was gettin maybe 260 kms for 30 litres(or so) of fuel.
Now, I might actually get close to, or over, 250 kms for a 1/2 tank.
I haven't changed my driving habits much.
Is there some truth to what my dealership says, that around this mileage the FE will improve?
Just my 2 cents worth.
P.S. Congrats on your MPG voodoo22
Darrin
mchllp925 is offline   Reply With Quote
Old 06-04-2009, 12:48 PM   #15
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i hope i do better this year..the most i did was 695km on a 36 liter..90% hwy
Old 06-16-2009, 10:17 AM   #16
BailOut
BailOut's Avatar
voodoo22! That is awesome, and it is a new world record for single tank MPG with the 1.5L Yaris! A combination of self discipline, technique, planning and a fair amount of luck combined to create a magical tank. I love it when a plan comes together!
You've set the bar way up there, my friend.
My own FE experience has been much different lately. I haven't been driving much, maybe once or twice per week. I bicycle to/from a carpool, I've been using public transportation to get to/from my company's data center colocation in Sacramento, I've been bicycling the grocery run and almost all my errands, telecommuting one day per week, etc. When I do drive it's usually to haul mountain bikes over the mountain for a commute on our organized ride day (which will change if Nashbar ever gets around to sending me my bicycle lights as I'll be able to trailer my MTB to the carpool with the road bicycle and return home late at night with it) or to take my Little Brother out for an activity.
My Little and I are scheduled to go for a MTB ride on a beginner trail this Saturday and I plan to get to and from his house on the north side of town, get us both to and from the trail area, to lunch and then back to his house only using public transportation and pedal power.
I'll be making another Sacramento run later this week. I already have my Greyhound tickets and exact change for city bus/rail fares ready.
However, my Yaris is still being driven a bit as I've been able to get my wife to use it for her needs in lieu of her Tacoma some days. While this saves a ton of gasoline she doesn't hypermile at all so my last tank was a paradox. It lasted a whopping 22 days but came out at just 45 MPG. This is the kind of scenario where simple mileage tracking doesn't accurately reflect the actual fuel usage and savings.
- Brian
Share the Road
Old 06-17-2009, 07:28 AM   #17
Woody_Woodchuck
Drives: 2008 Yaris LB 5M
56 mpg is fantastic, congratulations! Seems to me you will be the first to break the 650 mile tank or 60 mpg tank barrier also!!!
I’m still fighting to match your 50+ mpg tank streak. Don’t worry, my evil plan is to not match it but SMASH it altogether. A tank over 55 mpg for me is going to take some drastic hypermiling techniques and lots of lucky commutes. Not impossible but very unlikely with my terrain and commute traffic. Heck, last night on the way home traffic was so heavy I had to drive the speed limit and could not get any coasting in for the first 20 miles. Managed to just break 50 mpg for the 30 miles, average is around 54 mpg.
Keep up the great work and keep raising the bar higher.
On a side note: Getting the average numbers for speed versus impg is going to take a while. There are only a couple flat sections on my commute and with the recent traffic I will not be able to get any standard down. I’ll get them, just going to take a while is all.
Lifetime log
Woody_Woodchuck is offline   Reply With Quote
Old 06-17-2009, 08:33 AM   #18
daf62757
Nothing beats a Toyota!
daf62757's Avatar
I just wish my Yaris had a larger gas tank. 15 gallons would have made a tremendous difference. 11 gallons isn't really large enough. 20 gallons would have made it have a tremendous range!
Big Dave
Indianapolis, IN
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
Fuel consumption US Yaris vs. Canadian Yaris Driver Performance Modifications 8 10-29-2006 02:27 AM
