Old 02-15-2011, 01:07 PM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Experience builders... Kick panel building...
is it OK if I don't use FOIL on top of the carpet, before the tape?
D.
CLA 250, 4MATIC
Old 02-17-2011, 12:59 AM   #2
derickveliz2
Arrow
I think I'm going to put the OEM carpet with "Yaris" logo and tape on top, so I can get the carpet down there with out cutting it!
Here are the pictures of what I did a couple of nights ago...
D.
CLA 250, 4MATIC
Old 02-17-2011, 01:54 AM   #3
CAyaris
CAyaris's Avatar
Send a message via MSN to CAyaris
Looks good let me know how that works for you i have been looking into making custom fit enclosure like that in a wheel well or next to one
108hp and still rolling
CAyaris is offline   Reply With Quote
Old 02-17-2011, 02:17 AM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I kicked a response onto DIYMA
― Thomas Paine
Old 02-17-2011, 07:56 AM   #5
derickveliz2
It's going to warm up a little bit here in next couple of days, I'll take advantage and work some fiberglass!
D.
CLA 250, 4MATIC
Old 02-17-2011, 07:40 PM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Work it brother! Pics!
― Thomas Paine
Old 02-18-2011, 03:33 AM   #7
derickveliz2
Wow!
I think I hit the wall, 3:40 am and I made a mess. Working with glass making kickpanels it's very hard.
I'll show pictures of my frustration, I think I can make it work... we'll see!
D.
CLA 250, 4MATIC
Old 02-18-2011, 06:04 PM   #8
sqcomp
Roadrunner Jr.
sqcomp's Avatar
If you could see how big my smile is...
I have a hint for you that can make your panel fab a little easier.
― Thomas Paine
Old 02-18-2011, 06:42 PM   #9
derickveliz2
Unhappy
I guess I need some advice!
D.
CLA 250, 4MATIC
Old 02-18-2011, 08:13 PM   #10
sqcomp
Roadrunner Jr.
sqcomp's Avatar
First, what was the most difficult part of the glass laydown?
― Thomas Paine
Old 02-19-2011, 12:29 AM   #11
derickveliz2
Red face
OK, besides getting down there and doing some Yoga... the most difficult part was applying the resin on the upper section/vertical areas. The fleece just kept sticking everywhere out of place. I guess I need to be more aggressive and not to be afraid to work with more than 6 oz of resin at a time.
D.
CLA 250, 4MATIC
Old 02-18-2011, 09:25 PM   #12
sickpuppy1
Drives: 2010 Yaris Sedan
Got my Lil sub in a .56 cu ft ported box....Nice balance of sound now, and with the fronts not doing anything under 100hz, they are livin better too. Gotta play with settings, but so far so good!
I bet that is a hard shape to lay freehand. Listen to SQ Derick. Maybe learn from his "experience"........
Old 02-19-2011, 12:44 AM   #13
derickveliz2
Red face
Here are the pictures of the kick panels in wanna be kick panels...
Get set GO!
This morning every thing looked ok, very stiff and rock solid, I don't know if I should pull them out and keep adding layers or do another layer down there?
D.
CLA 250, 4MATIC
Old 02-19-2011, 02:11 AM   #14
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Eeek...it's just me, I wouldn't lay day down fleece as a bottom layer. Butnow that I know you did, we can work with making that fleece straight. Do what you can to make the substrate as flat as possible for a few more layers. I use fleece to wrap the top of the enclosure.
Show me pics of how you lay down glass matting. I may have some suggestions.
― Thomas Paine
Old 02-20-2011, 01:57 AM   #15
derickveliz2
Arrow
Well, the first batch was kind of random, just trying to cover the fleece at least once or twice in some areas, My intention was to place them at 90 degrees overlapping with each other starting from top to bottom, but didn't happen.
It got cold again, Brrrr
D.
CLA 250, 4MATIC
Old 02-20-2011, 01:35 PM   #16
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The issue starts here. We need to keep the substrate flat to get the closest fit to the panel. If the base isn't flat it is VERY difficult to get a build up with all those waves that we see. Also, it's probably better to use chop mat versus glass weave in that area. Chop mat is great for build up, which is what you're trying to do.
― Thomas Paine
Old 02-24-2011, 01:59 AM   #17
derickveliz2
Arrow
It wasn't easy to pull that thing out!
The waves kind of filled in and made a flat surface in the back, the second layer filled in the uneven areas on top, I just added another layer, it's very heavy and solid, I'm going to add another layer or 2 then trim out and glue in the ring for the speaker, any suggestion for aiming the L6s? my feeling is 30-45 degrees at the stick???
This is not easy, I guess after doing it half a dozen times, it gets better!
D.
CLA 250, 4MATIC
Old 02-23-2011, 05:04 PM   #18
derickveliz2
I did a second layer, now I'm going to try to pull it out, trim and reinforce it.
D.
CLA 250, 4MATIC
