Old 01-24-2009, 05:28 PM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Smile Installed the 1zz throttle body -
I installed the 1zz throttle body today, and after everything was bolted back up, the engine oscillated terribly, I was expecting the 2-3k revs, but then after a few minutes it started to rev weird, eventually dropping off and starting to rough idle between 500 and 2k rpm, I attempted to purge the air from the lines, and got a few bubbles out of the coolant, and no more were coming out, but it did the same thing. No CEL was present during this.
So to prevent damage, I took it off and re-installed the stock throttle body, as I was doing this, I noticed that there was no coolant passing through the 1zz throttle body, the lines were empty. however when I bolted back up the stock TB and everything connected again, it oscillates between 2-3k rpm still, although I again purged the air from the coolant, getting more bubbles than I did with the 1zz TB.
What could this be from? I was shocked when I put the stock throttle body back on and it still oscillated like that.
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
