Old 07-08-2018, 09:25 AM   #1
atomic_hoji
Drives: 2018 Yaris SE 5MT
+1 on the great job man! Sorry to hear you ran into some trouble spots, but the photos really make it look like you've done a sharp job - that's gotta be worth at least a 50' job, lol.
As you said, big effort and lots learned - next time you'll be 10 steps ahead; be honest with yourself, you know there will be a next time..
Keep us posted on the fix-ups when you do them, and thanks for sharing the awesome job you've done, it's been enjoyable to follow.
-- Adam
Old 07-08-2018, 05:47 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
-- Adam
Thanks Adam! I've decided to respray the passenger doors as they are the worst. I'll sand with 600 first and hopefully the clear will sand smooth enough to lay a couple of base coats and 3 clear coats. I have enough material remaining to do that. I will definitely post up the process.
Old 07-08-2018, 01:43 PM   #3
zoidberg444
zoidberg444's Avatar
I wish i wasn't on the wrong side of the pond otherwise i'd have you paint Betty.
Sent from my SM-G930F using Tapatalk
UK to Nordkapp in a Yaris
Old 07-08-2018, 05:47 PM   #4
06YarisRS
I would love to!
Old 07-11-2018, 10:00 PM   #5
06YarisRS
'New' liftgate
Scored a used liftgate for $150.00 today. It will need to be stripped, primed, sanded and painted. Although the clear is flaking off, the liftgate has absolutely no dings or even scrapes. It is 100% rust-free. I think this car was 'decomissioned' very early in its life. I'm going to refinish this off the car and then bolt it on. It came with the factory style spoiler too! Of course I have no use for this as I'll be taking the wing off my old tailgate and putting it on the 'new' one.
If this is the original paint, I'm really getting WeeYari's and Kimona's point that the paint on these cars - at least the clear coat - is a joke. This stuff can't be thicker than a human hair - wow!
Old 07-12-2018, 04:15 AM   #6
bradbowl
Hatchbacks for the win
bradbowl's Avatar
Drives: Hatchbacks
Thanks for sharing your experience, this is a great thread. You deserve a ton of credit for your hard work. It's inspiring!
bradbowl is offline   Reply With Quote
Old 07-12-2018, 02:36 PM   #7
06YarisRS
Thanks very much, bradbowl. It's been fun and it's definitely helping me improve my patience.
Old 07-12-2018, 02:32 PM   #8
06YarisRS
The Saga Continues...
Well, I'm definitely getting better at spraying paint. Doing an orientation coat (pulling the gun back and dusting the metallics on immediately after my final med/wet base coat eliminates any mottling and my base coat is super smooth and uniform with the metallic flake all in the same direction. I am learning tons. There are parts of the car that look much better than factory with almost perfect metallics and a deeper, glossier look due to more clear being applied. However, everytime I do some painting something goes wrong. This time, two things...
1) I had sanded the clear coat down with 600 grit to spray the new base coat. In one tiny spot, not realizing, I had sanded slightly through the clear right at the front of the door, lower style line. The base coat immediately wrinkled. I let the base dry, carefully wet sanded it and then laid about 4 dust coats of base with 15 minutes between each. Then, I laid down my final medium/wet coats. This solved the problem. You cannot tell now that there was any wrinkling.
2) My gun must have had some silicone or other contamination. I got many fish eyes. I am hoping to be able to sand these out and then do a quick flow coat of clear in a couple of days.
I am thoroughly enjoying this learning process. I am definitely improving but there is still much to learn and there are so many variables to contend with.
Old 07-12-2018, 05:05 PM   #9
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Let's just go big and call this pass a learning experience and do the whole thing over again when done! That way it'll come out perfectly
Amirite?!
Guys?
On Instagram
On Wheelwell
Old 07-12-2018, 06:24 PM   #10
Runethecursed
Drives: 2009 Yaris S
Amirite?!
Guys?
Runethecursed is offline   Reply With Quote
Old 07-12-2018, 08:46 PM   #11
06YarisRS
Amirite?!
Guys?
I'm going to do the liftgate next. Maybe next summer, I'll respray the whole car, or find another one to do so I can continue to practice.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
