#1 |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
790rpm and up you'll get a code for high idle. I got mine at about 600rpm on idle, been over a year and zero issues. I'll finally have time to mod a 1zz aluminum intake and have everything match properly. Just the 1ZZ TB alone you still don't get the full benefit.
#2 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I wonder if I could do the same for a plastic intake manifold from an '03+ corolla...
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#3 |
Bolt holes to the head don't match but the ports do 100%. I'm cutting off the existing mounting plate, machining a new one to fit, tig weld the port it. The other end is a 3 stud mount for the TB, cutting that off too, machine, weld, port and voila. I don't know the exact year but looks like a celica intake.
#4 |
Pumpman
^^^ +1 for custom manifold!
#5 |
ThatYarisGuy
Drives: Toyota Yaris 2012 SE Join Date: Oct 2012
so all I have to do is install the new throttle body, then either loosen up or tighten the idle screw?
#6 |
![]() ![]() Drives: Yaris '05 1.3 Hatch "R.I.P." Join Date: Aug 2014
Yes. Install it, make sure the gasket is sealing properly and just loosen the idle screw to reduce the idle RPM's and tighten to increase. Make sure to chip away the resin on that screw before installation :)
#7 |
ThatYarisGuy
do I use A toothpick or a screwdriver to take it out?
#8 |
It's quite hard. I used a small flat-headed screwdriver and a hammer to tap at the resin "carefully" and to dig in it. Make sure to get it all off so the screw doesn't strip when you try to adjust it.
Maybe someone else knows a safer or easier way?? :P And remember it is a Allen Key screw. It was quite difficult to source the correct one here where I live but everything is difficult to find over here :P |
#9 |
ThatYarisGuy
Thanks for the specific info medmantle👌 btw im using a CAI so do i need a specific intake hose adapter thingy like this one or could i uss the one that originally came with CAI?
#10 |
![]() ![]() Drives: 12 LE 5d HB 1nz-fe Automatic Join Date: Oct 2014
I was able to use the one that came with my CAI just took a little bit of finesse. Just rounded the inside edge a bit then little bit of oil and it slide on
Sent from my SM-G386T using Tapatalk |
#11 |
I still have the stock intake. Like 'scod' said, just give it all you've got! :P I had to turn my stock intake pipe around to get it to fit and it was still quite tight and difficult to get over, but I eventually got it. I would have loved to be able to use a adapter like that but we have almost no aftermarket car stuff where I live. :)
#12 | |
#13 | |
In the future I'm gonna look at doing an engine swap to the 1.5 (yes, I am driving the 2NZ-FE ) and once I have the engine I'm gonna do a bit of work on it like porting and stuff regardless of the gains, mainly for fun though 'cause I'm still learning. I'm happy to hear there are still potencial gains to come :DThis forum was my first introduction to how cars work so my Yaris is kinda my guinea-pig :P |
#14 | |
#15 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Bolt-on options are pretty few and far between: golden eagle, MicroImage, and possibly Weapon-R. The Corolla manifold requires a custom TB adapter and machining a flange for the engine block. Tooter made a short run of them a few years back, and is no longer making them. If you want to go that route, I've posted a PDF of the flange dimensions in another thread.
#16 |
Pumpman
I'd actually be interested in going that route. It would be a cool project to take on. Which thread did you post the flange dimentions in?
#17 |
I'm running a long runner golden eagle intake manifold that I got from micro image (may see if he can still get one for you) but have seen short runners from Golden Eagle and if you're looking at the TB i think some people run the corolla intake manifold but you have to modify it but from what I've seen looks like it would work better as its a smoother transition
#18 |
ThatYarisGuy
Is it useless to have a 1zz tb on stock intake manifold then?
| TPS reading at WOT with 1ZZ throttle body? | 4/20 NEVER FORGET | Performance Modifications | 14 | 07-02-2023 04:20 AM |
| Installed the 1zz throttle body - | AlexNet0 | DIY / Maintenance / Service | 135 | 08-01-2014 07:57 AM |
| FS: 1ZZ throttle body and Fujita intake | mrbond | Items for Sale by private party | 25 | 09-08-2009 10:21 PM |
| Intake to match the 1ZZ throttle body | fuji | DIY / Maintenance / Service | 2 | 06-17-2009 10:02 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
