Old 10-09-2010, 09:31 AM   #1
sleey0
Drives: 2008 Yaris LB
The Aftermarket Pistons and Rods Thread.....
Ok. Here we can talk about aftermarket pistons and rods and how our learning ECU will handle the lower C:R.
I am making some calls today an will report back what I find.
FEEL FREE TO DISCUSS.....
<And, thank you Garm and Aras>
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-09-2010, 10:13 AM   #2
sleey0
...... reserverd
xbgod - 9/23/2010
Old 10-09-2010, 02:17 PM   #3
sleey0
Just wondering if the ECU woulod re-learn the C:R if it was minimally changed , say like 10:1 iinstead of 10.5:1.
All I want to do is beef up my internals a bit to hit 12psi to 1bar reliably,
I called AEM, CP, and ARIA but all are closed on weekends and will have to wait for answers lol.
I should just yank my cars ECU and send it to CTScott to play with. He could get it in constant open-loop then none of this matters lol.
Thanks for listening,
Wes
xbgod - 9/23/2010
Old 10-09-2010, 03:09 PM   #4
xbgod
Drives: "Burning It Down GTX2860RS XB"
I see this threads been Hi-jacked.....it's missing posts now too.
Instead of worring about all this other nonsense, you could just play it safe, since this is your DAILY DRIVER and put a reliable kit on have some fun and then play with the big dogs when you can afford to not have it be a daily driver.
All your threads are running wild with no end results. Look no one cares anymore. you are the only one responding to your own threads.
I give up, I quite, I resigne.....I'm throwing in the towel.....I'm ringing the bell.
XBG
xbgod is offline   Reply With Quote
Old 10-10-2010, 12:27 PM   #5
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Wes
I think the main issue related with the stock ecu isn't the pistons or rods but the turbo setup itself.
Let me explain:
- Pistons with lower compression mean that they differ in height (by few mm) versus others with more compression. Now if you change the pistons to a lower compression, you might be aware that the less compression means a bigger combustion chamber since the piston is effectively going up the same height. The bigger the chamber, the more the engine needs air and fuel to make a good bang.
-If you remain with the stock ecu, the ecu doesn't know that the engine needs more air and fuel to make a good mixture in the chamber which will result in startup, knocking and engine dying issues since the ecu is giving the same amount of fuel as if you are still at 10.5:1.
-Regarding the turbo setup, I am one of the guys that don't vote to remain with stock ecu because of the much issues with turbo systems. I don't mean it can't be done but will probably cost you more money and patience to have good results.
As xbg said you should check other threads and you will surely find your answers.
Old 10-10-2010, 12:54 PM   #6
sleey0
Let me explain:
Thanks for the info!!! Really good stuff.
And XBG, the learning-ECU issue when changing pistons and lowering C:R was from Garm.
MODS if XBGod is right, and all pieces of info about rods, pistons, the ecu, and ways around it (that are being tried), and C:R are already in another thread.
THEN PLEASE CLOSE OR MERGE!!!!
Thanks.
xbgod - 9/23/2010
Old 10-10-2010, 06:15 PM   #7
sleey0
Let me explain:
Garm is the 1 that told me changing the ratio will mess up the stock ecu n then you would need stand alone.
If we could lower the ratio and use a piggy back that would work perfect for my situation.
But no 1 has figured out the closed loop situation. C t scott said he was gonna look at it, but IDK.
xbgod - 9/23/2010
Old 10-09-2010, 04:25 PM   #8
sleey0
Thanks.for.that i guess.
I just want learn and.help the community.
Just because i havent.started.yet doesn't mean i cant gain some knowledge.
I.am.doing.like u told me to.
Aras, one minuteu tell me.to call arias and.aem and now you.are.telling me my threads are.worthless.
I.dont.get u sometimes bro.
Why be nice.too me in emails and.then put me down in my own hreads?
Instead, share your knowledge here and help.
Confusing.as.sbit.
