Old 08-22-2006, 02:25 AM   #109
RoninMax
Drives: Yaris 3 Dr, AE86
I think the biggest problem is the camshaft. There is no one out there to make aftermarket performance camshaft. You can put a ITB on the 1NZFE but the stock camshaft is so low lift than the ITB set up is usless. I am always a NA guy. On the other hand, the Blitz supercharger is a pretty good piece since you can choose to start you supercharge in OFF, LOW, MID, HIGH. So if you dont want to use the supercharger, you can just turn it off.
Unlike the Greddy one, They are always on.
Maxwell Arancon
Pass Racing Inc
148 S.8th Ave, Unit F
Industry, CA 91746
626-961-6284
626-369-4418
RoninMax is offline   Reply With Quote
Old 08-22-2006, 11:27 AM   #110
ChinoCharles
Drives: LB
While we are on the topic of N/A, what do you guys think are realistic numbers for a done up N/A Yaris? We're talking pistons, rods, cams, ITB's, everything. I always had more respect for people that tuned their cars without the use of FI. However, I don't think the 1NZFE is potent enough to put up any kind of numbers without FI. What do you all think?
Old 08-22-2006, 06:59 PM   #111
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
I think it really depends on how much money you want to put in it... look at the much more primitive 4AGE... look at how much power the Forumla Atlantic version makes... I'm sure the 1NZFE could be built to have similar numbers to that, but it'd be mostly useless on the street. I assume you could get near what the greddy charger gives and still have it be streetable.
heylookitsjames is offline   Reply With Quote
Old 08-22-2006, 08:16 PM   #112
riceboy
Drives: icebox
but why sink so much money into this car?? having a nice looking customized car w/ some pep is one thing.. but putting anything more than 10g's is getting kind of out there...
riceboy is offline   Reply With Quote
Old 08-22-2006, 09:55 PM   #113
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
I must admit I don't read all reply to that threat. Just by reading the initial question, I think it doesn't make sens. "Yaris" and "performance" in the same phrase doesn't make sense. "Yaris" and "cheap car", or "fuel economic", or "reliable cheap car" is more credible.
I don't buy an Echo for performance, I buy it because it was cheap and the fuel economy is awesome. It was very reliable too.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 09-23-2006, 06:59 AM   #114
As far as I know the engine should be able to handle a good amount of power from a turbo. Here in Thailand there is another car called the Soluna Vios, basically a mini sedan, which also comes in a factory turbo version, but the engine is the same as the Yaris, and does 143HP. Here's abit of info:
http://paultan.org/archives/2005/11/...ta-vios-turbo/
So in theory it may be possible to transplant that engine into a yaris :D
Old 09-23-2006, 01:11 PM   #115
ChinoCharles
Drives: LB
Interesting...
Old 09-26-2006, 04:59 PM   #116
w1ngzer0
w1ngzer0's Avatar
Drives: Subaru Impreza
Originally Posted by birdy
i think with this motor just get intake exhaust and header and be done with it and then get coilovers, sways and kick ass
Don't forget engine management
w1ngzer0 is offline   Reply With Quote
Old 09-26-2006, 08:59 PM   #117
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
probably be cheaper to just swap in the 2zz, or even maybe a k20 motor to get good power. It is very doable, and you'll be making more power then the car could ever make NA, or with a turbo by just adding a stock motor swap. The recent super street had a honda fit on the cover with a k20 making around 240whp!!!
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 09-27-2006, 12:22 AM   #118
sam07yaris
sam07yaris's Avatar
Drives: 07 yaris sedan (silver) STICK
K20 swap with exact engine mounts to a 2z yaris engine? Are pigs flying or what?lol
sam07yaris is offline   Reply With Quote
Old 09-27-2006, 08:42 AM   #119
soros151
Another question... :D
soros151's Avatar
Drives: Scion tC 06
VERY TRUE!!
*One tire nearer to my goal*
soros151 is offline   Reply With Quote
Old 09-27-2006, 11:24 AM   #120
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
What does your statement mean exactly I don't get it??
K20 swap would probably be the best upgrade as far as swaps go. So what if your going with a Honda engine. Probably will need to get Custom Mounts, but the car will be a beast. Considering it weigh it lot less then the rsx also.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 09-27-2006, 02:02 PM   #121
ChinoCharles
Drives: LB
Eww, Toyota with Honda engine. Stay true to your manufacturer, kiddies.
Old 09-27-2006, 02:27 PM   #122
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Honestly though if your looking for is performence out of the Yaris then who cares what you put into it.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 09-27-2006, 04:17 PM   #123
ChinoCharles
Drives: LB
If you're looking for severe performance out of a Yaris, you should have bought a Fit.
Old 09-27-2006, 04:24 PM   #124
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
I agree! That is why I didn't buy the Fit
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 09-27-2006, 04:33 PM   #125
soros151
soros151's Avatar
Drives: Scion tC 06
I really would enjoy a more toyota way, since the car u are using is a toyota. Cause if you are going with the engine of another brand greater problems will arise as plugs and electronic signals from other components. We are talking here, I think of a DD Yaris with 2ZZ swap, which I think is more..."in the line".
Old 09-27-2006, 05:27 PM   #126
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Has anyone read about the Mazdaspeed 3?
Nearly 300 HP in a Yaris would be insane... no?
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Mod's List riceboy General Yaris / Vitz Discussion 43 07-25-2006 10:49 PM
How strong is this engine? UndefinedDesign Performance Modifications 27 07-08-2006 10:45 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
engine modify for d-4d uraz General Yaris / Vitz Discussion 0 02-20-2006 03:16 PM
