Old 10-22-2009, 11:26 AM   #1
DandiDani
DandiDani's Avatar
it looks great. i even helped him. we did get a lil bit of sealant on the outside of the headlight but i think that i could prolly get that off...or itll wear off on its own eventually...it literally took us all day to get this project done but...i think it was prolly worth it. now that we know how to do it we might just have to do mine too...
Old 10-22-2009, 12:17 PM   #2
LEGATO``
LEGATO``'s Avatar
Noiiice!
I'm going to hopefully get mine next month!
Definitely going to need help with that haha.
Did you oven bake your headlights or heat gun?
Project LEGATO
Old 10-22-2009, 12:36 PM   #3
DandiDani
DandiDani's Avatar
we put them in the oven...but we used the heat gun to get some of the old sealant off.it is sooooo much easier if you have two people.
Old 10-22-2009, 01:00 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
why unhook the battery?
Old 10-22-2009, 01:21 PM   #5
that looks great, congrats on a successful install!
Old 10-22-2009, 02:49 PM   #6
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
You all was right the electrical was the easy part
Originally Posted by sw07gt
Old 11-25-2009, 10:27 PM   #7
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Just installed my projector headlights. It was a pain in the ass. The halo's don't even work. Must of blown a fuse.
marlondog is offline   Reply With Quote
Old 11-25-2009, 11:48 PM   #8
JumpmanYaris
USAF_SrA_E-4
I ran my Halo to my Fogs wiring
Old 11-26-2009, 12:29 PM   #9
marlondog
marlondog's Avatar
Does anyone know where the fuse is that powers the day running lights?
Old 11-26-2009, 01:34 PM   #10
JumpmanYaris
USAF_SrA_E-4
Wow its under the steering wheel to the right side if you have small hands you dont have to take anything appart but if you dont then you might have to take a couple of things out
Old 03-16-2010, 03:41 PM   #11
israeldgr
Drives: yaris sedan
Hi
Hi what type of paint used for painting the chrome parts such as headlamps and headlamp illumination is painted as good or bad
israeldgr is offline   Reply With Quote
Old 10-10-2010, 05:36 PM   #12
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
I made my projector 2 days ago and i had 2 or 3 issues :S
My high beam are only working on driver side....
And I don't know what wire to connect my halo to so the parking light are not the orange one but only the halo..
Interior:ALL red, black roof
Old 10-10-2010, 06:23 PM   #13
Did you make sure that your high beam cable is connected on the side that does not work? If it is connected properly, try plugging in a regular H4 bulb (have a friend hold it while wearing rubber gloves just in case the base gets hot) into the socket and try the high beams. If they work, then there is something wrong with the high beam cable. If they don't work, then there's a problem somewhere on the car.
For the the parking light, find the wires that go to the parking lights, snip them (make sure the battery is disconnected), and solder/connect the halo ring wires in place. There might be another, better solution, but that's the one that came to mind first.
Old 10-11-2010, 12:23 AM   #14
packetrace
packetrace's Avatar
for the high beam it's special because the light in the cluster does not come ON when i put the highbeam on!
and last question is there away to adjust the cut off ? because my friend told me my passenger side is lower then my driver side ...well he said that it'S less brighter...so my passenger side has no highbeam and is less brighter then my driver side
Old 10-11-2010, 07:51 AM   #15
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
I can tell u on my that my highbeam will not turn on if my halo ring is not wire correctly hope this help
Old 10-11-2010, 12:39 PM   #16
packetrace
packetrace's Avatar
oh well this i probably what is wrong with my high beam thank you !
Old 10-11-2010, 12:57 PM   #17
packetrace
packetrace's Avatar
are parking light and DRL the same ? (the orange one)
Old 10-11-2010, 10:59 PM   #18
packetrace
packetrace's Avatar
DAMNNNN i didn't knew there was a side right and left...iknew for up and down...but not right and left :O I hipe it's ok :O maybe that's the problem:O where can we see the indication for right or left ? i feel like a noob...well that's what i am !! :P
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-19-2020 11:35 PM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
DIY needed for amplifier for sedan install YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 2 02-27-2009 10:07 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-11-2007 11:02 PM
