Old 04-22-2009, 02:17 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
[QUOTE=jkuchta;275971]As far as I can tell, the TB is heated to give better fuel economy. Why a cold charge would cause those problems is beyond me.
im assuming the high rev on cold start is due to oil being cool has to warm up ..
Old 04-22-2009, 05:50 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
its due to the open loop during warm up, a preset throttle position untill its warm and then it uses the sensors and activly adjusts it. the opening is 30 percent larger so the preset is automatically that much higher
Old 04-22-2009, 06:02 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by AlexNet0 View Post
its due to the closed loop during warm up, a preset throttle position untill its warm and then it uses the sensors and activly adjusts it. the opening is 30 percent larger so the preset is automatically that much higher
Do you think that will have an impact on engine life and/or MPG in the end? I really like this mod, but I may not keep it if it's doing any damage...
Old 04-22-2009, 06:40 PM   #4
AlexNet0
AlexNet0's Avatar
Originally Posted by camelll View Post
I think you meant open loop during warm up.
lol yup *duh*
Old 03-28-2009, 02:24 AM   #5
jkuchta
Drives: 2007 Yaris hatch (red)
Hey Nexus the TB has been on for 260 miles, and no problems, and the improvement is still there!
jkuchta is offline   Reply With Quote
Old 03-28-2009, 04:21 PM   #6
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Is your TB still heated?
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 03-28-2009, 04:40 PM   #7
AlexNet0
AlexNet0's Avatar
it would make sense around here because it gets very cold (0 or lower) consistantly in the winter, and on the off day it will be cool and very damp. so cool and damp, temp drops, condenses on butterfly flange, engine cools down, butterfly freezes. makes sense to me for this area at least
Old 03-28-2009, 09:59 PM   #8
jkuchta
Saggio, my TB is not heated.
Alex, it would have to be REALLY cold and VERY humid for ice to form in the TB. When a carb freezes up it is caused by the fact that fuel requires energy to vaporize...thus when fuel vaporizes it super cools the air it's in, thus causing the water vapor in the air to turn to ice. Because there is no fuel passing through the TB on our cars, there is no way the air can become supercooled enough to form ice.
The cold weather problems people are running into with unheated TB's may be caused by there being too little heat in a less-than-fully-warmed-up engine to fully vaporize the fuel in the intake port of the cylinder head, causing rough running (caused maybe by the resultant lean condition, or an over-rich ECU compensation).
This is just a theory of mine, and may not be totally correct, but I think its at least a pretty good guess
Old 03-28-2009, 11:43 PM   #9
AlexNet0
AlexNet0's Avatar
yours makes sense, it was just what seemed logical to me
..Because there is no fuel passing through the TB on our cars, there is no way the air can become supercooled enough to form ice.
welllll, maybe I should not bypass anyway, lol, because a future mod planned WILL supercool the intake air
Old 04-09-2009, 01:43 AM   #10
MGargano
Drives: 2009 Yaris Hatchback
Will this: http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories work with the '09 3-door HB? I'm planning to do the DIY listed in this thread, but I want to make sure this is the correct TB first.
MGargano is offline   Reply With Quote
Old 04-09-2009, 01:55 AM   #11
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Yup, that's the one. Great seller too, bought mine from them.
Old 04-09-2009, 10:42 AM   #12
MGargano
Thanks, Gideon. So, if I'm reading this thread correctly, all I need is the 1ZZ-FE TB and the chip from my stock TB? Anything else needed to get everything working? I'm not looking to do the coolant bypass or anything.
Old 04-21-2009, 05:22 PM   #13
MGargano
For those of you who did the coolant bypass, did you plug the tubes on the TB or just leave them open?
Old 04-21-2009, 05:28 PM   #14
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i actually pulled the tubes out with some pliers for a cleaner look and polished it up. so yes they are open.
Old 04-21-2009, 08:14 PM   #15
MGargano
I capped mine. Think that's gonna make any difference?
Old 04-21-2009, 06:38 PM   #16
marcus
toyota
marcus's Avatar
WOULD THIS WORK FOR CANADIAN TB 1.5,...well im assuming it will.i may try this out...
Old 04-21-2009, 06:41 PM   #17
AlexNet0
AlexNet0's Avatar
as long as the stock is a 1nz-fe engine
Old 04-21-2009, 06:47 PM   #18
marcus
toyota
marcus's Avatar
aight..i guess i got a new project to do...
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
