Old 03-28-2011, 02:40 AM   #1
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@duke, question, hindi na ba sila nag-lagay ng inline fuse para sa relay? in-between ng relay at battery?
rye7jen is offline   Reply With Quote
Old 03-28-2011, 06:05 AM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol ganito ung harness na kinabit kay storm iba lang ang socket nito, wala syang fuse, yung nakikita nyong white casing sa wire na pula na ikakabit sa battery ay connector lang yun para madali syang i-disconnect sa battery if ever needed...Name:  H4 relay harness..jpg
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-28-2011, 06:07 AM   #3
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Originally Posted by duke_afterdeath View Post
tol ganito ung harness na kinabit kay storm iba lang ang socket nito, wala syang fuse, yung nakikita nyong white casing sa wire na pula na ikakabit sa battery ay connector lang yun para madali syang i-disconnect sa battery if ever needed...Attachment 40741
ayos!
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 06:09 AM   #4
syntax
syntax's Avatar
@ duke kailangan pa kaya ng harness na yan kapag naka HID?
Old 03-28-2011, 06:13 AM   #5
duke_afterdeath
Originally Posted by rye7jen View Post
Thanks tol, baka si idol jonimac ang makakapag-bigay linaw.wehehehehe!
nasan nga ba si idol para magbigay liwanag, haha.. idol labas jan
tol di na kailangan nyan sa HID kc may sariling harness na siya at may ballast na na nag hahandle ng power or load (ako malapit na maubos powers ko)
Old 03-28-2011, 06:15 AM   #6
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
+1
Wahahahaha!!
Old 03-28-2011, 06:13 AM   #7
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@ramil, according sa harness na pinost mo e plug'n'play nga siya at hindi na kailangan ng inline fuse. THanks!
Old 03-28-2011, 06:16 AM   #8
duke_afterdeath
ako naman ang nagiisip ngaun if need pa bang lagyan ng inline fuse between battery and relay para mas safe
Old 03-28-2011, 06:20 AM   #9
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
"*ding dong**
(Paging joni idol)
Old 03-28-2011, 09:13 AM   #10
syntax
syntax's Avatar
@ xtremist parang na encounter ko na yan sa lancer ko dati, tuwing liliko ka lang ba? or kapag nalubak din ung rightside? nakalimutan ko na ung pinalitan kung ano tawag dun, pero tama si rye pa check mo na agad baka pagliko mo ulit makikita mo na ung gulong mo nauuna pa sayo wehehehehe....
Old 03-28-2011, 09:34 AM   #11
batman_john72
batman_john72's Avatar
Drives: yaris y 2010 blue
batman_john72 is offline   Reply With Quote
Old 03-28-2011, 10:33 AM   #12
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
Originally Posted by batman_john72 View Post
tananananananan...batman......sa wakas lumabas sa kweba nya..tol wala ng emblem e...
katulad ng kay armando meron..40sr..sa dammam..ano papabili ka ba?
rosco is offline   Reply With Quote
Old 03-29-2011, 01:40 AM   #13
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
mga pre, mukhang ung tunog e nanggagaling lang sa lever ng signal, sinubukan ko nakaparada tpos turn right ko signal w/o turning the steering wheel, may naririnig akong tunog, parang tunog ng spring. ung tunog ay nacrecreate lang kapag ginalaw ko ung lever na hindi align, i mean ung hindi straight na straight kapag pinihit. sa tingin ko wala naman prob yun,
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
xtremist is offline   Reply With Quote
Old 03-29-2011, 01:43 AM   #14
fgorospe76
"i R i S H"
fgorospe76's Avatar
Drives: Toyota Yaris 2010
itanong natin sa mga experts yan pre, wala din me alam dyan hehehe
pre, magkakabit ka din bang relay? tingin tyo sa tuqbah kung gusto mo?
fgorospe76 is offline   Reply With Quote
Old 03-29-2011, 02:02 AM   #15
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
if that's the case bro buksan mo yung steering column, silipin mo yung lever sa signal baka may nag loose lang. Or ipa-check mo na sa toyota kung di mo pa rin makita, at least hindi BEARING ang problema.
jonimac is offline   Reply With Quote
Old 03-29-2011, 08:03 AM   #16
xtremist
xtremist's Avatar
libre ba yun pre sa toyota? o may bayad na?
Ciao !!!
Old 03-29-2011, 08:04 AM   #17
syntax
syntax's Avatar
pre ano na ba km ni sky? kapag pinasok mo ulit, sabihin mo na ung problema na un...
Old 03-28-2011, 12:03 PM   #18
syntax
syntax's Avatar
sa wakas nabunot din este lumabas sa batcave si batman wehehehehee
