#1 |
![]() ![]() Drives: 07 Yaris Sedan Join Date: Jan 2009
2007 Yaris S
Flint Mica 64000 miles - Replaced tires @ 43k miles - Replaced stock front rotors and pads @ 64k miles with premium rotors and pads (Rotors started to rust along the edge and scored my brake pads) - I feel the body/paint is too cheap to handle highway conditions. - Yaris needs lubrication on bushings/steering to have a quiet ride - May decide to replace stock struts - Stock rims too cheap/warp/dent easily. Replaced all 4 @ 50k miles - Steering rack has some noise, not ready for replacement yet. |
![]() ![]() ![]() Drives: 2009 Toyota Yaris Join Date: Jan 2009
2009 3dr liftback
< 33,000 miles Bayou Blue Problems: squeaky gears (DIY fixed Scuff on the back passenger-side bumper (Mom is no longer allowed to drive my Yoshi! )His poor nose is riddled with rock dings (working on a DIY for that)
#3 |
![]() Drives: yaris Join Date: Oct 2011
I have a 2007 with 100,000 miles and runs very well
#4 |
Posted in another thread. 2007, HB purchased new with 19,300 mi. Waterpump.
#5 |
Toyota
Drives: '11 5dr/5spd yaris Join Date: Nov 2009
Purchased 5/29/11: 16 miles.
11/1/11: 3,058 miles. Average: 139 miles/wk. :D I'll check in-in a month or two! |
#6 |
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
Purchased new Oct 2009. 23,000 trouble free miles. Click Fuelly icon for stats.
#7 |
purchased new@147mi. (driven to dealer) now at 33,000. trouble free so far besides that TSB w/ loose/rusty bolt issue in the front end
#8 |
![]() ![]() Drives: 2008 3dr Join Date: Oct 2011
2008 polar white liftback 3dr 5sp. bought it at 30,xxx miles, up to 32,500 now
only problem so far is a little stumble i get while idling...i dont have a tach so i couldnt tell ya how many rpm it drops, but it's enough to make the car shudder for a sec or two then jumps right back up....any ideas? |
#9 |
Toyota
12/1/11: 3,340 miles. Average: 128 miles/wk (26 weeks) |
#10 |
Toyota
1/1/12: 3,503 miles. Average: 116 miles/wk (30 weeks) |
#11 |
Toyota
Whoops. Forgot to check in for February.
Purchased 5/29/11: 16 miles 2/1/12: 3,611 miles Average: 103 miles/wk (35 weeks) |
#12 | |
![]() just shy of 50,000 miles now, couple of syn oil changes, replacing air filter, changed plugs (no difference), still have a low idle stumble every once and a while. just rotated tires and checked brakes front/rear. finally got a ultragauge- the lack of gauges in the base model leaves mea bit worried. have it set up for instant mpg, average mpg, tach, water temp, voltage, and miles till empty- going to see if i can find oil pressure though |
#13 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
#14 | |
brakes are getting a little noisy, passenger side pad, although still having more then 50% material left, looks like it has some stress cracking and pedal feel sucks - ordered new rotors and pads, going to flush all the fluid out as well for future use: 11/5/11 @ 32,500 (purchased shortly before) 4/12/12 @ 50,000 3/15/14 @ 123,494 Last edited by randeez; 03-15-2014 at 03:40 PM. |
#15 | |
pads still had plenty of material, honestly think I could have gone 200k miles with oem pads- they were just breaking away from the steel backing maybe not broke in properly? discs could have been reused/turned and reused for sure but I wasn't positive what was causing brake shake so I ordered some r1 rotors and hawk pads from micro image. rear brakes I changed awhile ago, upon the advice of tire dick around 100k miles . I looked at them before and they didn't have much material... when he mentioned it I figured mileage had been plenty for oem to change anyway. Went ahead and ordered new ones, made the time to change em, pulled the drum off and realized they just don't have much material on them to begin with. But I had new shoes and the time to do it. btw they quoted me almost 300bux to service rear brakes, so check em yourself they only have maybe 1/8"-3/16" of material |
#16 | |
![]() I see a few more high mileage cars have come around No issues since last check in, and I get the cup holder buzz, without the cabin filter I also get stuff down in the HVAC blower wheel too ![]() 10/23/14 @ 141,000 |
#17 |
![]() Drives: 2007 Toyota Yaris Join Date: Sep 2014
2007 Yaris Liftback
Blazing Blue Metallic 80,000 miles 2 new sets of tires (both Yokohama ~30,000 & ~60,000) New brakes last summer (~60,000 miles) Replaced driver window seal Nothing other than routine oil changes, etc. It has started running loud...a friend mentioned maybe the muffler might be bad. Hopefully it's nothing major. |
#18 |
2009 3 door hatchback
black 27,000 miles waterpump replaced ~26,000 cable rattle in reverse |
| excessive sulfur odor on 2007 model year Yaris | tomjasz | General Yaris / Vitz Discussion | 121 | 03-13-2010 06:49 PM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
