Old 04-30-2013, 06:13 PM   #91
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
So far with test driving it, I've only taking it up and down my street and side streets, no highway speeds. I have hit full boost (8psi) tho.
I'll do a quick run down of the few CELs I've gotten so far. First start up to now:
CELs 1-4 were spark plug related (b/c i changed mine out)
The next couple were AFR/O2 sensor related
And the most recent was a "too lean" code
The only really serious one was the too lean one, that was before i received the tunes from Garm. This code went away on its own after uploading the tune file i have on it now. (the lean tune)
yariSB86 is offline   Reply With Quote
Old 04-30-2013, 06:15 PM   #92
yariSB86
yariSB86's Avatar
@kou The screw cap thing on the end of the BOV was loose. I hand tightened it and started up the car to a good idle. So maybe that was it combined with the tune file i have on the fic right now.
Old 04-30-2013, 06:19 PM   #93
yariSB86
yariSB86's Avatar
@Tolmach I removed my oil pan and drilled from inside out. With an angled drill and that unibit i was able to but not fully get level, i was close enough. The bulkhead fitting along with the gasket type washers and the bulkhead nut, everything is pretty secure. Only oil residue i can see is coming from my oil drain plug, which ive tightened since finding it.
Old 04-30-2013, 06:29 PM   #94
yariSB86
yariSB86's Avatar
Not a problem M8
Old 04-30-2013, 06:30 PM   #95
kou
Drives: 08 lb
Glad its working out. Now we need pictures.
Old 04-30-2013, 06:37 PM   #96
yariSB86
yariSB86's Avatar
Ask and you shall receive :)
Old 04-30-2013, 06:55 PM   #97
yariSB86
yariSB86's Avatar
I do plan on heat wrapping, there is a DEI just up the street.
The stock O2 sensor wire isnt stressed at all, infact i have it hanging with a zip tie to keep it off the exhaust manifold.
That steel braided hose is the oil in line. It is coming from my oil filter sandwich adapter.
Old 04-30-2013, 07:05 PM   #98
yariSB86
yariSB86's Avatar
would this work in a 2.25" custom pipe?
http://www.mandrelbendingsolutions.c...High%2C/Detail
Old 04-30-2013, 09:59 PM   #99
yariSB86
yariSB86's Avatar
Whats this knob on the end of the BOV for? What is its function? I can screw it/unscrew it.
Edit: so that's the actuator control housing knob?
Old 05-01-2013, 04:50 PM   #100
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Wow...I really forgot how much it looks wide open front top to down on the backside when you are running an internal WG. I would get the heat wrap ASAP. Makes a big difference both performance and safety wise.
Old 05-01-2013, 07:09 PM   #101
yariSB86
yariSB86's Avatar
Yeahs, thanks man. I'm picking some up Friday.
Think I got car to run pretty good. Still having issues with it stalling after lifting off throttle after a load. It's like when I lift off the rpms should go to 950-1100 like they do at idle but they keep falling until stall. My buddy was thinking adjusting the throttle position or changing the VE table. Any suggestions?
Old 05-02-2013, 11:15 AM   #102
kou
Drives: 08 lb
^^ my suggestion is you check that blow off valve and make sure its closing.
Old 05-02-2013, 11:26 AM   #103
yariSB86
yariSB86's Avatar
@kou - am i correct in thinking that if the BOV needs to be adjusted, it is done by removing that screw cap on the end?
Old 05-02-2013, 11:28 AM   #104
Focus_Sh1ft
Focus_Sh1ft's Avatar
^ Yes. I actually had to loosen mine to get it working better, but try tightening it and see if that solves any of your problems.
Old 05-02-2013, 11:29 AM   #105
yariSB86
yariSB86's Avatar
Thanks guys, ill give it a shot.
Old 05-02-2013, 08:57 PM   #106
yariSB86
yariSB86's Avatar
Update: As mentioned earlier I checked my BOV, I checked the spring and messed with it a bit, I didn't really change anything. I hooked it up to a cummins radiator cap pressure tester. it actually worked well. I plan on upgraded the BOV later down the line anyway.
I decided to start a fresh tune to see if I can get it to idle like stock. think I got pretty close. I don't know why my rpms are still kinda surging, not nearly as much as before but they do like 250ish. you'll see in the videos im about to post. with this tune I test drove it down the street (not included in the video) and I had a bunch of misfires. My buddy sitting next to me with my computer hooked up the the fic was able to retard the timing live and we fixed all misfires. over all im pretty happy that I got it running well. I'm still going to get it professionally tuned here next week. it will be interesting to see what happens and what the dyno reads :)
so with out further a due.
Before I leaned it out:
https://www.youtube.com/watch?v=EETj1jC8MIA
After I leaned it:
https://www.youtube.com/watch?v=SDIYLWHa3pk
Little bit o boost:
https://www.youtube.com/watch?v=70fq_fzEbZc
Old 05-05-2013, 12:09 PM   #107
yariSB86
yariSB86's Avatar
so the local temp got warmer than when I originally tuned. so im misfiring and stalling again. time to adjust the maf map and retard some timing I think.
Old 05-23-2013, 08:46 AM   #108
yariSB86
yariSB86's Avatar
Update time:
I have an 08 ecu en route to replace my old 07.
I had a custom exhaust made. I'll show video of my old setup, then of the new.
Old setup
New setup
_______________________________________________
List of Boosted Yarisworld Members - Redux CTScott Forced Induction Forum 40 06-29-2025 08:42 PM
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
