Old 02-05-2009, 12:21 PM   #109
Jerkratt
Jerkratt's Avatar
well i see that the suv's have slightly fatter side markers then the normal cars.. so im going to go to the dealer and take mine out and size them... im going to measure the hole opening aswell and bring a ruler with me to the dealer so i can see if there will be a gap
"It hurts more when its wet"
Old 02-05-2009, 03:06 PM   #110
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Easier idea... pop out one of your side markers, hold a piece of paper on the side of your car, and trace the outline of the hole. It'll be easy to see if the BMW marker will cover it then.
2006 Red Blitzed RS 5-door
Old 02-05-2009, 06:03 PM   #111
Jerkratt
Jerkratt's Avatar
i went there today and got some part numbers... im going to go back next week and have them give me one of each and compair them.. the 3 series does not fit correct...
Old 02-05-2009, 06:43 PM   #112
Jerkratt
Jerkratt's Avatar
2 1/2" x 1" is the opening of the fender
Old 02-06-2009, 04:55 PM   #113
MadMax
MadMax's Avatar
alright, another bump for the updated thread, since I sell these since those old days (smoked or clear):
I got my set in the mail today (thanks Garm! ) and they are 'plug and play' but the other end of the harness has to be plugged in to a certain polarity so if they don't work just unplug 'em and swap the plug around to reverse what you had the first time!
Now, I could still use a little help. These new side markers are a bit loose on my car. The original ones were a tad loose; but these are much looser, almost to the point where you can pull them off the car quite easily. So, I was wondering if 1) anyone else had this problem, and 2) if they did, what did they go to fix it?
Cheers! M2
Old 02-06-2009, 08:58 PM   #114
MadMax
MadMax's Avatar
OK, no advice then, huh? I was wondering if some silicon adhesive or sealant would be the way to go...thoughts?
By the way, I went outside now that is dark and this is when the side markers that Garm sells really shine! They are much brighter and noticeable than the stockers, and a heckuva look cooler looking! The blend in much better on my black hatchback, I'll take some pics over the weekend to show everyone.
This is a great mod, easy to do and not too expensive!
Cheers! M2
Old 02-07-2009, 01:51 AM   #115
kou
Drives: 08 lb
Just paint the stock ones with TAMIYA PS-31 SMOKE great results and very easy, still shine super bright at night and day had them on for two years and they look like they were done yesterday.
Old 02-07-2009, 01:53 AM   #116
madmax, I would use a spot of silicone to get those to not move around.
kou, those look pretty good!
Old 02-07-2009, 01:54 AM   #117
kou
Drives: 08 lb
Thanks cali.
Old 02-07-2009, 04:36 AM   #118
StefanVVTi
VVTi lover | D-4D driver
StefanVVTi's Avatar
Drives: 1.6 Corolla & 1.4 D-4D Yaris
Send a message via Yahoo to StefanVVTi
@ kou: they look very nice! how did you take the part to be smoked off the whole thing?
(2006) - 1.6 VVTi Corolla & (2008) - 1.4 D-4D Yaris
StefanVVTi is offline   Reply With Quote
Old 02-07-2009, 11:50 AM   #119
MadMax
MadMax's Avatar
I did the same thing as kou with a set of flush motorcycle turn signals, except using orange paint (the bike is orange where they are), also Tamiya. I will see if I can find the instructions but it is pretty easy. It is pretty much remove the marker lights (easily done), cut some cardboard so only the outside is exposed (make the holes like the ones in your fender), and put on numerous light coats letting dry for about 10-15 minutes between each. Continue to do so until you reach the desired color.
Garm, thanks for the tip on silicon, I will get some today. The marker lights you sold me look excellent!
Cheers! M2
Old 02-07-2009, 12:22 PM   #120
StefanVVTi
StefanVVTi's Avatar
Did you spray them on the outside?
Old 02-08-2009, 11:10 AM   #121
kou
Drives: 08 lb
yes, just take them off the car clean them then spray them.
Old 02-08-2009, 11:25 AM   #122
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
What side marker of the SUVs did you compare? The X3 or the X5? Or even maybe the X6....
thanks for the sizes bro.
Old 02-08-2009, 01:03 PM   #123
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
In Europe the side markers are clear on the Toyota Yaris. If anybody need a pair I can buy them for you and ship them.
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 02-08-2009, 03:05 PM   #124
StefanVVTi
StefanVVTi's Avatar
Thanks a lot! I`ll probably do them next weekend!
Old 02-08-2009, 05:27 PM   #125
MadMax
MadMax's Avatar
Originally Posted by Danish Yaris View Post
Hi
Regards Steven.
Steven
The side markers in the US are clear as well, they are the same ones I saw in Germany, Austria and the UK; which is why folks here are painting or replacing them...
But it was very nice of you to offer!
Cheers! M2
Old 02-09-2009, 12:29 PM   #126
Danish Yaris
Hi
Ok, I thought they were yellow in the states.
I work at Toyota in Denmark, so if you need some special European parts I can help you guys.
Regards Steven.
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
xb side marker swap? funkstrong Cosmetic Modifications (Exterior/Interior) 4 10-25-2006 11:32 AM
Fog Lights - only right hand side JayCee Cosmetic Modifications (Exterior/Interior) 3 09-26-2006 05:44 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
