Old 11-23-2010, 08:43 AM   #109
djct_watt
Drives: 2010 NCP91 5spd
It works!!!!!! Awesome!!!!! I always hated not being able to adjust the dash brightness... I swear, adjusting it is about as clear as a super contra cheat code, but I'm glad it's there!!! Thanks Bella!
The best modification you can make is between the steering wheel and driver's seat.
djct_watt is offline   Reply With Quote
Old 11-23-2010, 09:48 AM   #110
djct_watt
Old 11-23-2010, 10:18 PM   #111
2007yariz
Drives: Yaris sedan
Exclamation
Originally Posted by DebbyM46227 View Post
I don't have a link about the oil, but my car was purchased new in June this year and the oil is / was clear...I could hardly see it on the dipstick. After being driven 3000 miles, the color is now light tan.
I'm wondering about the other statement.....where is the link that the maximum top speed should be only 68 MPH?
Hi Debby, sorry to break it to you, but "Oil color does NOT matter. Some people feel if a oil is not black it is not doing its job.
Others feel that clear like new oil is a better oil.
Bottom line is color does not matter.
Take care, Bill "(this is a quote from an oil site, i know i am an oil nerd lol...)
http://www.bobistheoilguy.com/forums...1674951&page=1
2007yariz is offline   Reply With Quote
Old 11-24-2010, 08:39 AM   #112
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I was just saying I thought mine was synthetic because it was clear oil when brand new. I don't like black oil at all.
DebbyM46227 is offline   Reply With Quote
Old 11-24-2010, 09:00 AM   #113
djct_watt
Oil is usually clear/yellow when new
Old 11-24-2010, 10:29 AM   #114
RedRide
RedRide's Avatar
A Yaris is more fun to drive when it's all paid for... as mine is.
Old 11-24-2010, 04:07 PM   #115
H3LlIoN
Drives: '09 Yarrrr hatch
Originally Posted by DFA View Post
If you have power windows, you can roll them up or down AFTER you've turned the car off.
Crazy! You can do that with the manual windows too.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 11-24-2010, 05:56 PM   #116
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
hell you can do that with the battery disconnected and the door removed from the car
Old 11-25-2010, 04:46 PM   #117
startree
startree's Avatar
Drives: 2009 Yaris YR: 3 dr hatch
hey my first post here, so hi all!
Thanks heaps for the tips, i'm going to spend some quality time with my yaris right now...
my tip, and i'm sure you all know this one: put your warm bottle of water or drink in the holder next to the steering wheel and put the air con on cool and angle the vents at the bottle and voila! ice cold drinks again!!
startree is offline   Reply With Quote
Old 01-07-2011, 05:11 PM   #118
TXyaris
Drives: Currently stock '09 Sedan.
Originally Posted by cookfreeordie View Post
You can have the dealership turn off that annoying beep when you dont buckle your seat belt.
for real? i was wondering about that... its so annoying
TXyaris is offline   Reply With Quote
Old 01-07-2011, 09:49 PM   #119
alch3miss
alch3miss's Avatar
Drives: Toyota Yaris
A Yaris equipped with TEIN basic damper coilovers delivers impeccable control! Check out my autox results here: https://axwaresystems.com/axorm/file...232009_fin.htm
alch3miss is offline   Reply With Quote
Old 01-07-2011, 11:13 PM   #120
Chuck G
Drives: 2010 Yaris Sedan
The Yaris steering wheel tastes of Peppermint.
Shhhh...........................................
Old 01-08-2011, 07:49 PM   #121
JetfireK
Drives: 2008 3 Dr Liftback
YARIS PLENTIFUL CUP HOLDERS....
ok this thread was lost so lets get it started again....
under the front passenger seat slide handle there is a flap in the carpet
with the VIN on it
Does anyone know how many cup holders are in the Yaris Liftback. The two up front allow the airconditioner to keep the drinks very cold . Then there is one on each front door...and there may be some in the back.
The cup holders are GRAND AND SURPASS OTHER AUTOS COSTING MUCH MORE...
JetfireK is offline   Reply With Quote
Old 01-08-2011, 09:08 PM   #122
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
2 in front of the vents
2 in the front doors
One in the rear of the center console
2 in the rear doors (on my 09 5 dr that is-not sure about the 3dr)
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 01-08-2011, 09:14 PM   #123
technoguy
Drives: Toyota Vitz 1.3L Auto 2005
Vitz 2005 Auto 1.3L Jap import doesn't have any indicator. With headlights ON, if you keep the button pressed when the odo showing total kms light just dims and then brightens, only two modes.
technoguy is offline   Reply With Quote
Old 01-08-2011, 11:36 PM   #124
MadMax
MadMax's Avatar
The 3-door has two cupholders (one on each side) where the doors are on a 5-door, so the total (7) is the same.
Cheers! M2
Old 01-08-2011, 11:37 PM   #125
MadMax
MadMax's Avatar
Crazy! The doors on my Jeep work that was as well!
Old 04-25-2011, 05:10 PM   #126
winfong
Drives: VIOS Belta
Originally Posted by drbilal View Post
Yes, I know we should all wear our seatbelts, and I do (95% of the time), but can someone tell me if the buckle has some sensor in it or can I get a buckle from the junk yard to plug in and stop the sound? If there is a sensor, how can I remove the buckle from the belt?
Check your Seat belt Latch (the one with the red button to release the Seat belt clip)....
There should be a connector attached to it somewhere - may have to unscrew the latch using a wrench to find it....
Disconnect the connector.... and no more Seat belt Beep....
I had to remove my Seatbelts to make way for a 4pt Racing harness
winfong is offline   Reply With Quote
Interesting Info on the Yaris from AU mikeukrainetz General Yaris / Vitz Discussion 3 11-24-2006 09:18 PM
