View Poll Results: Which Fully Synthetic Motor oil do u use?
Mobil One 78 48.75%
Castro Synthec 12 7.50%
Royal Purple 21 13.13%
Vavloline 13 8.13%
Redline 3 1.88%
Motul 7 4.38%
Toyota Factory Synthetic 8 5.00%
PennZoil 12 7.50%
Penrite 0 0%
Generic(Exxon,Shell) or Other 12 7.50%
Multiple Choice Poll. Voters: 160. You may not vote on this poll
Old 01-19-2009, 03:44 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Poll: Which FULLy synthetic oil do you use?
for those who use fully synthetic oil for their engines
i am now using Royal Purple after my factory break in oil (changed at 5100k)
Yawesh is offline   Reply With Quote
Old 01-19-2009, 04:35 PM   #2
ChinoCharles
Drives: LB
I use Royal Purple because the hillbillies that live amongst me swear by it and if there is one thing I know it is that hillbillies love their engines. Doesn't hurt that its a track staple around here, too.
Old 01-19-2009, 04:40 PM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
I use Mobile-1. Why? I guess I've always held it to be the standard among synthetic engine oils. I'd certainly switch to another synthetic brand if it were that much better.
same here and im up for a change if it will help.....
Old 01-19-2009, 04:48 PM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i use royal purple because were dealers for it so i get it at a good price. other than that, i wouldnt use it
Old 01-19-2009, 05:14 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Where is Amsoil on the list?
Old 01-19-2009, 05:26 PM   #6
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
lol, sorry. wished i could fit more
Old 01-19-2009, 05:41 PM   #7
CASTREX
CASTREX's Avatar
Well, then you need to remove one of the options you have there because I know several YW members use Amsoil.
Amsoil 0W-30 Signature Series FTW!!
Old 01-19-2009, 09:15 PM   #8
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
is there any way to edit it? can mods help out? thanks!
which should i remove in replace with Amsoil?
Old 01-19-2009, 05:28 PM   #9
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I'd buy Amsoil if it were more readily available through retail outlets.
BTW, wth is Vavloline? Are you trying to piss off SilkySmooth?
Old 01-19-2009, 05:38 PM   #10
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Amsoil!
2006 Red Blitzed RS 5-door
Old 01-19-2009, 08:22 PM   #11
CB900F2
Drives: 08 Sedan
Amsoil 5W30 (ASL) with EAO OIl Filter.
CB900F2 is offline   Reply With Quote
Old 01-19-2009, 08:33 PM   #12
Klink10
Klink10's Avatar
Amsoil 5W-30 XL changed between 4000-5000 mi. usually at 4500.
Old 01-19-2009, 09:56 PM   #13
Klink10
Klink10's Avatar
I wouldn't worry about it....just count the number of posters who write in AMSOIL.
Old 01-19-2009, 10:45 PM   #14
YarisSedan
Drives: 08 Yaris Sedan
Amsoil high performance oil with K&N filter
Old 01-19-2009, 10:50 PM   #15
yarstar
Drives: 2008 Absolute Red HB
AMSOIL 0W-30 Signature Series with EAO filter
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 01-21-2009, 02:28 PM   #16
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
bump
Old 01-27-2009, 11:47 AM   #17
PolarWhite
PolarWhite's Avatar
Drives: '07 Polar White Hatchback
For those out there that think Mobil 1 is the best on the market, you need to do your research. Valvoline was running national ad campaigns claiming that there full synthetic oil provided 4x better protection than Mobil 1. Mobil 1 sued and their case was thrown out when Valvoline showed up in court with the independent lab tests showing the results. They also did more testing and found that the current Mobil 1 formulation does not meet the minimum API SM or ILSAC GF-4 specifications either. Seems they have been resting on their laurels and got behind the rest of the industry. I love it. I have the letter right here in front of me.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads,
PolarWhite is offline   Reply With Quote
Old 01-19-2009, 11:16 PM   #18
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
i've used mobile on two changes, and castrol on one change.... didn't really see any change in mpg's.... MAYBE 1mpg...hard to tell.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
