Old 05-30-2009, 07:57 AM   #1
regal
I finally got it to work after cutting about half the waires off, I am using a different 12V source and the voltage divider, the TPMS unit is unplugged. Not pretty but does work. CTScottt mentioned there is a regulated 4V signal coming out of theTPMS uit, I couldn't find one on my 09 only a 6V.
Old 07-07-2009, 07:31 PM   #2
Treyz
~ ambient one ~
Treyz's Avatar
Sedans don't get the DRL options like the lifback. My old '07 had them as well as my new '09.
I did the switch today. I had to leave it dangleing because I don't think the quick connects (splicers) made a solid cut through the facotry wires. I'll get to it eventually lol.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 07-07-2009, 09:18 PM   #3
Here's an even easier method that I figured out one day. I just haven't gotten around to writing up a DIY on it:
Old 09-22-2009, 03:15 PM   #4
busdriver
Drives: 08 Yaris
CT Scott:
Great thread. Using your scematic, I did the fix in 30 mintues.
Thanks!
busdriver is offline   Reply With Quote
Old 08-09-2012, 04:17 PM   #5
CodyTheBody
Drives: 2009 Toyota Yaris 4D
So this method replaces the very first post of this entire thread? I'd like the ability to switch back and forth between wheels. Put some different rims/tires and had the TPMS light come on and stay on.
CodyTheBody is offline   Reply With Quote
Old 08-09-2012, 04:42 PM   #6
Correct.
Old 07-08-2009, 12:54 AM   #7
Treyz
~ ambient one ~
Treyz's Avatar
So now we are back to three wires? I did the heat shrink and all with the 150ohms.
AMBIENTLIFESTYLE
Micro Image
Old 07-08-2009, 09:00 AM   #8
It's not cutting the VSS and ESS wires (like the original started with). In doing some reverse engineering of the TPWS, I realized that it has a regulated 5VDC output that powers the radio receiver module. Tapping the white wire in pin 5 gives us this regulated voltage, so the resistor voltage divider isn't necessary. Both methods work, but this one is a bit more simple.
Old 07-28-2009, 12:01 PM   #9
Keith Tinari
Scrubble with a poke.
Keith Tinari's Avatar
Drives: 2009 Yaris LB
I just took off my rims, I will be doing this in a little to get the light off permanently.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen
Keith Tinari is offline   Reply With Quote
Old 07-28-2009, 12:29 PM   #10
regal
I found my 09 to have completely different colors, I used a DMM to find the right wires.
Old 07-28-2009, 12:38 PM   #11
Keith Tinari
I re read this thread and realize I am not even close to competent to do this lol.
Old 07-28-2009, 12:51 PM   #12
Just look at post #115 above. As long as your wire colors/positions match up, it is quite simple, especially if you do the non-switch version. Basically, you clip one wire and tap it to another.
Old 07-28-2009, 12:45 PM   #13
regal
learn how to use a DMM they cost like $6 at harbor freight, use the resistors to split a 12V line to 5V and send to the indicator light.
Old 08-19-2009, 11:06 PM   #14
Liu997
Drives: 2008 Red Yaris LB
ehh I did the resistor thing anyway, so basically the resistors was just for a 5v dc?
Doesn't matter soldering is fun Anyways you da man CT
Liu997 is offline   Reply With Quote
Old 08-29-2009, 02:00 PM   #15
jonismyname
Drives: 08 liftback 5spd
i just completed this in 90 seconds with a pocket knife.
it'll take another 30 seconds when i have a piece of tape to finish.
jonismyname is offline   Reply With Quote
Old 09-23-2009, 02:12 PM   #16
bronsin
bronsin's Avatar
Hmm I bought a rim for my Yaris with a useable tire but no sender. What happens if the warning light goes off! Ok to put tape over it?
Old 09-23-2009, 02:54 PM   #17
The light will come on eventually. It doesn't affect anything other than being annoying. You can tape it, or do the mod.
Old 12-21-2009, 10:18 PM   #18
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
thank you CTScott and Rick!!
Thanks to them, I was able to make mine with a switch.
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 06:53 PM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
