#91 | |
Hi Fred, Sedans did not get an update in 2012 as liftbacks did, so for your daughter's car the my 2009-2011 directions are the ones you will follow.
#92 |
The pin that goes into the spring clips has a groove in it that the spring clip latches onto, so you are trying to open the legs on the clip to release it from the groove.
#93 |
![]() Drives: 13 yaris Join Date: Oct 2013
How do you do, it is called takumu. It has ridden on Japanese use of 12 models. There is no cruise control in vitz of Japanese use, and I am troubled by it. It did not operate, even if it post-installed the cruise control switch. If it investigates, there is no wiring of a spiral cable to the point. Who has a wiring diagram of the cruise control of yaris of 12 models? Or please let me know wiring to a computer. Thank you for your consideration.
#94 | |
On the ones that do have it, Pin 60 of ECM connector A72 is where one wire of the stalk connects to and the other wire connects to chassis ground.
#95 |
Mr. CTScott, thank you. My car is 1 KR-FE engine. Somehow, the form of the connector of A70 was different. It was connector-shaped [ of the same engine computer as yaris(es) from 2006 to 2011 ]. The wiring which is already different is stuck in the wiring place of the cruise control of 2011 models. It was troubled.
#96 | |
My kits are still for sale and for 3rd gens I also stock the little cover for the side of the steering wheel, so no drilling is even required.
#97 | |
The page 7 info is completely wrong for a 2012. The 2012+ are all prewired. The only thing that would have to be done is to install and plug in (connector is present) the clutch switch for a manual transmission Yaris. So, for 2012+ just install the stalk and you're done for an auto. For a manual, also install the clutch switch. All wiring is present, so it is just a matter of plugging them in.
#98 |
![]() Drives: Yaris 2013 1.33 CVT Join Date: Feb 2013
Hi All,
Fitted the Scott's CC kit on Yaris 2013, 1.33 1nr-fe CVT. Touch 'n Go head unit didn't ask for security code after the battery disconnect, also all settings were not reset (radio, BT, sound settings). To get out the airbag from the wheel with side gear switches - is real pain, took me like 40 min. CC works like a charm :), the plastic cover panel didn't fit though, waiting for Scott to figure that out. Update: Scott emailed me the partnumber of the cover panel and I got it from the local dealer for $10 with taxes (btw Scott had refunded me the wrong part cost at the moment I've reported it) Last edited by dobrik; 11-03-2013 at 03:39 AM. Reason: Update |
#99 |
![]() Drives: Yaris 2013 Join Date: Nov 2013
Does anyone know if this will work on my 2013 1.4 d4d ?
Thanks |
#100 |
No. Unfortunately only the 1.33L European Yaris supports cruise control.
#101 |
Is there any kit that you know about that does ?
#102 |
I have seen a couple of aftermarket kits listed on European websites (I posted a link in one of the threads on here). Those kits sell for $400 to $600 US from what I have seen.
#103 |
I do not believe that the 1.0L supports cruise. Only the 1.33L wiring diagrams indicate that cruise control is available on it.
#104 |
![]() Drives: 2013 Yaris HB Join Date: Dec 2013
Just a quick post to thank Scott, just installed the cruise control on my 2013 3 door. This is my second Yaris first was a 2007 that got totaled in 2012 with 245000 miles on it. The install was quick and easy like 20 minutes. The hardest part was being careful releasing the 3 pins that hold the (horn airbag assembly), don't force it just press it with light force you will see the assembly unlock and you will hear it. Works great and the cover was worth the extra $5, makes it look nice and clean, just like OEM at 1/8 the cost.
Mods so far with 2003 miles on it performed in this order, TRD sway bar, Tanabe Medallion axle back, and of course cruise control. Next lightweight belt pulley, then AFE intake. |
#105 |
Drives: Yaris 2012 3 door SR Join Date: Feb 2014
Hi.. First post.... I have a 3 door 2012 European SR model Yaris with the four steering wheel buttons.... Looking to fit cruise control... Scott do you supply kits for this car? I was told when we bought the car CC was not an option....
Thanks Dave B |
#106 | |
Shipping to the UK is no problem.
#107 |
![]() Drives: Hybride Join Date: Mar 2014
Hello new here / anybody know if it possible to install Cruise Control to a Yaris 2012 hybrid XP13M(A) from Europé.
#108 |
![]() Drives: Yaris 2012 Join Date: Feb 2013
Ask CTScott, but I think that is possible, because in our country the hibrid can have CC in stock new car. You have 1.5l engine?
| Tags |
| cruise control. 2012 |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
