Old 12-29-2019, 07:13 AM   #1
fredovvti
Drives: Yaris 07 HB
I change mines to LED and the different is BIG!! Try it!!
fredovvti is offline   Reply With Quote
Old 06-01-2020, 04:11 PM   #2
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
OK I was wrong last year about the Negative Switched, and before I go back out and start hacking on my cars (ok being too lazy, and at work, to go back out with my meter) I wonder if any of you experts know... IS The Positive Terminal on the H4 Halogen lights (Right at the bulb) "Hot" ALL the time?
OR Hot ONLY when The Headlights are turned ON?
Your Input is Appreciated!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 11-15-2020, 02:44 PM   #3
govtec
Drives: 2007 Toyota Yaris Hatchback
Hi guys, so after 3 years my low beams suddenly stopped working the other day. High beams and everything else works. I’ve checked the engine bay 10 amp fuse and they are fine. Any idea where I should look next? Thanks
govtec is offline   Reply With Quote
Old 11-15-2020, 05:17 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
ballast and bulb. its 90% most likely the bulb. both went out at the same time eh?
Old 11-15-2020, 09:39 PM   #5
govtec
Yes, at first I doubted both bulbs would go at the same time so I just ordered 2 D2R Osram bulbs from Amazon. I also tried switching out the headlight switch with a new one from Toyota and that didn't work. We'll see if the bulb solves it. Thanks
Old 11-22-2020, 06:34 PM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
wait you're using d2r with toyota ballasts? that might not be good...should be using d4rs... D2Rs use a good deal amount more energy to light up. It just might be your ballasts too!
Old 12-20-2020, 02:34 PM   #7
govtec
I ended up taking the vehicle to a local mechanic shop and they determined it was a bad relay. They changed it and put a new one in and it's working fine now. Where is the location of the low beam relay?
I used d2r because that is what the HID housing said to use. I also have a relay harness setup...https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-29-2020, 10:49 PM   #8
govtec
Quick question...Has anybody tried substituting the H4 male plug with a 9006 male plug to the 4 prong connector?...I'm finding that the cheap H4 relay harness is about to die on me and keeps flickering when I hit a bump on the road after about 3 years of use and I can't seem to find a quality H4 relay harness in the market. Morimoto makes a 9006 relay harness but will require a 9006 plug, so that is why I am asking this question. Thanks
File Type: jpg Screen Shot 2020-12-27 at 9.49.11 PM.jpg (83.5 KB, 44 views)
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 10:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 06:30 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 06:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 02:56 PM
