#109 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
So what would be the ideal transmission for those interested in a 2zr swap AND a auto>manual trans swap? Can we do a pros VS cons on the available transmission choices?
#110 | |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Stock Yaris C50 - Bravery: Sir Robin Pro
Stock xD C50 - Bravery: Sir Galahad Pro
Custom gearbox internals - Bravery: Black Knight Pro
#111 |
Data doesn't lie
^that is awesome! Thank you!
Im also starting to contact the Lotus guys to see how the 2zr handles track abuse and if it needs cooling upgrades
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 12-22-2015 at 11:49 AM. |
#112 | |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
I'm in the frozen north, land of Igloos and Universal Health Care............so having a paid swap done in the USA is out of the question. This seems a little bit easier than a K20 swap Will |
#113 |
Data doesn't lie
UPDATE: Ive completed my move to San Diego and have started searching for 2zrfe's. Ive found a few at dismantlers out of Corollas for $850-1000....but not complete engines. I will be purchasing one of the longblocks to test fit with a Yaris clutch and transmissions asap.
#114 |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
I've been watching this post from the start and have been wondering if there is a more common (AKA cheaper) LSD option for the XD? Or another trans that bolts in?
Also, good job on the swap! |
#115 |
Generally, no. The "cheapest" option is a Phantom Grip, which still runs a few hundred dollars and requires complete disassembly of the stock differential to install. There was an OBX-made torsen style that was hit or miss for being a grenade for around US$700 iirc, but I haven't looked for them recently. You might be able to find an OEM LSD in a junkyard if the stars all align for you, but I use US$1000 as the benchmark for adding limited slip of any kind that isn't going to be a gamble down the road.
#116 |
Data doesn't lie
^What oem lsd are you referring to?
#117 | |
Cheers |
#118 |
Data doesn't lie
This is exactly my plan with my personal 2zr swap. I have a spare Yaris trans I will upgrade with the Xb final drive and a LSD....given That the yaris trans works with the 2zr.
#119 |
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
For what it's worth:
On toyodiy.com 2008 Toyota Yaris NCP91 with a 1NZFE 1.5 Liter engine, uses a C50 manual trans part # 30300-52360. 2008 Scion XD ZSP110 with a 2ZRFE 1.8 Liter engine, uses a C50 manual trans part # 30300-52360. Same trans, so my guess would be that a Yaris trans will bolt to the 2ZRFE engine, or at least in this case. I've got a 2007 Yaris with an auto, and if I did this swap, would go consider going manual, but the manual trans part number for my year is a 30300-52510. I bet the difference has to do with VSS sensor vs. getting speed off of ABS, as my car doesn't have ABS. Checked the auto trans part #s, they are different from a Yaris and a XD. I'm just wondering if you can run the Yaris computer with the 2ZRFE, or if you have to swap out with an XD computer? Last edited by beaker; 01-03-2016 at 07:39 PM. |
#120 |
Data doesn't lie
Wow...thats more evidence suggesting compatibility. Thank you.
Anytime you swap Toyota engines you are required to swap in that corresponding ecm. And yes the 2zrfe uses a different auto trans, I haven't looked into why though |
#121 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
If someone was in the market for a used Yaris and they did it smartly depending on how much equity they could have in the purchase it would be smart to roll the swap right into the note ;-)
Sent from my XT1575 using Tapatalk
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#122 |
sooooo........................................why aren't we also talking about the 2Litre- 3ZR-FE ?
Is it because its not as readily available in North America? Does anyone (CTScott???) know if it is dimensionally the same as the 2ZR ? (ie:, is it just a bored and stroked 2ZR?) Either way, I'm still anxious for more information because I was thinking about some other "next level" mods for my 1nz-fe, and it seems more cost effective to put that investment into a swap. Will |
#123 |
Data doesn't lie
We briefly discussed the 3zr, and yes it will probably work but like you said...its not available in the US. The 2zrfae just now showed up here and it was developed in 2010!
#124 | |
) ......................................Will |
#125 | |
#126 |
Data doesn't lie
I don't believe the 3zr at 150hp is worth the additional effort, and it would not be a legal option. The 2zr has n/a bolt-on potential to 150hp, or you can boost it like Lotus does
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
