Old 04-23-2009, 01:12 PM   #1
jkuchta
Drives: 2007 Yaris hatch (red)
Yes....I would leave it on and see what happens.
jkuchta is offline   Reply With Quote
Old 04-23-2009, 03:23 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i did after the chip swap for a day or so. give it some time.
Old 04-23-2009, 05:54 PM   #3
MGargano
Drives: 2009 Yaris Hatchback
I'm gonna leave the stock one on for a week or so and then start over with the chip swap. Glad to hear I wasn't the only one having this problem.
MGargano is offline   Reply With Quote
Old 04-23-2009, 07:33 PM   #4
mikenacarato
SIPNDEW
Drives: 15 STI
:) mine still cold idles high for a min but it goes down to normal after that
Old 04-23-2009, 08:08 PM   #5
severous01
ok.......
here's the deal....again...for you who will listen now
you can stop the oscillation in less than ten minutes.
after the swap, pull the plug on the battery, drain caps by hitting brakes and turning on lights
plug in batt
start car AND LET IDLE FOR 10 MINUTES
you have to re-learn the iac sensor to the new throttle body...it is oscilating to learn the position of the iac motor....unless you have a vac leak somewhere.
Old 04-23-2009, 08:35 PM   #6
MGargano
Originally Posted by severous01 View Post
ok.......
plug in batt
Yeah I did that... didn't help at all. I disconnected and drained the battery before I even removed the TB.
Old 04-24-2009, 07:56 AM   #7
bxrich
bx in the house
Drives: toyota yaris sedan
quick ? guys what's the diameter on the 1zz tb is it 2" & half or 3"
bxrich is offline   Reply With Quote
Old 04-24-2009, 07:59 AM   #8
yarstar
Drives: 2008 Absolute Red HB
Mine's on the car, so I can't really measure it right now.
Do a search. It's on here. I think in the Performance Mod section. There's a picture of both TBs and the exact measurement of each.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-24-2009, 08:35 AM   #9
bxrich
bx in the house
will do thanks
Old 05-02-2009, 04:43 PM   #10
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
stock yaris 1nz tb is 2"
1zz tb is 2.5"
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-03-2009, 01:50 AM   #11
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
1zz tb is 2.5"
i think 1nz tb is 2.25"
no?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 05-04-2009, 05:39 PM   #12
eii
Rides canyon walls
eii's Avatar
no?
Pic of my 1nz tb now a paper weight on my desk <3
Old 04-24-2009, 12:43 PM   #13
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
been 2 days anyone got rid of the issue..
Old 04-24-2009, 01:13 PM   #14
MGargano
Reinstalled the 1ZZ w/ chip swap this morning with gasket sealer and coolant bypass but didn't disconnect the battery so we'll see if anything changes later today.
Old 04-24-2009, 12:52 PM   #15
jkuchta
I never had the issue.
I think you have an air leak somewhere in the system. Best bet is to pull the TB, and reapply the sealer and let it sit overnight to set up.
Old 04-26-2009, 02:24 PM   #16
marcus
toyota
marcus's Avatar
well................anyone.
Old 04-26-2009, 07:16 PM   #17
MGargano
Good so far. Got oscillation on the first & second cold start but so far I'm 2 days oscillation free. I got a CEL today but took care of it with the Scangauge. I'm just glad the oscillation's gone.
Old 04-26-2009, 09:33 PM   #18
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Can't wait to get my TB in the mail
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
