#109 |
Drives: Toyota Yaris Join Date: Jan 2013
hi there every one anybodyb know how to take the bottom half of the air box out, so I can have a proper look.
#110 |
To remove the bottom of the airbox you have to remove the entire dashboard, the metal support for the dash, and then the airbox itself. It may be easier to go into the air intake for the fan with an inspection camera if you want to take a look.
#111 |
Drives: Toyota Yaris 05 Join Date: Feb 2013
Hi, ive been reading this thread as I too have an issue with water in the passenger side floorwell front and back. I am not sure if it is my AC unit as over here in the UK we rarley use aircon and my outlet drain hose looks to be clear. I have had a piece of stiff wire in the hose and it went up to the AC unit without much resistance. I wasnt sure how far to force the wire as i am not sure if I will damage something.
Also my air blows with quite a bit of force through the drain pipe when the heater is on so I am asuming the drain hose is not blocked. The amount of water that is coming into the passenger side of the car is quite a bit, I often have a good half inch in the rear passenger well. I am suspecting its rain coming in somewhere!!! Does anybody know any suspect places for water to get in on the 2005 Yaris models? Thanks for your help on this one. Mud
#112 | |
Drives: plain simple silver yaris Join Date: Jan 2012
Clogged hose
Just wanted to say thanks for the tip |
#113 |
Drives: 08 Yaris Hatchback Join Date: Jul 2014
Shop vac did the trick
Hey guys first time poster here. Just wanted to say that just popping off the drain hose and taking a shop vac to it for less than a second did the trick of loosening the blockage, then just drained it into a pot.
I know some people think it's annoying, but it's a very quick fix if you've got a shop vac or something with similar suction. Better than poking the blockage back up into the hose. |
#114 |
Basking in Yaris luxury
Drives: 2009 3-door liftback Join Date: May 2009
Thanks!
Not really adding anything new to the discussion, but I wanted to say "Thanks" to everyone for your instructions and photos on how to deal with this problem. I just experienced it for the first time today, and using the info in this thread, I believe I've corrected the problem. I unplugged the hose and ran a hanger into it, then the water flowed forth. I plugged the hose back in and a nice pool of water soon formed under my little Bayou Blue pal. We shall see how things progress in the next few days.
Again, thanks for the help! |
#115 |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
looks like my kid has a problem with this. i instructed her not to use AC or fan and avoid sharp left turns. will try a wet vac after work.
scott's picture is very helpful: http://www.yarisworld.com/forums/sho...6&postcount=22 edit: the wet vac did nothing. i also probed and removed the rubber drain hose, no water or obstruction. where is the water coming from? Last edited by jack black; 07-20-2015 at 08:30 PM. |
#116 |
OK, i learned about this TSB 027-08:
http://workshop-manuals.com/toyota/y...r_rear_carpet/ the fix is a new cowl panel (55708-52170) "to help prevent debris from entering the HVAC unit". but i have a filter already, why would debris enter AC? anyhow, has anyone done that new cowl panel fix? BTW, the lowest i can find is $158 (before S&H) for that large piece of plastic. is it worth? Last edited by jack black; 07-21-2015 at 11:26 AM. |
#117 |
With the filter in place the cowl update is really not necessary. It would just reduce the larger particulate captured by the filter.
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Air Conditioner kick-in?? | churp | General Yaris / Vitz Discussion | 5 | 05-26-2007 08:43 AM |
| Air Conditioner Noise | Cathy | General Yaris / Vitz Discussion | 16 | 05-08-2007 02:08 AM |
| Air Flow switch problem | aucorium | DIY / Maintenance / Service | 5 | 01-15-2007 04:54 PM |
| 1.3 Ltr Yaris Air Filter mods | aucorium | Performance Modifications | 9 | 08-18-2006 08:32 AM |
