#109 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
Yeah, that was actually the engine backfiring. With how much has changed the cold and hot tunes need to be adjusted a fair amount. We also need to figure out the fuel issue.
Sent from my XT1575 using Tapatalk
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#110 |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
![]() Sounds amazing! BTW, what tails are those, altezza? |
#111 |
The tails are spyders. Mine are the smoke version. Not sure if carid still carries the smoke, but here is the link to the standard ones:
http://www.carid.com/2007-toyota-yar...ts-439658.html Sent from my XT1575 using Tapatalk
#112 |
As previously stated the hydrodipped CF valve cover was damaged due to rubbing issues so I decided to have the cover PC'ed to match the new IC piping. Also upgraded the valve cover bolts to an ARP set which looks much better and will stand up to conditions for a long time to come. Unless mistaken I am now 100% completed under the hood.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my XT1575 using Tapatalk
#113 |
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
That color is beautiful and almost distracting enough to hide that big snail attached to your Yaris lol
#114 |
Yeah I really love the purple for sure. We installed a shorty bullet stainless racing muffler yesterday. Really lowered the tone of the exhaust to a nicer less ricey note however didn't do much for reducing the db. I am thinking the only way to tame that is with another chambered muffler, but don't want to reduce performance.
#115 |
Brought her home from the shop today and she is definitely running super rich. All that extra air makes a big difference. Working right now to figure out the schedule to take the car down to the Dyno and hoping to do it within the next 30 days. Can't really come to soon.
#116 |
That's great news, one last step in the way for you to set new land speed records. Should we start guessing how much she'll put down?
#117 |
If you would like you can. I had hopes for certain numbers last year however learned to not count chickens before they are hatched. We are fighting with over boost situations right now and still the fuel pressure gauge not watching to cooperate. These will need to be resolved first. I have a 12psi spring in the wastegate so by what AEM says their boost controller does the max boost should not go over 24psi. The big problem is that my current boost gauge only goes to 20psi so I will need to invest in a new one.
#118 |
Over boost? Do you know what's causing that on your setup?
#119 |
We aren't sure just yet. I had been set at 15 across the entire rpm range previously, but we have buried the needle at 20 the few times we have tested wot. It isn't over boosting per the controller ability AFAIK by the data logger, but still needs to be figured out since the fuel quality here isn't good enough to be hitting 20+ for me and feel comfortable.
#120 |
Ah ok, so i assume there is no E85 locally where you live or you want to stay with 91/93? So a 5 psi overboost and she held together? That is a dang good tune.
#121 |
No e85 for at least 400 miles. Plan is street tune with 91 while still in Maine, then 93/95 in TX. Race tune will be with c12. My fuel pump isn't the model for use with e85, but everything else will support it.
#122 |
Sounds like a good plan, congrats on moving to a state with far friendlier car atmosphere. Curious how much the higher temperatures in Texas will affect your land speed runs.
#123 |
All goes well I will be able to tell you in October. Plans are to race in the Texas Mile at the least and possibly the Arkansas Mile as well.
#124 |
![]() Drives: Yaris Tsport Join Date: Dec 2015
What compression ratio do you have.
I ran 33,5 psi on pumpgas oktan 93. Is the overboosting in 4-5 gear, mabey wg is to small. Do you have boostcreep in lower gears ? |
#125 |
CP 9:1 pistons. We will figure out the boost issues once we get down to the Dyno. What were you running 33psi of boost on?
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. Last edited by fnkngrv; 12-27-2015 at 10:38 PM. |
#126 |
Well, 33psi is maney abit to much at 9-1 :-)
Ran it on my starlet 5e engine, but the compression was low around 8-1 |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| Whats needed to turbo charge the yaris? | Arkhangel | Forced Induction Forum | 44 | 03-02-2009 10:08 PM |
