Old 03-05-2011, 07:19 AM   #991
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@xtremist / frank, di ako kumuha sa door speaker, dun mismo ako sa harness nangapa ng feed, nag-splice na lang ako ng wire dun, IMO less hassle sa pag-alis ng door panel.
rye7jen is offline   Reply With Quote
Old 03-05-2011, 07:22 AM   #992
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
pwede pre, kung makukunan mo ng pic paki post, plan ko kc magtap din ng maliit na twitter eh...hehehe
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 03-05-2011, 07:44 AM   #993
xtremist
xtremist's Avatar
mga bro, check out the set up of our kabayan for his vios sound system including base and frame for his trunk (all are DIY)...galing :
http://www.diymobileaudio.com/forum/...yota-vios.html
Ciao !!!
Old 03-05-2011, 08:41 AM   #994
syntax
syntax's Avatar
@ insan ricky, check mo ang link na ito para sa installation mo ng sidemirrors
3
http://www.yarisworld.com/forums/sho...73&postcount=1
Old 03-05-2011, 08:48 AM   #995
xtremist
xtremist's Avatar
3
nosebleed ako d2...wahahaha
Ciao !!!
Old 03-05-2011, 08:53 AM   #996
syntax
syntax's Avatar
wehehehehe kayang kaya ni insan yan, wag lang sya kabahan sa pag tanggal ng mirrors
Old 03-05-2011, 08:54 AM   #997
xtremist
xtremist's Avatar
hehehe...yun lang...hehehe
Ciao !!!
Old 03-05-2011, 09:15 AM   #998
xtremist
xtremist's Avatar
guys, share ko lang about car audio installation, nagbabasa basa ako at so far naintindihan ko ng mga pinag gagawa kahapon. hehehe
http://www.caraudiohelp.com/how_to_i..._a_car_amp.htm
Ciao !!!
Old 03-05-2011, 09:19 AM   #999
rickyml
rickyml's Avatar
Drives: Yaris 2008
nosebleed nga rin ako dito... siguro mtatanggal ko ang side mirror pero ang installation ng wire... huhuhu ako.
rickyml is offline   Reply With Quote
Old 03-06-2011, 02:26 AM   #1000
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Klaxcar Horn (with relay?) need help Guys
Dahil sa tulong ni kabayan, from 35sr ginawa na lang 25sr
Heto naman yung hinayupak na relay.. Ang basa ko sa Horn at s relay same silang 30A (kailangan ko ng tulong sa ating mga henyong kayaris)
Nakabili na rin ako ng harness from local electric shops.
Old 03-06-2011, 02:41 AM   #1001
syntax
syntax's Avatar
@ rye hindi ba plug and play ito?
Old 03-06-2011, 02:53 AM   #1002
rickyml
rickyml's Avatar
Drives: Yaris 2008
rye... ganyan din ang kinabit kong Type-R horn... pagisahin mo lang ang ground tapos yung isang wire na currently meron tayo sa yaris.. yung ang ikabit mo sa isang wire... bali series lang yon.
Old 03-06-2011, 02:54 AM   #1003
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Hindi eh.. kaya siguro mura lang.
Old 03-06-2011, 02:55 AM   #1004
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Originally Posted by rickyml View Post
rye... hindi namin makita ang pics.
:eek!: kita naman? inupload ko thru YW uploader.
Old 03-06-2011, 03:01 AM   #1005
syntax
syntax's Avatar
kelan mo balak ikabit pre'
Old 03-06-2011, 03:03 AM   #1006
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@ricky, baka may pics or diagram ka? pa-post naman? ginamit mo rin ba yung kasmang relay? Ilang ampere pala yung horn na kinabit mo?
Old 03-06-2011, 03:04 AM   #1007
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax, as soon as alam ko na yung wiring pati na rin yung pagkabit ng relay, ikakabit ko na agad.
Old 03-06-2011, 03:06 AM   #1008
rickyml
rickyml's Avatar
Drives: Yaris 2008
naku, naitapon ko na yung diagram eh. pero magbe-base ako sa picture na pinadala mo. yung dalawang may butas... pagiisahin mo lang yon. then, yung isa sa neg & possitive, ida-direct mo rin sya connected doon sa ground (doon sa may butas na pinagisa mo) then yung isang connector pagisahin mo rin yon at iyon ang ikakabit mo sa wire na avail sa yaris natin.
