Old 09-15-2009, 07:12 PM   #1
wiliker
wiliker's Avatar
Drives: 2008 Yaris LB
Just received my 23mm sway bar from Garm. Will install this coming weekend, can't wait
wiliker is offline   Reply With Quote
Old 10-15-2009, 05:55 PM   #2
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
I installed mine today and it feels like the front of the car is a little higher than the back, I hope thats normal.
Red Horse is offline   Reply With Quote
Old 09-22-2011, 12:42 PM   #3
ocs811
Drives: 2009 yaris HB
Just installed my UR 19mm sway bar, shipping was fast and reasonable to Canada. Thanks Garm for giving us Yaris owner alternatives to TRD.
ocs811 is offline   Reply With Quote
Old 09-15-2009, 07:40 PM   #4
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
yeah send pics I am gonna get a 23mm this weekend
chongopants is offline   Reply With Quote
Old 09-20-2009, 04:40 PM   #5
wiliker
wiliker's Avatar
Sway bar installed today Even more fun to drive.
Old 09-20-2009, 05:56 PM   #6
chongopants
lucky... its my next purchase
Old 10-05-2009, 05:13 PM   #7
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
19 mm sway bar ordered from Garm, installed this weekend. Beautiful piece, perfect fit, easy install, the car handles much better!
Now I'm wondering if I should give up the hitch or the spare wheel and the jack to compensate for the added weight
I'll probably try without the spare for a week and see if I feel any difference
Old 10-15-2009, 07:01 PM   #8
tomato
tomato's Avatar
In what way?
also, bigger bar = stiffer ride? Can you even tell the difference (only 4 mm ?)
I see everybody on the thread says "better handling" "great handling" and other types of positive adjectives but all I get is that they're happy, I still don't understand how the rear bar improves handling in straight lines, with cross-winds. Does it make the car feel like it "sticks" better to the rd or am I looking at the wrong mod? Thanks.
I dread the winter coming, and crosswinds on the bridge
Old 10-15-2009, 09:17 PM   #9
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
In what way?
From my rear sway bar thread:
Originally Posted by Loren View Post
Automotive design and engineering is all about compromises. The general public, especially the "commuter car" market, wants a car that is comfortable and handles predictably. Basically, they want an appliance. A couch that they can drive to work.
For these reasons, cars like the Yaris are designed with fairly soft suspension that handles most road conditions "comfortably" and the car is designed to handle predictably and safely. Predictable and safe handling for the average idiot driver means understeer.
Enter the rear swaybar. A rear swaybar's purpose is to increase rear roll stiffness. Increasing rear roll stiffness has a lot of effects, but the most obvious is a reduction in body roll and an improvement in steering response, which the "performance-minded" driver likes... but the general public might actually prefer the car to be less "twitchy" and prefer a little body roll that allows the suspension to lean in a turn instead of making THEM lean in a turn.
Increasing rear roll stiffness also changes the handling bias of the car and makes it less prone to understeer, or more prone to oversteer. The stiffer the rear of the car is made, the more likely it is to oversteer in an emergency maneuver. Toyota doesn't want the liability of putting the average idiot in a car that could oversteer unexpectedly, so they design their cars to understeer predictably.
Now, if Toyota wanted the rear roll stiffness to be greater on the Yaris... they wouldn't have fit a swaybar to it, anyway. It adds weight, complexity and expense, things that are considered greatly in the design of such a car. Even if they used the TRD/Ultra Racing design (a beam axle reinforcement rather than a true anti-sway bar), it would still add at least 7 parts to the car, one of them being a bar that requires complex forming and welding and heat-treating, the others being a pair of bolts, nuts and washers. (if they put a REAL swaybar on the car, the part count would be at least 3 times as many with brackets, end links, bushings, etc.) No, if Toyota wanted to add more stiffness to the back of the Yaris, they would simply have designed a stiffer beam axle assembly that allowed less twist or they would have fitted stiffer rear springs... either of which would create a compromise to the level of comfort that the car was designed for.
Um... what was the question again?
Old 10-05-2009, 05:23 PM   #10
^ Thanks, glad you like it. Plenty of both sizes in stock at this time.
Old 10-15-2009, 11:24 AM   #11
Cvc9216
Drives: 09
I'm a little confused about the rear sway bar. Granted I haven't done anything to my yaris or even looked at the suspension. But since the rear is a solid beam type and this just bolts to the two sides, wouldn't this be more of a "brace" than a real "sway bar"? Is the rear suspension beam that flexy?
Cvc9216 is offline   Reply With Quote
Old 10-15-2009, 12:56 PM   #12
ddongbap
Yes, it is.
Old 10-15-2009, 01:03 PM   #13
No, it's not merely a brace. Technically it is a torsion bar.
Your beam axle does nothing to transfer weight in cornering -- that's why this bar is effective.
Old 10-15-2009, 01:26 PM   #14
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
The 23mm Ultra Racing bar is noticably stiffer. I have to believe I'll see a difference at the AX.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 10-15-2009, 04:27 PM   #15
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
let us know for those that have a 19mm sway bar.....
Old 10-15-2009, 06:27 PM   #16
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I dont understand what you just said....??
Old 10-15-2009, 06:52 PM   #17
The sway bar does not change the ride height of the car - the part simply can't do that.
Old 10-15-2009, 09:59 PM   #18
YarisSedan
Drives: 08 Yaris Sedan
I think loren is the god when it comes to anything suspention related in the form of questions.
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
