Old 04-15-2010, 11:45 PM   #91
Maitre_Te_Te
Drives: Yaris 08
The bolt is M6 X 1.00 (metric) and the Length is 75mm aprosimative (3 inch)
I search for to find a dealer
Maitre_Te_Te is offline   Reply With Quote
Old 04-17-2010, 12:37 AM   #92
Maitre_Te_Te
Drives: Yaris 08
I have install mine today. I have use the original gasket for intake to spacer, and for spacer to TB just a silicone. Bolt is M6 X 1.00 3 inch . Result, idle fix at 600 RPM and maby a litle diffrent at mid range but at cold start, engine go at 2900rpm.
Old 04-17-2010, 12:47 AM   #93
MGargano
Drives: 2009 Yaris Hatchback
I picked up the M6 x 1.00 x 75 bolts today and will hopefully be tackling this soon
MGargano is offline   Reply With Quote
Old 04-18-2010, 07:28 AM   #94
yarstar
Drives: 2008 Absolute Red HB
Damn. I should have been watching this forum. Is there a way I can still get one of these? Payment can be immediate.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-18-2010, 08:11 AM   #95
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
cruz-gsr is offline   Reply With Quote
Old 04-18-2010, 08:41 AM   #96
Someone post up a picture of the installed piece.
Old 04-19-2010, 05:21 PM   #97
cruz-gsr
cruz-gsr's Avatar
i installed my spacer and TB today, the idle settle at like 6k rpm but my check engine ligth came on and it has not come off, any ideas what did i do wrong. I did unplug the batt for like an hour before i plug it back in.
Old 04-19-2010, 05:32 PM   #98
tk-421
tk-421's Avatar
Drives: 5D-07-LB
A 6K RPM idle is extremely high. Something's definitely wrong there. Not sure what the problem could be, but you may want to unplug the battery for longer to make sure the ECU completely resets itself.
Old 04-19-2010, 05:34 PM   #99
cruz-gsr
cruz-gsr's Avatar
sorry 600 rpm
Old 04-19-2010, 05:51 PM   #100
Yariz
Drives: Yaris 3dr Hatchback
Originally Posted by H3LlIoN View Post
The adapter makes the transition smoother, would will reduce turbulence in your intake. Also, it adds an easy spot for the nos jets, if you are looking at going that way.
I too am curious about the injectors, as my TB came with 1zz coils/injectors/fuel rail too. I new to FI, but methinks you would still need to reprogram ecu to send more fuel. Not sure though, hopefully someone with more experience will pop in for the assist.
Will this give a HP gain, or any sort of response difference?
Yariz is offline   Reply With Quote
Old 04-19-2010, 05:53 PM   #101
cruz-gsr
cruz-gsr's Avatar
im going to dyno my car soon with the spacer and w/out as soon can in school
Old 04-19-2010, 05:55 PM   #102
Yariz
Sweet let me know how it goes, I am gonna try to get one on the next order if I can.
Old 04-19-2010, 07:17 PM   #103
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by cruz-gsr View Post
sorry 600 rpm
600 RPM is within the normal idle (I have ~500 RPM myself with the 1ZZ TB). The CEL should go away after a few trips, but I can't say for sure.
Old 04-19-2010, 08:11 PM   #104
cruz-gsr
cruz-gsr's Avatar
ill wait a couple of days to see if it clears if not ill unplug the batt for like 6 hours
Old 04-19-2010, 10:02 PM   #105
New2tuning
1st mod project at 35
Drives: 2008 Yaris
Is there any way one could get the prints on this part? It doesn't look that hard to make. Even with the o-ring.
New2tuning is offline   Reply With Quote
Old 04-20-2010, 07:10 AM   #106
Maitre_Te_Te
Drives: Yaris 08
do you gave aply silicone between spacer and throttel
Old 04-20-2010, 03:34 PM   #107
captaincrunch
Chris
captaincrunch's Avatar
Question Spacer for 2007 Yaris s 1.5 1nz-fe
Is there a spacer for the 1NZ-FE?
captaincrunch is offline   Reply With Quote
Old 04-20-2010, 05:10 PM   #108
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
Exactly what I was thinking. Will they be making a spacer for those of us that don't have the 1ZZ TB???
redglare45 is offline   Reply With Quote
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 03:59 PM
