Old 06-04-2009, 02:57 PM   #1
would this work for any other cars..
Such as?
I would think that based on what we found with the Yaris it would probably be doable for any drive by wire Toyota.
Old 06-04-2009, 03:01 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
nice...
Old 06-04-2009, 05:21 PM   #3
bronsin
bronsin's Avatar
IM thinking something similiar will work for all such DBW cars.
Old 06-05-2009, 03:47 PM   #4
bronsin
bronsin's Avatar
I have two sets of resistors and two sets of switches I bought that I didnt use. For $5 Ill send you a set. PM me if intereted.
Old 06-05-2009, 05:11 PM   #5
POORSHA
POORSHA's Avatar
Drives: 2008 LB
pm'd
POORSHA is offline   Reply With Quote
Old 06-05-2009, 10:39 PM   #6
Originally Posted by POORSHA View Post
pm'd
Let me know if you need help with the install, since you're in CT as well.
Old 06-05-2009, 11:20 PM   #7
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Hold on just a couple more days and I'll have that module installed. I just haven't had time to rip the dash again. I also have to rethink my clutch switch, the switch broke. That's what I get for going cheap :) Anyway, I'll prolly just buy the oem one. I'll put picks up when I'm done with all of this...
My Car Rules!
nickhjort is offline   Reply With Quote
Old 06-05-2009, 11:24 PM   #8
POORSHA
POORSHA's Avatar
Drives: 2008 LB
thanks i might just take you up on it
Old 06-06-2009, 08:33 AM   #9
goat1of2
Drives: 2008 Yaris LB Auto 3-door
In order to provide the on-off indicators which some folks want...rather than messing with wiring LEDS and such, why not just buy an illuminated switch button? Would that work? If so, which Digikey part number would you supersmart electronics types recommend?
I'm about to make an offer on an 07 Yaris without cruise and am MOST grateful that I stumbled on this thread! Thank you all!
goat1of2 is offline   Reply With Quote
Old 06-06-2009, 12:20 PM   #10
The illuminated switch won't work without the same type of driving circuitry, due to the switch being a momentary input (rather than a latching switch). Basically, in electronic terms you need a flip-flop, which takes a single input and toggles the output each time the input is pulsed.
Old 06-07-2009, 10:33 AM   #11
daftcain
Drives: 07 3dr HB
I'm probably going to do this mod soon and I'm about to gather what parts I need. I'll probably go with the mounted two button method, and since I have an 07 3-door HB auto, I'll need to run a wire through the firewall. This seems like it will be the same installation as Patrick Johnson (http://www.yarisworld.com/forums/sho...&postcount=101). I'll get the resistors/switches from digikey, where should I get the wiring and what gauges? Also how hard is it to feed a wire through the rubber hose and have it come out the other side?
daftcain is offline   Reply With Quote
Old 06-07-2009, 12:23 PM   #12
The wire gauge isn't critical, as there is no current involved (we're just switching a signal input). I would go with between 22 and 18 gauge. You could purchase a small spool at Radio shack or Home Depot.
Feeding through the passenger side rubber boot is fairly easy. Poke a small hole, shove through a semi-rigid piece of wire, and then pull through your wire.
Old 06-11-2009, 12:35 PM   #13
bronsin
bronsin's Avatar
Old 06-22-2009, 11:59 PM   #14
nickhjort
nickhjort's Avatar
Awesome install Patrick Johnson and bronsin! Looks just like mine. I'm glad this is working out for everyone :)
My Car Rules!
Old 06-23-2009, 09:28 AM   #15
bronsin
bronsin's Avatar
How many have done the install? Many who see mine comment on the coolness. But an equal number say "You did WHAT?!"
PS I still have a set of four switches and the resistors to do this mod. $5 gets it mailed to your door.
Old 06-28-2009, 09:39 AM   #16
Bravejus
Drives: 08 Yaris 3 door 5MT
I just did this mod also, however i mounted my two button setup in the empty pop out panel next to the dimmer roller switch.
Bravejus is offline   Reply With Quote
Old 07-06-2009, 03:27 PM   #17
luigi
luigi's Avatar
Drives: '07 Sedan
Bravejus, i was thinking of mounting in the same place. Got any pics?
luigi is offline   Reply With Quote
Old 07-06-2009, 03:51 PM   #18
trialsdork
Drives: '09 liftback, '91 pickup
It worked! I mounted the buttons inside the coin tray as a trial, they're completely hidden. I also installed a mini-deans connector so that I can take the whole mess out in the event of a warranty problem. I think I'll relocate them to the empty removable panel next to the dash light dial soon, for user friendliness. THanks!!!!
trialsdork is offline   Reply With Quote
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
