Old 12-18-2015, 06:17 PM   #1171
Jason@SportsCar
Finally got the spare trans opened up, looks worse than I expected. Drove fine, other than a slight clunk when going from 5th to 4th - never even a grind from 3rd to 4th, no hint there was an issue until I found synchro teeth in the axle seal. In addition to a wasted synchro there are some broken and burned up parts. The oil sprayer broke off and the shaft it supplied got a little hot. Ordering a few replacement parts, and coating stuff this time. Still, after three years of racing with nothing more than a fluid change, I can't complain.
Old 12-18-2015, 08:55 PM   #1172
Wow. Any miss shifts contribute to that?
Sent from my iPod Touch
Old 12-18-2015, 09:17 PM   #1173
Jason@SportsCar
Its really hard to miss the 3-4 shift. But after three years of use, and many guest drivers, I am sure it has been well used. I know guys that are having to rebuild much more costly trans every season, so I wont complain about getting three years out of this one.
Old 12-18-2015, 09:22 PM   #1174
Only asked because you said the downshift was getting bad but the upshift was fine.
I had the same problem with 4th on my 6 speed transmission I built years ago. But after having it out to swap in my new turbo engine I switched to royal purple and the notchy downshift to 4th has nearly completely cleared up.
Old 12-21-2015, 12:06 PM   #1175
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Going the DLC route or WPC treating the parts?
2014 BSpec Divisional Champion
Old 02-01-2016, 02:33 PM   #1176
Jason@SportsCar
Took the car out to Auto Club Speedway over the weekend for the SCCA U.S. Majors Tour. Took the win from the pole on Saturday, and knocked another tenth off the H Prod track record, now at a 1:59.302.
Sunday we thought it was going to stay dry enough to run full slicks, was just a slight sprinkle when we headed to grid, but it started to rain hard during the race. At one time I was leading the group overall, but it was not worth pushing that hard to so I backed off a bit. Took the win in HP and finished 3rd overall.
https://www.youtube.com/watch?v=YltL_MgqkrU
Old 02-02-2016, 04:42 AM   #1177
rabbito
rabbito's Avatar
i salute you for the build you have done on your car
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-02-2016, 05:06 AM   #1178
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Oh, the horror! Not everyone knows what those are supposed to look like, but I can appreciate what happened in there. Will you be sticking with the stock ratios still, or have you decided to tweak them based on performance at a given track?
Old 02-02-2016, 12:32 PM   #1179
Jason@SportsCar
Stock ratios? We have been using the Kaaz gear set since 2012. Nothing will be changing.
Old 02-02-2016, 06:52 PM   #1180
CrankyOldMan
Crap, there I go showing my age again. You're still using the stock final drive, yes?
Old 02-02-2016, 07:03 PM   #1181
Jason@SportsCar
Not since 2010, we use the xB final drive.
Old 02-05-2016, 11:49 AM   #1182
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
What GoPro are you using. looks so crisp.. better then before unless my new glasses are clearer.
Love watching your video's.
-Derrick-
Old 02-05-2016, 02:23 PM   #1183
Jason@SportsCar
Have been using the same GoPro Hero 3+ for a couple of years... The difference in clarity is due to the windshield being tinted.
Old 02-06-2016, 10:18 AM   #1184
ilikerice
ilikerice's Avatar
Cool, learned something new
-Derrick-
Old 01-24-2017, 03:14 PM   #1185
Jason@SportsCar
The 2017 race season is under way. Just head a double header at Auto Club Speedway. Took the H Prod pole, claimed the win both days, and reset the record that I set at this event last year. Looking forward to Indy in October.
https://youtu.be/FlX4IYoBeNE
Old 01-24-2017, 04:12 PM   #1186
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Top shelf level of cool.
On Instagram
On Wheelwell
Old 01-24-2017, 08:13 PM   #1187
CrankyOldMan
Any chance you'll get to MIS this summer?
Old 02-02-2017, 09:44 AM   #1188
ilikerice
ilikerice's Avatar
My Idol
-Derrick-
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
