Old 10-23-2010, 07:21 PM   #127
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by spookz View Post
Actually, 1.5.. so it's pretty bad compared to what some of you are getting (>100whp?).. HAHAH =\
I'm guessing it's my tri-flow ruining my exhaust flow? What do you say Barber?
your numbers look fine, stock on a dyno dynamics is 86whp
Ptuning.com
Old 05-27-2011, 12:41 PM   #128
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
109whp 106tq
Here's my 109whp 106tq dyno pull
-Intake (custom)
-1zz TB
-Header (ebay)
-Exhaust (custom catless)
-NST Underdrive Pulley
-Apex Neo (dyno tuned)
Here's the video
http://www.youtube.com/watch?v=US7JO9s3ZXQ
I Drive a 129whp Yaris ;)
Old 09-28-2011, 02:18 PM   #129
well, i gave the yaris its final hurrah today
took it to forrest and forrest racing in ayr to run it on the dyno.
i ended up pulling 136whp and 130wtq
old pull was with intake and res-back exhaust (106whp/107wtq)
new pull was with same intake and res-back exhaust as well as dc header, blitz supercharger, 1zz injectors, colder iridium plugs (136.2whp and 129.8wtq)
im pretty happy with that.
Old 09-28-2011, 02:26 PM   #130
^ Very nice. Great that you recorded that for Yaris Historians everywhere!
Old 09-28-2011, 03:08 PM   #131
ya, shows a consistent 25% at-wheel gain
Old 09-28-2011, 05:34 PM   #132
Jason@SportsCar
Here is our latest... Stock motor with bolt-ons and an AEM EMS series 2.
This is on a Dynapak.
Old 09-28-2011, 08:51 PM   #133
^ how much power does the AEM EMS add on it's own?
Old 10-01-2011, 04:09 PM   #134
Maitre_Te_Te
Drives: Yaris 08
this is my dyno run
I have:
DC sport headers
Nito exhaust (Tanks MicroImage)
Borla
Next mod, FIC and mayby... piston prius 13:1 compression with water/meth !!!
Maitre_Te_Te is offline   Reply With Quote
Old 03-23-2012, 01:10 PM   #135
Nanoss22
Drives: Yaris sedan 10 std...
Dyno pull...
Intake"custom" pvc made
1zz tb
header " toyota echo"
2" exhaust ending with Magnaflow " free flow 2 1/4"
Apex vafc
Some minnor problem with the air/ fuel @ 5.5_6.0
Nanoss22 is offline   Reply With Quote
Old 03-24-2012, 11:10 AM   #136
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
2010 sedan, 27,2xx miles
-gutted air box
-removed snorkle
-Apex-i drop in high flow filter
-Amsoil Synthetic 0-20w & 75-90w
-Weapon-R header
-MBS Exhaust...2" mandrel bent with race 100cell catalytic converter
the green lines is after RS*R RanUp additive was added & cycled thru approximately 30min...
video;
http://www.youtube.com/watch?v=JIosaoHkS0c
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-01-2012, 12:35 PM   #137
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
My Stage 2 kit vs Stage 1 kit
Tuner did a conservative base tune to run in the engine
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 04-01-2012, 12:42 PM   #138
^ Amazing. What's your boost?
But -- Power and torque don't cross until 7000? That's not quite right.
Old 04-01-2012, 01:05 PM   #139
changchewsoon
Drives: Vios Turbo
Hi Garm,
That's because of 2 reasons:
1. The torque measurement is calculated using kg-m instead of ft-lbs
2. I didn't apply force scaling
Now they should be crossing after I've updated the torque measurement to ft-lbs and applied force scaling.
I'm running 23 psi of boost at the moment.
Old 04-01-2012, 01:24 PM   #140
That short runner intake manifold sure helps with the top end power, she wants to make power through redline - that's great!
What is your exhaust manifold design? I'm redesigning mine to try and regain some of that lost torque from the intake side.
and -- what fuel are you using for these numbers?
Old 04-01-2012, 01:25 PM   #141
Zoiks!
Old 04-01-2012, 01:30 PM   #142
changchewsoon
Drives: Vios Turbo
Hi garm, I am currently using Golden Eagle's intake manifold, however when they designed it for me it was still a prototype model.
I've yet to feedback to Bob Woodcock about it. I think I shall do it soon.
I am running on pump gas at the moment. Can't afford to use race fuel and drive around town to run in the engine, think I will break a big hole in my bank account if I do so :(
Old 04-02-2012, 11:35 AM   #143
malibuguy
Obsessed with 1.5L
Fucking nuts
-96 Tercel 4dr
Old 04-03-2012, 01:35 PM   #144
malibuguy
Obsessed with 1.5L
Like crap?
-96 Tercel 4dr
WR Yaris Intake Picture & Dyno. WRLEO Performance Modifications 37 04-05-2007 07:02 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
