Old 09-19-2013, 09:20 PM   #127
Just take the drums off and clean the dust out. The squeak should go away.
Old 10-11-2013, 02:35 AM   #128
Tarryn
Drives: Yaris T3 Sedan a/c
Originally Posted by Lafiro View Post
Hey thanks, but can you post a furthr away picture, and then a closer one please because Im having trouble finding this.
i'm also having trouble with this - did you get the further away pic??
Tarryn is offline   Reply With Quote
Old 10-23-2013, 02:21 PM   #129
aacceerr808
Drives: Yaris 2007 hatchback
Exclamation
Just asked the service advisor at my dealer about lubricating the manual transmission components and he said they never need lubrication because they are all sealed.
Huh?
Funny thing is that a mecanic from a local shop told me the same, he said I'll have to remove the transmision to lub it... . my biggest squick was when I press the clutch pedal, was making a huge squick! The toyota dealer fixed it for 28$.
aacceerr808 is offline   Reply With Quote
Old 10-24-2013, 01:34 PM   #130
esse10
Drives: 2009 yaris 2 door
Tranny squeak
Has anybody figure out how to lube the inside transmission clutch fork pivot area? I mean without removing major hardware. red arrows in this picture.
File Type: png toyota-yaris-clutch-parts-components.png (36.8 KB, 305 views)
Old 10-24-2013, 10:03 PM   #131
Nigel8600
Drives: 2008 Yaris Sedan
I also just oiled the yellow circled section and the problem went away immediately. When I had the car up on my ramps doing the gear oil I gave it an extra shot of spray from underneath too for extra luck. Unfortunately I used silicone spray because it was on sale for 2.50 a can and the white lithium grease spray was 8.99 lol.
Nigel8600 is offline   Reply With Quote
Old 11-02-2013, 01:29 AM   #132
Nigel8600
Soooo, for the record, my silicone spray lasted only 1 day per lube. I sprayed with white lithium that I had to go back to the store and buy 5 days ago and its still not squeaking. Don't waste your time with silicone spray.
Old 09-27-2014, 07:30 AM   #133
Dmonte
Drives: 2007 yaris sedan 4d
Does this also apply to automatic transmissions? Because my car has had a similar squeek for 3 months now ...
Dmonte is offline   Reply With Quote
Old 09-27-2014, 09:40 AM   #134
No. An automatic does not have the mechanism that this thread is discussing.
Old 02-18-2015, 07:58 AM   #135
pightzter
Drives: Vios 2014
hey guys i just registered. im from the philippines and got a 2014 vios which is sort of a sibling of the yaris. found this thread due to a squeak in shifting gears (manual). so anyway thanks to the thread starter my problem got a quick fix instead of lining up in the dealership. i used an ordinary oil lubricant with paintbrush and glazed the joints.
the cause of the squeak, as recalled, was by engine wash. some newbie overdid it using a pressure wash. so a tip out there for squeaking shift gears after an engine wash, the grease from the shift joints inside the engine bay must have absorbed some water and in the process pushed away some of the lunricants.
hope this reply helps.
super thanks to this thread!
pightzter is offline   Reply With Quote
Old 03-28-2015, 02:27 PM   #136
Mikastef
Can this work in an automatic gearbox?
Mikastef is offline   Reply With Quote
Old 03-28-2015, 10:28 PM   #137
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
No, the auto gearbox does not have the clutch lever. Must be something else.
Old 09-18-2015, 11:58 PM   #138
xdarkxfirex
Drives: 2015 yaris le
What about the automatic? I get a squeaking sound shifting into d or taking off most times
xdarkxfirex is offline   Reply With Quote
Old 09-19-2015, 09:33 AM   #139
could be a bad motor mount
Old 11-18-2015, 04:59 PM   #140
esse10
squeak
Anybody figure out how to lube the inside of the Clutch release fork boot pivot point? blue arrow in this picture.
File Type: png toyota-yaris-clutch-parts-components.png (36.9 KB, 300 views)
Old 11-18-2015, 05:02 PM   #141
I just stuck a straw in there from a can of lithium grease and sprayed. I also sprayed it on all the shift linkages on top of the transmission. My squeak went away and has been for a couple months now.
FWIW I had a squeak when i'd depress the clutch pedal
Old 11-18-2015, 06:23 PM   #142
esse10
ok
oh okay, I was skeptical about doing that cause you don't want to spray the clutch disc or something that'll cause more harm or start slipping. I was thinking if maybe I can get a camera probe in there to see what specific parts to lube or not.
Old 11-18-2015, 07:32 PM   #143
I just made sure I didn't direct the straw directly in the direction of the clutch. Haven't had any issues since.
When I swap out my flywheel and clutch this summer i'll be adding a lot of grease to that area to ensure no sqeaking happens again.
Old 02-15-2016, 01:13 AM   #144
RiceCake
Drives: 2007 Steel blue yaris sedan
This is a definite fix!!! I've been looking everywhere for an answer and am so glad I stumbled upon this forum. So many useful guides!! Thank you again for the fix!
RiceCake is offline   Reply With Quote
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