Help me or.dont. i thought you were helping and.then.tbis?
You have a split personality bro....
xbgod - 9/23/2010
Old 10-10-2010, 11:28 PM   #9
sleey0
PLEASE for now-foward if you don't have anything to contribute NICELY then just move along.
I don't need this. This will be my fist Boosted project and I want help and opnion, NOT mockery and foolishness.
Why is it only my thread that gets all trashed? I am basically trying to do what Focus_Shift is doing just MAYBE a little different.
Is there a sleey0 hate club around here? What did I ever do bu show my excitement and ask a lot of questions?
If that is all I am guilty of then these boards shouldn't exist.
Yes, I am a month or two away from getting everything I need to proceed, but that doesn't mean we can't share info NICELY and in an APPROPRIATE manner.
Thanks for those that are helping me, BTW.
Wes
xbgod - 9/23/2010
Old 10-11-2010, 01:57 AM   #10
xbgod
Well, it's good to see all of your stuff on one thread now. At least now when your asking a question we know it's souly for your build. No more crazy other threads to keep going back and fourth too. I think you will find this a much easier way to have all your questions answered.
The only reason you were getting so much crap is because it was all over the place and alot of this stuff was answered in other peoples turbo projects. At least now it's under control and should move forward.
Talk at you guys next week.
XBG
Old 10-11-2010, 03:37 AM   #11
Parmas
Parmas's Avatar
Wes
Dear Wes I know this project isn't an easy one and will probably cost you a lot of hassle so I understand that you are nervous about this but you need to focus on what you read. During the time doing my turbo project, 2years ago btw, I wrote many good information related to my build in order not to mislead anything.
During the time I was making mine, the only help I could find was Garm since he was the only one I knew about doing the custom turbo setup.
Saying this, if you re-read the quote here you will understand that many of your answers are in other threads since you are not alone here.
In the case you have a different question or an update on your build than you post here.
Regards
Old 10-11-2010, 08:27 AM   #12
sleey0
Ok got it.
I will search my ass off!
The only problem is I have only 1 thread to really help me because of the same xage kit I will use focu_shift.
I will read your thread again but wasn't yours custom built?
Thanks, Parmas!
xbgod - 9/23/2010
Old 10-11-2010, 08:59 AM   #13
sleey0
I need to know QUICKLY if the tC injectors (2az) will work with the 1NZ.
I came across a set for $100 and want to jump on it but don't know if they will work with the 1NZ.
xbgod - 9/23/2010
Old 10-11-2010, 10:25 AM   #14
sleey0
And I have come up with nothing yet.
Trust me I posted that out of frustration because nothing is coming up. Even at scionlife.
xbgod - 9/23/2010
Old 10-11-2010, 12:33 PM   #15
sleey0
Talked to Elmer @ Arias today. He isn't sure if the piggyback solution will work with a 9.5:1 CR. He did say that a 10:1 might not have any issues but not 100% certain.
He tried to help but his accent was very hard to understand, He referred me to TOYSport in Cali and they were less helpful.
The search for info continues!!!!
I think I will wait and see if focus or ct can figure out the closed loop workaround as I have time before I start my build.
And I might hook up with Focus when I am ready for my build. w00t!!!! Cool guy that Focus_Shift!! :D
xbgod - 9/23/2010
Old 10-11-2010, 12:44 PM   #16
That IS the info. LOL
Old 10-11-2010, 01:57 PM   #17
sleey0
I knowed u said. it wouldn't work but what about a 10 to 1 compression ratio?
I am just going to wait it out and see what ctscott comes up with the closed/open loop situation.
xbgod - 9/23/2010
Old 10-11-2010, 02:00 PM   #18
sleey0
And elmer from areas pistons wasn't sure if the piggy back woul work so we do not have current confirmation yet about needing a stand alone. It's not that I don't believe you garm its just that i am double checking all my sources.
The more we know the better off the community will be, right?
Still need to speak with aem and crower.
xbgod - 9/23/2010
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
