Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Hawaii
Old 05-23-2009, 05:59 AM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
This?!
Wow I didnt even know that HUGE thing was a wire. haha
Old 05-23-2009, 06:00 AM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
yeah thats a constant 12volt wire
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-23-2009, 06:03 AM   #3
Taiyaki
アキバ製
Taiyaki's Avatar
whoa sweet. Oh! also is it ok to tap the illumination wire to the red constant? just like we did with my tach? so the back light is always on.
edit: how would be the best way to tap that big wire? cut some rubber off and just twist the wire around it and tape it off?
Old 05-23-2009, 06:08 AM   #4
battleversiontc
yup or you can find the alarm wires and tap into the red wire for the alarm thats also a 12volt constant that comes of the biggest harness on the alarm for the illumination wire i would tap it into the yellow wire off the alarm thats on the pack of wires that are all like stuck together so it turns off with the key
Old 05-23-2009, 06:15 AM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
Ok! ill give it a shot tom'w and will put my wheels on my car! will report back later tom'w with the good or bad news. Dude thanks again devin.
Old 05-23-2009, 06:29 AM   #6
battleversiontc
no problem let me know when u get the alarm and stuff
Old 05-23-2009, 03:26 PM   #7
gwasabi
Drives: 07 Blazing Blue LB
Is that 12 constant always on? I was trying to tap into a source that only turned on when the car was on but I guess it doesn't matter
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-23-2009, 03:52 PM   #8
battleversiontc
the big black wire yes is 12volts constant theres another wire that is ignition only when the key is turned on which is the one that he uses for the tach light
Old 05-23-2009, 04:22 PM   #9
gwasabi
Ok from what I can tell on the manual it says the power gos to ignition and the illumination switch goes to headlight or something. I think he needs to take the two wires apart. I think its blowing the fuse cause we have both the illumination switch and power wire spliced together.
Serious Business...
Old 05-23-2009, 04:25 PM   #10
battleversiontc
nah shouldnt not unless thats the main power it needs to move the windows
Old 05-23-2009, 04:40 PM   #11
gwasabi
yups it is the main power.
Serious Business...
Old 05-23-2009, 05:57 PM   #12
battleversiontc
oh ok if its the main power you need constant 12 volts so hook em to the big black wire or the red wire off the alarm and the illumination is off the yellow wire coming off the alarm
Old 05-23-2009, 09:21 PM   #13
Taiyaki
アキバ製
Taiyaki's Avatar
Ok when I tap to the big black wire it instantly blows the fuse, I did I twice just to make sure. Ill try tap it to the alarm red off the largest harness and the yellow off the one next to it thats all stuck together.
here we go!
Old 05-23-2009, 10:08 PM   #14
Taiyaki
アキバ製
Taiyaki's Avatar
Ok hooked it up to the yellow and red wire of the alarm. and it blew the tach/radio fuse, but the power window was working, even with the car off it worked. then it stopped. Im not sure if I blew two fuses, but i replaced the tach/radio fuse and tried again.
It blew the fuse again, so i took the illumination tap off the yellow wire and replaced the fuse, and tried. It didnt blow the fuse but it still wont work. No power. But im not sure if I blew two fuses, everything seems to work.
edit: Pulled and checked all the fuses in the inside and all good. quite confused
Old 05-24-2009, 03:41 AM   #15
battleversiontc
ok so one of two things either it draws to much current or something is grounding out in the unit itself
Old 05-24-2009, 05:04 AM   #16
Taiyaki
アキバ製
Taiyaki's Avatar
I was thinking. Could I tap it to a 25 fuse and put it in the empty power window slot?
Old 05-24-2009, 05:15 AM   #17
battleversiontc
try hool em up to the battery straight
Old 05-24-2009, 05:32 AM   #18
Taiyaki
アキバ製
Taiyaki's Avatar
ok ill try that now.
Ok total newb question, the wire wont reach to the engine bay, I dont know what gauge wire it is. could I use a smaller or bigger wire? or does it have to be the same gauge?
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
Need help picking a good indash monitor BelleOfPistola In Car Entertainment + Electronics (audio / video / alarm) 14 08-22-2007 01:25 AM
Any good lease deals out there right now? sherryberry Off-topic / Other Cars / Everything else Discussions 5 07-02-2007 04:02 PM
a good slide show derekjd Photo-Video-Media Gallery 0 05-10-2006 03:26 PM
Is this a good deal? YotaYarisUSA General Yaris / Vitz Discussion 2 04-09-2006 12:29 AM
