Old 09-01-2015, 02:53 PM   #1
Geez look how smooth that crank is. Nice!
Old 09-01-2015, 09:39 PM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Wow, very nice!
Old 09-02-2015, 12:22 PM   #3
Jason@SportsCar
Bottom end is built, crated, and should arrive here on Friday. Then I get to slap the head on it and toss it in the car.
Old 09-02-2015, 04:13 PM   #4
ArmstrongRacing
Data doesn't lie
This is so Epic. Im glad to see you used CP, we use them in our Subaru builds! Great product!
Old 09-02-2015, 07:00 PM   #5
What are you pushing for whp on race day? This thread is awesome to follow, I love hearing all the mods you've made to the Yaris, keep at it.
Old 09-02-2015, 07:09 PM   #6
Jason@SportsCar
More than the stock 106hp.
Old 09-02-2015, 09:26 PM   #7
W/ the wins that you've racked up I would think so
Old 09-03-2015, 06:08 PM   #8
Jason@SportsCar
Might as well freshen up the clutch while the car is apart. New OS Giken floating clutch disk and pressure ring.
Old 09-04-2015, 08:58 AM   #9
Cool, it's like a multi plate style cluch.
Old 09-04-2015, 05:49 PM   #10
Jason@SportsCar
Cant believe how quick we went from parts to complete short block.
Old 09-04-2015, 07:16 PM   #11
Did you nee to adjust the ring gap much?
Old 09-04-2015, 07:49 PM   #12
Jason@SportsCar
That is beyond my pay grade. I sent out a stock short block with a set of CP-Carrillo rods and pistons, and got a finished piece back, what happened in between I do not know.
Old 09-25-2015, 06:57 PM   #13
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
UGH, I missed it.. I meant to watch it but got busy today... UPDATES!
-Derrick-
Old 09-25-2015, 09:42 PM   #14
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
you missed a pretty epic race, Jason finished 2nd after a spin\wreck at SF
2014 BSpec Divisional Champion
Old 12-18-2015, 06:17 PM   #15
Jason@SportsCar
Finally got the spare trans opened up, looks worse than I expected. Drove fine, other than a slight clunk when going from 5th to 4th - never even a grind from 3rd to 4th, no hint there was an issue until I found synchro teeth in the axle seal. In addition to a wasted synchro there are some broken and burned up parts. The oil sprayer broke off and the shaft it supplied got a little hot. Ordering a few replacement parts, and coating stuff this time. Still, after three years of racing with nothing more than a fluid change, I can't complain.
Old 02-02-2016, 05:06 AM   #16
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Oh, the horror! Not everyone knows what those are supposed to look like, but I can appreciate what happened in there. Will you be sticking with the stock ratios still, or have you decided to tweak them based on performance at a given track?
Old 02-02-2016, 12:32 PM   #17
Jason@SportsCar
Stock ratios? We have been using the Kaaz gear set since 2012. Nothing will be changing.
Old 12-18-2015, 08:55 PM   #18
Wow. Any miss shifts contribute to that?
Sent from my iPod Touch
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
