#1 |
Apexing Egg!!
what spring rates did you end up running? i am currently running 375 F and 342 R on Tokico HTS's with a 23 mm rear sway bar... curious to hear what you guys run.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Garm your car looks amazing on slicks! You better be going to Import Alliance this year!
Good luck with the tires Jason, i think you guys can pull it off! Also got any updated pics of your progress as of now?
You think your Yaris is low and fitted LOLzzzzz |
#3 |
Ecurie Snoopy Lives
I'm curious to see how this is all going to come through.
10 in wide eh?
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
#4 |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
So Sunday came and went without the Yaris leaving the garage. I did go to AAA Speedway on Sunday to watch last years project car race (Nissan Sentra SER Spec V, that was built for Showroom Stock C for only $3k). My boss (Philip) ran the car in the SSC Natl race, qualified 2nd and finished 2nd - I was very happy to see he was lapping 1 sec slower than I ran in the car last June.
Yesterday we had a "work from home day" so I could nail done the rest of the items to get our car SCCA Club Racing legal. Finally we are log book ready and can start racing the car. Fire system, kill switch, seat, belts, wheel, pedals and preliminary bodywork are done. Philip also came down to "help", instead he built a new exhaust for the Sentra, this only cost me about an hour of my time. ![]() Making the bumpers secure without all of the mounting hardware, and crash beams was a project. The fiberglass headlight replacements seemed to take forever, but they are on - they still need to be finish sanded and painted, they are in primer right now. We have yet to cut the fenders, so we are sitting on some old Kumho V710s, rather than our race slicks. Trying to determine how much to cut when we don't have our suspension yet is a bit of a gamble. But we will probable go ahead and cut them to fit the slicks now, and deal with further fender messaging after our suspension shows up. ![]()
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#5 |
Looking very good man! Aww... my old bumper...
![]() Is that a stock radiator?
#6 |
No, its a Koyo. It came with the car, and we cant see any reason to change it.
#7 |
We just got back from the SCCA natl convention in Vegas.
Had a chance to talk with a number of people involved with the Prod class rules making. Found out we were misinterpreting our wheel allowance... We thought we had to run 15x7 wheels, but it turns out that is the max size for our car in HP. So we are putting off the fender cutting until we have a chance to test fit a 13x7.Going to a 13" changes our tires from a 23" diameter to 20". This will change our effective final drive by a good margin, lowers the car 1.5" without screwing up the geometry, and would drop another 20lbs from the car. Yet we still maintain a 10.4" tire width. I did have some time to kill so I removed my first rear side window. Covered it in some spare vinyl and gave it a good whack with a rubber mallet. That was fun, and way quicker than removing it the correct way. Now I just have to cut and fit the plastic replacement. I have continued trying to convince the SEB/PAC (Solo rules makers) to move the Yaris from EP to GP, as it is way underpowered for EP, but no luck. They want to see how it pans out in HP Club Racing before they risk upsetting GP with a newer car. So we will likely skip autocrossing this car on the natl level, and strictly focus on road racing.
#8 |
I have some V2 13x8 wheels here if you're interested.
#9 |
I might have to send Philip over there to pick one up for a test fit.
#10 |
as you wish!
#11 | |
Lurker supreme!
Drives: old and boosted! Join Date: Nov 2006
Hi Jason,
I recently dug out my copy of Siphon #1, and checked out the article on the Tein Yaris. I thought you might find some of it interesting: Quote:
![]() Take care... and good luck with your build & racing!
2006 Red Blitzed RS 5-door |
#12 | |
![]() Seems odd that they would ditch the useful stuff, then install 12lbs of 0 gauge wire and a 35lb battery.
#13 | |
Lurker supreme!
#14 |
Had a productive weekend... Both of the rear side windows have now been replaced with 1/8" plastic for a nice weight savings. I pulled the headlight covers to add another layer of fiberglass, they are much stiffer now, and I was able to close up some of the gaps around the edges.
Got our fender flares and did a mock up, should give us just enough width to cover the tops of the tires, but with out making the car super wide. Friday we have our log book inspection being done. And Sun we are off to the track for our first test session.
#15 |
what wheels and tires are being used?
#16 |
For our test day we are going to burn up some old 205-50-15 Kumho V710s, mounted on 15x7 Motegi Traklite wheels - these are off of the SportsCar ITA Miata project car.
We have some 15x7 Kosei K1 TS wheels, wrapped in 23-9-15 Goodyear Eagle Sports Car Specials (10.4" wide bias ply cantilever slicks) ready to go, but we are still looking at making the change to 13"s for the gearing advantage.
#17 |
It's always something.
Getting ready to load up for our tech inspection... And the alternator is bad. No I have to try and pick one up on the way to the office. 300 miles on this car and the alternator fails.
#18 |
that sucks a fat one. ive installed tons of "new" junk parts.... starters alternators...etc im enjoying your updates on yalls project
| Hood Stay (lift) Instal | 1NZYaris1 | DIY / Maintenance / Service | 31 | 09-22-2016 07:56 PM |
| The opposite sex can't stay away with ssk | POORSHA | DIY / Maintenance / Service | 20 | 08-19-2009 10:41 AM |
| eTiMaGo Stay safe | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 20 | 12-02-2008 05:31 PM |
| Tuned a DBW Toyota yesterday | Turbo&Auto | Performance Modifications | 17 | 08-17-2007 12:04 AM |
| why am I always here?! wtf...i cant stay away.. | Blenjar | Off-topic / Other Cars / Everything else Discussions | 5 | 02-26-2007 10:51 AM |
