Old 08-09-2016, 08:47 PM   #1
bassmannate
Drives: 2008 Toyota Yaris
That is fine. There is about 30 ohms of tolerance for each of the switch modes.
Was the ECM pin a genuine one that seated properly in the ECM connector?
Pretty sure it seated properly. It felt like it clicked in there. I'll try to pull it out again tomorrow morning and make sure it seats correctly. I would think if that were the issue the rest of the functions wouldn't work right.
Sent from my LG-H811 using Tapatalk
bassmannate is offline   Reply With Quote
Old 08-09-2016, 09:11 PM   #2
The other one will only work after on/off works, so unless you can watch the cruise control input on a Toyota Techstream tool, you really can't tell if the other functions are working when on/off is now.
Old 08-09-2016, 09:14 PM   #3
bassmannate
Right but after i get it on, everything works great. I used it from Chicago to St. Louis and back this past weekend to keep pace with traffic.
Old 08-09-2016, 10:00 PM   #4
bassmannate
Well, I think I figured out what the problem is. I went ahead and pulled the ECM plug back out and checked it out. On closer inspection, the wire that came with the kit does not have the little rubber piece that goes directly behind the pin. This piece not only looks like it seals out moisture, but also locks the pin more securely than the pin lock mechanism does on it's own.
This would explain why it worked flawlessly right after I finished the install because the pin had just been seated. Add on top of that that I didn't have any zip ties for a couple days to re-secure the ECM wires and it was a recipe for that pin to vibrate out slightly.
Anyone know what that piece is called? If I can get a picture, I'll post it to show what I'm talking about. Where would I find these?
Edit: I found a picture. It's the blue piece right behind the pin on the yellow wire.
Old 03-03-2017, 07:44 PM   #5
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I was looking at this pdf. Looking at the picture of the cruise stalk on page 2, does anyone know if that one wire with the brown connector is actually used?
33.7 mpg in PA
bad is offline   Reply With Quote
Old 05-09-2017, 12:57 PM   #6
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Thank you for that very well documented step by step video. I'm sure it will help out others in the future.
Old 06-04-2017, 09:02 PM   #7
scratchpaddy
Hubcap Enthusiast
scratchpaddy's Avatar
Drives: '09 3-door 5-speed
They are M5 screws. Any hardware store will have them. The shortest ones you can find should do fine.
scratchpaddy is offline   Reply With Quote
Old 08-31-2017, 08:37 PM   #8
nikonNUT
Drives: 2010 3 Door L
Just finished my install. Why didn't I do this sooner?!? Thanks for the parts and the great tutorial Scott!
P.S. I didn't order the rear cruise rear boss. I just used this to drill the hole....
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Worked a treat and no pulling the steering wheel!
"Sanity? What would I do with something as useless as that?”
nikonNUT is offline   Reply With Quote
Old 09-04-2017, 06:55 PM   #9
n3szt0r
Drives: Auris 2009
Dear Toyota friends!
I would get some confirmation about cruise control. My Dad's birthday gift would be a cruise. He has a 2008 Auris 1.33 petrol europe(uk) engine code 1nr-fe.
Did see one of supported yaris has the same engine.
Will it fit?
Can you give me name of small metal connectors or a source for them?
Please help, thank you!
n3szt0r is offline   Reply With Quote
Old 09-10-2017, 01:52 PM   #10
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
Just finished mine this morning. The hardest parts were running the wiring and making ghetto pins. lol
The Gibbs Garage
2016 Lexus GS350 f-sport (my main car)
2013 Lexus RX350 (wife's vehicle)
2010 Toyota Tacoma (my second vehicle)
GibbsYaris07 is offline   Reply With Quote
Old 11-23-2017, 08:31 AM   #11
Freedomage
Freedomage's Avatar
Drives: YARIS 2010 1NR-FE MMT
Hi I couldnt find any introduction page so My name is Alper and from Turkey.
I have a Yaris 1.33 1NR-FE Multi Mod transmission I checked my VINN number and it says that my car's market: North America, Europe(UK) by the way it is made in France.
TYPE: NSP90L-CHLGKW
I was wondering if my car's ECU has built in CC functionality.
Is there anything I can do to figure out this?
