Old 03-26-2011, 05:32 AM   #1
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by xtremist View Post
how about sa headlight mo, wala nman ba prob? sa foglight lang ba?
wala naman problema sa headlight
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-26-2011, 05:36 AM   #2
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Originally Posted by duke_afterdeath View Post
@rosco, kagabi ko lang napansin kapag bukas ang foglight ko may wire na nagiinit sa ilalim ng dashboard dun sa may mga fuse, napansin ko lang kagabi kasi bigla akong may naamoy na parang nasusunog kagabi, try ko kanina off ang foglight di naman uminit ung wire tapos takbo ulit si storm this time on na ang foglight at ayun uminit ulit ang wire,, try ko ipa check sa kilala kong car electrician...
@duke, paki check nga yung white bulb sa foglight mo kung ilang watts, base kasi sa manual 55watts ang maximum na pwedeng ikabit sa foglight. Baka kaya umiinit yung kable nya gawa ng over wattage naman.
jonimac is offline   Reply With Quote
Old 03-26-2011, 05:39 AM   #3
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
possible din
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
xtremist is offline   Reply With Quote
Old 03-26-2011, 05:39 AM   #4
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
baka 50KW ang nailagay!
EjDaPogi is offline   Reply With Quote
Old 03-26-2011, 05:39 AM   #5
duke_afterdeath
cguro nga tol, according sa label 1200W yung foglight try ko ibalik then check ko ulit kung iinit pa..
Old 03-26-2011, 05:40 AM   #6
xtremist
xtremist's Avatar
buti nalang nauna ka pre...hehehe, wait lang ako ng feedback mo bago ko ikabit ung sakin
Ciao !!!
Old 03-26-2011, 05:41 AM   #7
EjDaPogi
EjDaPogi's Avatar
duke, ayos! may sukli ka pa! ibili mo na agad ng seatcover!
Old 03-26-2011, 05:43 AM   #8
duke_afterdeath
bussettt
Old 03-26-2011, 05:57 AM   #9
jonimac
jonimac's Avatar
okay, try mo muna yung OEM bulb. Kung umiinit pa rin yung kable may ibang problema yan. Pero palagay ko sa ilaw lang yan.
Old 03-27-2011, 07:06 AM   #10
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Tol joni, what about sa headlights ilan ang max watts? Sa tingin mo ba ok lang yung H4 white bulb nanilagay namin??
rye7jen is offline   Reply With Quote
Old 03-26-2011, 05:22 AM   #11
xtremist
xtremist's Avatar
may katapat na pala kayo mga Kayaris Central pagdating sa kantahan, dyan sa central, si duke ang manok nyo...dito naman sa east, recommend namin si Frank as our "pambato"...hehehehe
Ciao !!!
Old 03-26-2011, 06:00 AM   #12
syntax
syntax's Avatar
@ duke nu kaya kung palitan mo ng wire na mas makapal ung para sa foglights? i trace na lang natin ung wire tapos maglagay tayo ng mas makapal na wires, kaya naman ata ng fuse para sa foglights kaya ok lang cguro lagyan ng mas makapal na wire para hindi uminit
pwede rin ung suggestion ni idol jonimac, para matroubleshoot din natin
Old 03-26-2011, 06:10 AM   #13
duke_afterdeath
ok mga tol obserbahan ko muna
Old 03-26-2011, 06:12 AM   #14
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
@duke kagaya ng napagusapan natin...try mo muna patignan sa mangagamotat kung ano reseta ibigay....sundin na lang...
itago mo lang yung kahon ..baka pede natin mapapalitan ng ibang item...
@jeff tignan muna natin kung ano magiging hatol..standby ka lang....
rosco is offline   Reply With Quote
Old 03-26-2011, 06:13 AM   #15
xtremist
xtremist's Avatar
ok rosco, no problem
Ciao !!!
Old 03-26-2011, 06:34 AM   #16
xtremist
xtremist's Avatar
teka teka, parang wala pa sa friendlist ko sa FB si armando, ano ba FB acct nya?
Ciao !!!
Old 03-26-2011, 06:48 AM   #17
duke_afterdeath
ito tol http://www.facebook.com/profile.php?id=100001277832124
Old 03-26-2011, 06:54 AM   #18
xtremist
xtremist's Avatar
ok, salamat
Ciao !!!
