Old 04-11-2007, 06:21 PM   #109
BailOut
Steals terrorist's lunch
BailOut's Avatar
hmmm, now you have me worried, but then again, Black Yaris said that the Prius comes with that weight and viscosity oil.
Never confuse the engine in the Yaris with the one in the Prius. Even though they have the same designation (1NZ-FE) there are 2 major differences between them:
1) The Prius' ECU runs the engine in an Atkins cycle which involves a longer spark at a lower temperature (for ionization) and requires less fuel as it burns more thoroughly but at a lower RPM/torque level. The Yaris' ECU runs the engine in a typical Otto configuration which involves a short and hot spark at the top of the compression stroke. This means the Yaris' engine runs at higher RPM and hotter.
2) The Prius' engine is almost never in a direct wheel feed scenario. The engine feeds to the HSD and the battery (which in turn runs the electric motor), and the HSD plays a hardcore game of matching inputs from both the engine and motor to produce torque in the CVT. The CVT in turn plays a hardcore game of balancing torque input and output to produce movement. These systems are a far cry from the Yaris' direct feed to either a transmission (MT) or torque converter (AT) which immediately convert torque to wheel drive.
The point of all of this is that the Prius' engine only receives about 1/3 the beating that the Yaris' does. As such you can get away with a lighter oil in the Prius than you can in the Yaris.
As with most other things sticking to the manufacturer's recommendations is best, and Toyota says 5W-30 for the Yaris.
- Brian
Share the Road
Old 04-11-2007, 11:34 PM   #110
what about the TSB's that were mentioned earlier?
Old 04-12-2007, 12:01 AM   #111
BailOut
BailOut's Avatar
I'm not saying that TSB doesn't exist by any means but no one ever provided the text of it or even the reference number of it, and I can't find anything on it myself. Without it we have no idea what the reasoning was, when the option applies, if it's valid for all regions and temperature patterns, etc.
As such sticking with 5W-30 is a safe bet and covers a huge temperature range. This is important to me because between where I live and work there is a 4,500ft elevation difference. In the Winter my car can experience temperatures as low as 14F with a wind chill of -20F and in the Summer it can experience temperatures as high as 100F. Because this is a high desert just our night and day delta can be 40F+ (i.e. 49F at night and 89F during the day), and the delta between my home and work can be as much as 30F over a 40 minute commute.
Besides, just switching to synthetic vs. standard oil will net you the most MPG gain. You won't see as much performance or MPG difference between different synthetics like 5W-30, 0W-20 and 5W-20.
Edit: Additionally, the person that was most adamant about that TSB was also the most adamant about a 5,000 mile drain interval. This shows an utter lack of eduction concerning modern synthetics which are commonly good for 7,500 miles, with some going as far as 15,000. This makes any information on this subject from that person suspect.
- Brian
Share the Road
Old 04-12-2007, 06:56 AM   #112
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Don't know about the TSB on the lighter viscosity....but are you saying there is a TSB on going further than 5,000 between changes by Toyota? Because only thing I've seen on that is the 5,000.....seems to me that Toyota should be the higher authority on their car than the oil marketing team! IMO by the way....
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 04-12-2007, 08:16 AM   #113
Black Yaris
der Zeck
Black Yaris's Avatar
me being adamant about the drain interval has nothing to do with my education about oil and synthetics. My choice to change every 5000 has to do with with being a new model year car and things are going to happen, lets say I do have a warranty issue down the road and they want my records of my oil changes every 5000? That is the main reason I am changing every 5000 untill warranty is up... after that every 10k, because my oil is still clean after 5000 miles, but it is the price I am going to pay to adhear to my warranty scheadual. This is all information I stated earlier in the post so if you would do as much as READ you would not make FASLE accusations.
Old 04-12-2007, 08:17 AM   #114
Black Yaris
der Zeck
Bailout is here just to confuse you churp just keep changing your oil every 5000 like you are supposed to
Old 04-12-2007, 10:02 AM   #115
BailOut
BailOut's Avatar
A TSB can be issued against something like viscosity because that follows an industry standard unit of measurement. Drain intervals, however, do not, and are subject purely to the creator of the oil.