Freedomage is offline   Reply With Quote
Old 11-26-2018, 05:38 PM   #12
tiiams
Drives: 2007 Yaris sedan S Pearl Black
Mine has been working great for 7 years or so i forgot when I bought it. Thanks scott only issue is blue light gets confused in cold weather. but functionality is perfect. By the way I am at 238,000 mile approx.
tiiams is offline   Reply With Quote
Old 05-08-2020, 04:52 PM   #13
Mykal
Drives: 2008 Yaris, auto
Cruise Control for 2008 Yaris 3 door auto
Hi Scott, I purchased the OEM cruise control stalk for the Yaris, but am still in search of the rest of the parts. Do you have those in inventory? - Mykal
Mykal is offline   Reply With Quote
Old 07-08-2020, 09:06 PM   #14
Sumdude
Drives: 2010 Toyota Yaris LB
Cruise COntrol Parts
Hi Scott,
I am new to your forum and also a new Yaris owner. I have just purchased a used 2010 Yaris LB with out Cruise Control. I have been reading some forum posts and I would like to know if you sell the complete CC kit and if so, how do I order it?
Thanks for your assistance,
Sumdude
Sumdude is offline   Reply With Quote
Old 07-12-2020, 10:19 PM   #15
reg_account
Drives: 2010 sedan
2010 sedan A/T without power anything
Hi all,
I just wanted to post my experience with this version of the car if anyone is interested. I have a 2010 US Sedan auto transmission with no power windows/locks, but with AC. I found a couple of interesting differences with my car that I couldn't figure out from the pdf, so I thought I would share. Big thanks to CTScott for the guide!
I was able to get the stalk from a junkyard Camry (04-09 I think, according to the other thread). I pulled off the extra wiring from the Camry and was able to pull the pins out from the larger Camry connector, which I was able to fit into the smaller connector (with the horn wire, section 1.4.3 in pdf) from the Yaris. Cost about 10 dollars for the stalk locally. If you do need to pull those wires from the Camry connector, you have to pull really hard (I thought I was going to break it) but it will disconnect if you have the lock popped up. One last thing about the stalk, I only had a 1 inch circular drill bit (Spade bit? the flat kind..) but it worked out fine. I highly recommend cutting the hole in the plastic, it is quick and easier than pulling the steering wheel.
Next, I found that the ECM pin already had a wire in it (it says this in the guide) so I was able to use a tap splice to connect to this. I precut the wires with a wire stripper to expose the wire to the splice (wasn't sure if it would cut the insulation fully). Firewall install wasn't too bad, as I was also installing a car amp wire. However, I think my grommet was in backwards, since I had to flip it around behind the carpet to pull it out.
The last thing I found was that I did not have any D3 connector pins. I found an ebay seller who makes the same wire and sells them for cheap (8 bucks shipped for 2 pins). I used some wire from the remote turn on from my amp kit (18 gauge) to connect the ECM tap splice to these D3 connectors. Make sure the pin lock snaps in easily with a nice click and you are good. I was able to see the indicator on the dash after connecting the battery and holding the ground wire to metal. Took it for a test drive today and it worked like a charm!
Quick summary:
2010 Yaris sedan, AT, no power windows or locks
Need to buy:
Stalk and wiring to horn pin (Need T30 bit to get into wheel)
D3 connectors
18 gauge wire or similar small gauge wire
Tap splice that fits your wire gauge
Butt connectors or crimp caps (I used Install Bay CC2218 since I had them)
You need a few other basic tools from the pdf, so read over it to get the gist. Thank you to all who posted on these forums about this so I could install a cruise control in my car for $21!
reg_account is offline   Reply With Quote
Old 10-26-2020, 06:53 PM   #16
c-dub
Drives: 2008 yaris
Is there a wired connector for the clutch switch (88280-14030)?
c-dub is offline   Reply With Quote
Old 10-27-2020, 12:53 PM   #17
bassmannate
Mine has been working fine for 5 years so far. Wish I had the indicator but I get along pretty well without it.
Old 10-31-2020, 05:11 PM   #18
c-dub
Drives: 2008 yaris
Got it installed today, took me about 5 hours, but soldered and heat shrank everything and made a harness. Found a radio harness from a 2020 4Runner (extra parts from a Alpine sub install) that had a female connector that i was able to modify for the clutch switch. Very easy install, just needed to adjust the clutch switch after the test drive. Only thing i'm not happy with is the connections in the fuse box. I need to figure out how to pull the pins, so i can get some heat shrink on them. I'm sure the tape would be fine, being enclosed and all, but it bothers me.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
