Old 05-21-2012, 05:28 AM   #1
syntax
syntax's Avatar
cge try ko hanapin ang specs nun, sa pictures pareho lang nung nasa ibang kayaris, mag iiba yung sayo dahil echo yan..
Old 05-21-2012, 09:52 AM   #2
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
Thanks in advance sa specs at sa photo. Yung photo baka pwede yung medyo malapit from engine up to filter kasama yung mga joints, pano kinabit yung MAF sensor at yung isang pipe from Engine na maliit.
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 05-22-2012, 05:09 AM   #3
BoyMalambing
@ Syntax, nakita ko na yung para sa Toyota Xa 2004 Scion na pwede gamitin sa Echo 2005. Same layout as you said. Papagawa na lang ako sa contractor namin ng Stainless steel pipe. Papagaya ko ito
http://www.trdparts4u.com/scripts/pr...dproduct=-7862
http://www.carid.com/2004-scion-xa-a...ke-360128.html
Old 05-22-2012, 09:26 AM   #4
syntax
syntax's Avatar
ayus yan pre' para sakin wag steel pre' kung pwede ang aluminum mas maganda
Old 05-23-2012, 02:39 AM   #5
BoyMalambing
Ay oo nga pla Aluminum... plan ko sana para mag ok, yung Rubber Tubing na misma nakakabit sa Intake tanggalin ko lang box tapos gamit ng mga clip(yun ba tawag doon)
Old 05-23-2012, 03:41 AM   #6
syntax
syntax's Avatar
yup.. ganun nga pre' basta kung ano ung nakakabit dapat sa OEM na intake meron din sa custom intake na gagawin mo...
Old 05-23-2012, 03:51 AM   #7
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
+100 hehehe, musta tol...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 05-23-2012, 04:04 AM   #8
syntax
syntax's Avatar
@ duke ok naman pre' dami lang ginagawa dahil lam mo na..hehehehe, kaw pre musta na?
Old 05-23-2012, 04:23 AM   #9
BoyMalambing
Try ko maghanap muna ng Air Filter... saan ba nakakabili nito...
Old 05-23-2012, 04:30 AM   #10
duke_afterdeath
ok lang tol kaso nga lang zero balance, hehehe...
d2 sa Riyadh tol madami nyan branded at generic nagkalat, hehehe...
Old 05-23-2012, 04:28 AM   #11
syntax
syntax's Avatar
check mo sa ghurabi area pre' dun sa al aqsa, malapit ito sa alrajhi atm na malapit sa jollibee, sa kabilang side andun ung al aqsa, hanapin mo si roy, alam na nya kapag yarisworld member
Old 05-23-2012, 04:32 AM   #12
syntax
syntax's Avatar
@ duke buti nga ikaw zero balance.. ako negative pa nga eh wahhhhh...
Old 05-23-2012, 04:41 AM   #13
duke_afterdeath
Old 06-19-2012, 08:55 AM   #14
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
isa Zero balance, isa negative......buti pa kayo may balance na tinitignan.....ha ha ha
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 06-19-2012, 12:04 PM   #15
duke_afterdeath
Old 06-19-2012, 01:05 PM   #16
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
Pa humble pa ire.... hindi ka naman kasi nag che-check charlie, diba yung ginagastos mo ngayon sahod mo pa nung year 2010? Ni hindi pa nga nagagalaw yung sahod mo nung 2011, nadadag-dagan pa 2012 na! just imagine mga tol....
jonimac is offline   Reply With Quote
Old 06-19-2012, 01:23 PM   #17
duke_afterdeath
ayan pala ang sponsor
Old 06-19-2012, 05:36 PM   #18
charlieXX
Corporate Slave
charlieXX's Avatar
@Joni how I wish tol, magdilang anghel ka tol at magpapa kanton ako he he he
Any Aftermarket Intakes Yet?!?!?!?! silverRS Performance Modifications 120 12-07-2011 06:44 PM
Weapon-r sheet metal intakes 1/2 off (almost) H3LlIoN Forced Induction Forum 5 11-27-2010 12:21 AM
aFe intakes in stock! cali yaris Micro Image 66 02-11-2010 04:58 PM
air intakes? SLIK4 General Yaris / Vitz Discussion 16 05-21-2007 09:34 PM
