Old 05-21-2009, 01:10 AM   #1
PatrickJohnson
Drives: 2008 Yaris LB
some pics of my install. it's all permanent and looking good!
New wire added:
Came through the firewall at the rubber hose on the passenger floor board
wiring at the switch point
Convenient grounding bolt under passenger kick panel
Finished!
PatrickJohnson is offline   Reply With Quote
Old 05-21-2009, 09:41 AM   #2
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Nice, looking good
My Car Rules!
nickhjort is offline   Reply With Quote
Old 06-02-2009, 11:49 AM   #3
bronsin
bronsin's Avatar
On my computer when you look at the instructions at the beginning of this post, theres a problem. Instead of a picture of the 4 and 2 switch hookup, there are red X's. Can someone post a drawing of the two ways to wire the switches up? Thanks!
Old 06-02-2009, 12:04 PM   #4
The photos are on photobucket, which gets blocked by many corporate proxy servers. PM me your email address and I'll send you the instructions with the pictures.
Old 06-02-2009, 01:14 PM   #5
Pitt Yaris
Drives: Flint Mica Sedan
2008....did you have the icon on your gauge cluster? I looked on mine, but didn't have one. Bummer.
Old 06-03-2009, 10:29 AM   #6
PatrickJohnson
No, the 2008 LB doesn't have the light on the dash. But really, I didn't need it. I may at some point add the other 2 buttons though.
Old 06-04-2009, 11:01 PM   #7
Pitt Yaris
So did you have to do more than ctscott?
Old 06-04-2009, 11:04 PM   #8
Take a look at this thread:
http://www.yarisworld.com/forums/showthread.php?t=16188
It shows what is required to do it with and 07 or 08. Basically, the extra work is running a wire from the switches to an empty pin on the ECM.
Old 06-03-2009, 11:50 AM   #9
regal
If you have an 09 I would just buy an oem stalk from ebay for $30, you really not sving much be using buttons.
Old 06-03-2009, 03:42 PM   #10
There's not a huge savings in using the OEM stalk; To me it was more about not having to pull the steering wheel to install it.
Old 06-03-2009, 02:31 PM   #11
bronsin
bronsin's Avatar
Looking at the switches, EB1900-ND, I see it takes a half inch hole to mount. Id like to do the four switch version. Im thinking this could crowd the hole behind the panel. And it would be difficult to drill 4 half inch holes in the panel that close together. Im thinking of using a smaller switch which takes a .19 inch mounting hole. The eb1900 is rated 3 amp @ 125VAc. The smaller switch is rated .5A @ 125VAC. Will this be enuf? Thanks!
Old 06-03-2009, 03:40 PM   #12
The current draw in negligible, so any switch will work. Fitting four of the ones I used is tricky. I drew it up in CAD and found that I only had a margin of about 1/8" for the four switches to fit through the hole behind the trim piece. One thing I just realized that I didn't check how much that hole can be widened.
Old 06-03-2009, 03:53 PM   #13
bronsin
bronsin's Avatar
The hole can be widened A LOT, maybe half an inch on the radius. The catch is the plastic material is like an inch thick. It would make a huge mess to remove it.
PS the switch Im thinking of using is Digikey EG2021-ND.
Old 06-03-2009, 04:06 PM   #14
The hole can be widened A LOT, maybe half an inch on the radius. The catch is the plastic material is like an inch think. It would make a huge mess to remove it.
That's the nice thing about mounting the switches to that removable trim piece - All of the drilling mess happens on the bench instead of in the car.
Old 06-04-2009, 01:39 PM   #15
bronsin
bronsin's Avatar
Here is my switch install showing the radio shack numbers. Note: I havnt tried this out in the dash to see if my hole position is correct!
Old 06-04-2009, 01:44 PM   #16
Looks close. If you look at the scratched cross and circle on the back of mine you can see the center point of the hole and approximate diameter.
Old 06-04-2009, 01:50 PM   #17
bronsin
bronsin's Avatar
Looks like its possible with these switches that they will fit even if they dont make the hole, judging by the standoffs on the panel itself.
Yeah it fits! The switches are on a 3/4 inch circle. The center of the circle is 1 3/16 inches from the top of the panel (as measured on the outside of the panel) and 1 7/16 inches from the right side of the panel. I cut a 1 1/2 inch circle (the diameter of the cutout in the dash)from a piece of paper and laid out the switches on the paper. Then glued the paper to the panel measureing the center point of the circle from the sides.
Old 06-04-2009, 02:49 PM   #18
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
would this work for any other cars..
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
