Old 10-11-2013, 09:55 AM   #91
adeen
Drives: 08 Toyota Vios
i had my wire go through the firewall and connected it directly to the #3 pin of the foglight relay. works like a charm...thnx CTScott
adeen is offline   Reply With Quote
Old 02-03-2014, 10:30 AM   #92
bairjo
For what it is worth, I threw together a video of my fog light install using the OEM light stalk. Hope I didn't leave anything out. It moves along rather fast at the beginning as I needed to keep it under 15 minutes for YouTube. Thanks go out as usual to CTScott for his in depth contributions on this mod as well as others he has come up with. Hope the link works.
https://www.youtube.com/watch?v=bilhPerqVEo
Old 02-03-2014, 11:03 AM   #93
auxmike
auxmike's Avatar
Bairjo, you knocked it out the park, man! Fantastic job and even the music is good here!
Old 02-03-2014, 05:57 PM   #94
bairjo
Thanks Mike...I never know how well received some of my videos will be. Hope it helps others out when they do thier install....thanks again.
Old 02-03-2014, 06:09 PM   #95
auxmike
auxmike's Avatar
I priced the stalk at 95USD. Does that sound right?
Old 02-03-2014, 06:42 PM   #96
$91 is about the cheapest I have seen the OEM stalk go for. On all of mine, I used an illuminated switch that I mounted to the dash. It is the same one as well that is included in the Micro Image kit. If you want to save some money, I can ship you one for $10.
By the way, Bairjo, nice job with the video!
Old 02-03-2014, 06:46 PM   #97
auxmike
auxmike's Avatar
That's nice. Can you PM me paypal info? I'd like one..
Old 02-03-2014, 06:49 PM   #98
auxmike
auxmike's Avatar
Also, can you tell me how I'd get it to light up? My current switch is between the seats but I can't figure out how the heck to get the light to work. The best I got was the light being constantly on ...
Old 02-03-2014, 07:43 PM   #99
The problem with the one that comes with the aftermarket kits is that the switching and illumination are tied together. To use the switch with the OEM wiring you have to separate the two by snipping one of the resistors off the circuit board within the switch.
The one that I use has separate wiring for switching and illumination, so you will have to connect 4 wires to hook it up. Two go to two wires on the headlight switch connector and the other two to two wires on the connector for the dimmer rheostat.
Old 02-03-2014, 08:23 PM   #100
bairjo
Well I was trying to upload photo copies of the directions out of the Toyota shop manual on how to properly adjust the fog lights but failed due to a "missing security token" whatever that means. Anyhow, I have not seen anything on the topic of adjustment. I'm having a little difficulty dialing one in to the proper height. Anyone care to share how you did your fog light adjustment and how did it go? By the way, my light stalk was $87 + 10 shipping. That arrangement CTScott has looks real slick....much better than the switch between the seats set-up. I had my switch between the seats on my 08 and really didn't care for it.
Old 02-03-2014, 08:37 PM   #101
With the foglights that have the adjustment mechanism that points down towards the ground, you stick a phillips screwdriver up in there and tighten to raise, and loosen to lower. I cranked mine way down to where the light patten starts right where I can see past the hood.
Old 02-03-2014, 08:52 PM   #102
bairjo
Thank you. That sounds a heck of a lot easier than how Toyota spells it out. I have measured out lines taped on the wall trying to hit the mark...I'll go with the CTScott plan!
Old 02-04-2014, 10:46 PM   #103
Revsson
bairjo - nice job on the video!
I shouldn't admit this, but I installed my foglights when I replaced the horn
with one of those premium horn kits. I never ran the wires. Been too busy
or lazy to finish the job. I'd really like to have a stalk like that, but too
chicken to mess with airbag stuff, though you make it look easy. That would
probably take me all day to do, and would have to borrow some tools.
However, maybe when it's warmer, I'll get motivated. BTW, I got the
Micro Image kit...yikes, that was a few years ago now that I think of it.
Where does the time go?
Thanks again for the video and to CTScott for all his expertise on the Yaris!
Old 02-24-2014, 03:17 AM   #104
coly369
Drives: yaris hatchback 2013
ok now mi problem is that I have the same kit, but I have a yaris 2013 and I don't want to cut any cable because the warranty, what can I do, don't know anything where to plug the wires o the 15 fuse go please help
coly369 is offline   Reply With Quote
Old 02-25-2014, 12:34 AM   #105
bairjo
Regarding cutting cables and warranty. Go ahead and cut...I asked the dealer about this when I had my 08...they said it will not void anything unless what you do damages something. For example, if you took your car to a pro to have a remote start installed....snip snip. No issues with the warranty. Just be sure you do your homework and follow the advise of the folks on here that tell you how to do it right. You will be fine...
Old 04-15-2014, 04:06 PM   #106
jcboy
Drives: Sedan 07
Originally Posted by docvirus25 View Post
I own a Yaris, (Thailand / General Area) year 2011 model and i've installed an aftermarket fog lamp. Does anyone here knows how to get the fog lamp indicator turned on the dashboard without replacing the OEM stalk. I'm too chicken out to remove the airbag and the oem stalk as it involves removal of the steering clock spring. Does anyone here knows which wire harness or pin to tap into for supplying the 12vdc power to light up the dash fog lamp indicator? Any help would be greatly appreciated. Thanks.
it should be pins 3 and 4 for the stalk connector under the steering column cover, but if you choose the route of tapping into the cluster (as ours here who don't have the stalk switch also don't have wires 3 and 4 under the stalk connector) you should be able to supply 12V on Pin 7 of the 16-pin connector (the shorter one and the one near the driver).
You can read more here:
http://yarisworld.com/forums/showthr...=indicator+fog
If nothing works, you might want to check if there's an LED behind the fog indicator on the cluster by gently lifting that black plastic part (where the speedometer/tach is printed on)
Old 04-28-2014, 03:35 PM   #107
Nenomarcano
Drives: Yaris Sedan
Instrument panel light of yaris Belta Sedan (Vios) not funtion.
Some one know how to repair it.
Nenomarcano is offline   Reply With Quote
Old 04-29-2014, 03:20 PM   #108
jcboy
Drives: Sedan 07
Thanks a zillion jcboy. That's what i'm looking for. There's an LED pre installed in the indicator panel. Your suggestion worked like charm.
Glad to help. Mine still doesnt work despite working in a different car with stalk switch, although both ours are factory-wired, mine is using a switch. i gave up.
Check the link above.
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