On a lighter note, if you're that worried about Toyota's wishes then maybe you should stick with standard oil. That's what your car shipped with, after all. ;)
Everyone here needs to realize that the drain interval debate is purely opinion on all our parts. Some like to think conservative while others like to take advantage of new science and technology. By all means stay with 5,000 mile changes if it makes you feel more secure, but I'll only be making 1 trip to the lube shop while you make 3, and we'll each have the same level of engine protection.
- Brian
Share the Road
Old 04-12-2007, 02:02 PM   #116
i see what Black Yaris is talking about with the 5000 mile intervals.
Old 05-05-2007, 04:12 PM   #117
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
i can't even find Amsoil anywhere here in Sac.
The tuning shops in sac sell em bro! --octane motorsports in citrus heights, whiplash performance along Madison Ave., and we got comptech..but they're in el dorado tho. u might wanna do a quick search! i used to buy redline oil at Trick Racing in Rancho Cordova when i had my prelude, but that was 4yrs ago, dunno if they're still there.
___
i've been using mobil 1 ep 5-30 eversince 3000. kaotic, u know i drive a lot. it's good stuff if ur driving as much as me.. i just don't wanna stress out on changing oil every month. saves me downtime and money, plus the reliability of of a good synthetic is there.. i'm switching to redline or amsoil on my next oil change.. but since u don't drive as much.. u can just stick to full syn.
barebonedvitz is offline   Reply With Quote
Old 05-05-2007, 09:23 PM   #118
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
http://neptune.spacebears.com/cars/s.../oil-life.html
My family used Amsoil in heavy equipment for years with high quality filters like Wix. Our equipment received regular oil analysis as this heavy metal was more then quarter of a million at a pop. Having said that I really like Amsoil!!! Just because it is black does not mean that it is not working better then brand new dino butter.
blacksan is offline   Reply With Quote
Old 05-06-2007, 12:27 AM   #119
___
yeah, i think i'll just stick to Mobil for now. come back in to L&L yo.
Old 05-06-2007, 02:09 AM   #120
barebonedvitz
i myt drop by next week man! my girl lives near by, so most likely i'll be seein ya soon! haha
Old 05-06-2007, 05:23 PM   #121
cool, i work Saturday mornings, Sunday evening, and Monday evenings.
Old 09-20-2007, 11:12 AM   #122
PolarWhite
PolarWhite's Avatar
Drives: '07 Polar White Hatchback
Smile
I am new around here. I just bought my Yaris about three weeks ago. I am an automotive lubrication specialist. I have always run full synthetic or high mileage oil in anything I own. A couple of things about your Mobile 1 synthetic oil that everyone is touting on here. Read the fine print on the back of the bottle. It very clearly states that if you fall under severe driving conditions you can't run the oil for 15,000 miles. All synthetic oils, excluding Amsoil, will tell you not to exceed the mileage in your owners manual while under warranty. If you do some research, Amsoil is the only synthetic oil out there that is preaching extended drain intervals. The purpose of a full synthetic oil isn't so you don't have to change your oil. The reason behind synthetic oils is better lubrication which reduces friction which in turn reduces heat buildup which destroys an engine over the life of the vehicle. Synthetic makes cold starts less harmful as well. Also, if you look at the Toyota issue they had with sludge or oil gelling, one of the contributing factors of the problem was extended drain intervals as well as the design of the engine. Why would you want to take a short cut when it comes to the life blood of your vehicle anyway. If you can't afford to maintain a car properly, you can't afford the car in the first place. Cars need regular oil changes, air filters and other fluid changes listed in the maintenance schedule of your owners manual. You might be amazed how long a Toyota will last IF properly maintained for the life of the vehicle. As some stated earlier, everyone has an opinion and that is just my .02 cents.
'07 Polar White Liftback, 15in Alloy Wheels, Exhaust Tip, Cruise Control, Tinted Windows, TRD Valve Caps, PadsPlus Pads,
PolarWhite is offline   Reply With Quote
Old 09-20-2007, 03:40 PM   #123
my cousin's old Cressida lasted 400k before the engine finally gave up. as for me, i'm sticking to the 5k interval for the warranty purposes. afterwards, i think i'll change at 7,500 if conditions where i live permit me.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 08:15 PM
Oil Question 91drggndime DIY / Maintenance / Service 7 03-23-2007 06:52 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 08:44 PM
