Old 04-05-2007, 08:06 PM   #91
Black Yaris
der Zeck
Black Yaris's Avatar
here is Chino's last car
Black Yaris is offline
Old 04-05-2007, 08:14 PM   #92
lol...that Bug's ass is on fire!
Kaotic Lazagna is offline
Old 04-05-2007, 08:17 PM   #93
Black Yaris
der Zeck
http://www.ronpatrickstuff.com/
ya'll gotta check the site it got this from out
Old 04-05-2007, 08:27 PM   #94
DAMN!
Old 04-05-2007, 08:35 PM   #95
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
that site is great!
Go4th is offline
Old 04-05-2007, 09:57 PM   #96
Black Yaris
der Zeck
who will be the first to have a jet propelled Yaris? Anyone live near that guy?
Old 04-05-2007, 10:04 PM   #97
Edd
Drives: None
What the **** is up with people saying it is dangerous to go higher with octane? The manual gives you the LOWEST octane rating the car will run on. The higher the number, the better. There is no damage from going to a higher octane level - you are just putting in purer fuel.
Edd is offline
Old 04-05-2007, 10:07 PM   #98
Black Yaris
der Zeck
wrong- higher octane has more additives
Old 04-05-2007, 11:26 PM   #99
BailOut
Steals terrorist's lunch
BailOut's Avatar
Octane is not a measurement of caloric content or burn-ability (cetane). It is a measurement of how high a temperature is needed in order to ignite the fuel. This is why premium fuel is usually only required on high performance engines (because they run at higher compression levels which generates more heat).
Higher octane fuel is actually less pure because of the extra additives which are used to make the fuel ignite at a higher temperature. These additives are also why it costs more.
Running fuel of an octane higher than what your engine is designed for can help with knock (detonation) but that is generally where the benefits stop. The detriments are:
- Fouled spark plugs due to the deposits left via incomplete burning.
- Greatly increased emissions due to incomplete burning.
- Fouled O2 sensors due to these emissions.
- Fouled catalytic converter due to these emissions.
Stick to what your engine is rated for. The 1NZ-FE engine in the Yaris is designed for 87 octane gasoline.
- Brian
Share the Road
BailOut is offline
Old 04-05-2007, 11:45 PM   #100
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Little bit of the subject but that is why all the early RX7's should run the least octane in the Wankel...slow burn and doesn't promote the carbon buildup problem the rotarys have. Thanks for refreshing my memories on the rotarys Bailout!
But I still believe the computer compensates to allow 87 octane when used....but a higher octane allows the computer to benifit from the 10.5: compression....
churp is offline
Old 04-06-2007, 02:29 AM   #101
ChinoCharles
Drives: LB
Actually, that is my last car... and it was baller.
How many 5500 pound cars do you know that can yank a 14 second quarter mile with the heated leather seats on?
ChinoCharles is offline
Old 04-06-2007, 03:23 AM   #102
heh, that's one fast tank! hahaha
Old 04-06-2007, 12:08 PM   #103
Pavel Olavich
Drives: 2007 Yaris LB
yes our car can tell the difference between fuel grades... more premium gas gets better gas mileage... plain and simple... if you do not believe me just do it.... then you will know for yourself
Sorry but you're living in the land of dillusion...using octane higher then 87 for your Yaris will give you WORSE milage....why is this so hard for you to understand? Using higher octane means the combustion is RETARDED, meaning that it takes MORE gas to give the car the same power....this means lower milage...the only exception to this is if the car is engineered (tuned) for higher octane....you keep thinking that ALL cars behave the same with higher octane...this is dillusion, or worse.
Pavel Olavich is offline
Old 04-06-2007, 12:10 PM   #104
Pavel Olavich
Finally Someone Else Is Rational Here....
AMEN Broda!!!! You wrote it right and it is right!!!!! Why some here hold on to superstitions, urban myths, or what use to work with 1960ish cars is beyond me....
Old 04-06-2007, 01:35 PM   #105
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
Attachment 4265
hahah, my sienna does a 0-60 in 7.4, and the 1/4 mile in 16.4. not too bad for any car, let alone a van that seats 7!! my van is probably a little slower than those numbers, since i gots all the goods, like power doors and trunk and heated leather everything, and i run only the required 87. those tests were done using premium fuel. but i can attest to the fact that i've beaten quite a few cars "off the line" using only the required 87...now if we can only cram my sienna v6 into the yaris...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline
Old 04-06-2007, 01:41 PM   #106
Black Yaris
der Zeck
ok Pavel, MR HIGH and MIGHTY.... you explain why it is that everyone that tries putting higher octane fuel in there Yaris gets better gas mileage? In the words of ChinoCharles "Don't you ever shut up?"
Old 04-09-2007, 11:40 AM   #107
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hehehe thats funny...
marcus is offline
Old 04-09-2007, 11:49 AM   #108
marcus
toyota
marcus's Avatar
premium is always cleaner that the regular.....it may not make much to the horsepower but its cleaner..
marcus is offline
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
