#1225 | |
But our head units make all kind of magic sound spectacular! Thank you! That would be great! D.
. CLA 250, 4MATIC |
#1226 |
Roadrunner Jr.
I received the album today...I'm listening to it.
What you should expect is a very comfortable five piece jazz group in a VERY small jazz club. The club was so small that the recording engineer had to put the reel to reel recorder on his lap with no console! ![]() You should enjoy the ambiance and musicality of these recordings.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#1227 |
I'm overwhelmed, many angles and aiming positions with the MIDs, technical tracks sound pretty good, some songs sound great! what sounds best??? it's hard to tell.
![]() In other hand I moved my IDQ12 back to the trunk (just for a couple of days) I just want to put it back up-front again. I did try the PB amp in other position and I still get the noise. It's getting warm over here, so that's good news! D.
. CLA 250, 4MATIC |
#1228 |
Roadrunner Jr.
I'm thinking it's time to send the amp back to Jim. We'll get you covered...
#1229 |
Roadrunner Jr.
A lot of the fun starts when you work on the tune...
Remember order of operations though! Can you tell me what the proper order of tuning is?
#1230 | |
![]() Please tell me the answer(s) before I go nuts with Google! At least I may know what I'm doing is not stupid... ![]() D.
. CLA 250, 4MATIC |
#1231 |
Roadrunner Jr.
There's a certain order that creates the most success in a tune...
It' won't necessarily be on google. :) This is where I torture you hanging the answer over your head for a little bit.
#1232 |
OK, lets try...
1. set x-over points and dBs 2. TA 3. EQ Just to throw some thing... D.
. CLA 250, 4MATIC |
#1233 |
Roadrunner Jr.
You're almost there!
crossover phasing amplitude level time alignment equalization Take a little time to research the different effects that your slopes that you choose will have on phasing.
#1234 | |
phasing A LITTLE HARD BUT DID IT amplitude level WHAT DOES THIS MEANS? time alignment WORKING ON IT equalization FUN AND WORKING ON IT D.
. CLA 250, 4MATIC |
#1235 |
Roadrunner Jr.
When you put the dB level as a choice. That's amplitude in this case. You recall what your p99 crossover slopes can do...that includes adjusting the signal Voltage for each preout which is nice.
#1236 |
Roadrunner Jr.
There is also another technique that is a bit more advanced...
I may let you in on that one in a few months. We'll see how I do in Calgary...
#1237 | |
Talking about "Aiming" I've been going nuts with my MIDs, but when that happens I turn "OFF" Time Alingment and that reminds me why struggle so much with this,there are a couple of sweet spots but in general they sound so good (off-axis). I'm leaning more in a position similar of your L4s, but just a tad more into the cabin 2 or 3 degrees and I would like to sink the Mids as much as possible into the a-pillars separating them apart. What about the Tweeters? How did you came up with your aiming? it's very agressive towards the windshiled! D.
. CLA 250, 4MATIC Last edited by derickveliz2; 04-27-2011 at 01:26 AM. |
#1238 |
Roadrunner Jr.
The tweeters for me are an afterthought. Most of the work of reproducing sound is done by the mids. The tweeters are there for top end "air". The aiming is a result of the same effect of the mids. It's about imaging for me. I can get the sparkle and air without the tweeters being too bright (i.e.-on axis).
...Scott also suggested I try the off axis setup...
#1239 |
. CLA 250, 4MATIC |
#1240 |
Roadrunner Jr.
Do you want to make that enclosure or do you want us to? That's the hard thing for you...it's a T/L enclosure. Right now we're still playing around with how to get these little woofers to give BIG impact. They sound spectacular but the output isn't as much as we'd like.
It's simply not a slap it in and let it go woofer.
#1241 | |
I will supply .35 cubic fit with 2" Diameter 16" long vent , like HAT shows in their website, as a starting point and see what happens? I'm sorry for the slow return, I got a new (temporally job in the IT area) with lots of commute, and some other photo projects, keeping me very busy and no time for my hobby/passion. D.
. CLA 250, 4MATIC |
#1242 |
Roadrunner Jr.
Job and family come first bro!
Like I mentioned in XBR's post, I've got a GREAT solution to IB the L6's. Check this out: You know the plastic insert mounts that the styrofoam goes into on our floor boards? ![]() Use a flat blade screwdriver or panel popper and pop that bad boy out. ![]() ![]() ![]() It gives is a 10"^2 aread for the L6's to vent! WOOT! Take out your kicks, mark the area where that hole is, make the cut in the bottom of the pod. Before you put the pod back in, put some polyfill into the hole. It's a crumple zone that remains more dry than the doors do. I'd place a thin gasket around the hole and replace the kick pod. The mid bass response should be remarkable at this point, especially versus a sealed enclosure. ...and let the magic happen!
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
