Old 07-12-2009, 06:01 AM   #1
solarVitz
solarVitz's Avatar
Drives: 08 Yaris S Liftback
wow, these really works guys? ive got to try these on my car now. i wonder if my 08 liftback S got the cruise control lights in the instrument cluster? will soon find out.
Old 07-12-2009, 11:09 AM   #2
PatrickJohnson
Drives: 2008 Yaris LB
it doesn't, the 07 and 08 don't have it, only the 09
PatrickJohnson is offline   Reply With Quote
Old 07-13-2009, 04:39 PM   #3
Blue_dragon_192
Drives: 2009 Yaris 4dr Sedan
Can I assume that this will work for the 09 Sedan also?
What dangers/issues do I need to be worried about doing this mod?
I have wires running all over from the LED mods so I am not worried about the work, just warranty issues.
Blue
Blue_dragon_192 is offline   Reply With Quote
Old 07-13-2009, 05:27 PM   #4
PatrickJohnson
Blue
Just an FYI, the burden of proof is on the warranty provider to prove that any modification resulted in a failure of the component or part being warrantied. They can't deny a warrantly claim unless they can prove your modification caused whatever is broken.
Old 07-13-2009, 08:19 PM   #5
Blue_dragon_192
Well, my base model sedan is different
I guess I am screwed on this fantastic inexpensive mod.
Here are the pics I just took of my steering column.
As you can see, the brown and blue cables are missing.....so I think anyway.
Can someone confirm?
Circled the connector where I think the two additional cables should be:
Picture from the bottom of the steering column...
Blue
Old 09-24-2019, 01:06 PM   #6
giorgos01
Drives: toyota yaris 06 1.3
without lamp and work right?
giorgos01 is offline   Reply With Quote
Old 07-13-2009, 05:11 PM   #7
bronsin
bronsin's Avatar
As I understand it yes, the mod works for the 09 Sedan. Its just a matter of tapping into the two wires under the steering wheel and hooking them up to the four (or two if you prefer) switches with the resistors. With an 09 you dont need to be concerned with the ECM.
Old 07-13-2009, 09:43 PM   #8
And to answer the next question, here's the location of pin 40:
Old 07-13-2009, 09:56 PM   #9
Blue_dragon_192
OK.
looking at the engine bay and now understand the diagrams....
Since it's too dark out and my wife's scion is in the garage, I will attempt this at a different date.
Thank you all for your input...i hope this works.
Old 07-14-2009, 01:06 AM   #10
Revsson
Where's the engine bay??
just kidding
I have the factory cruise, but if I didn't, I'd probably try this mod.
CT Scott is one of the best with electronics in this forum!!!
Old 07-14-2009, 07:52 AM   #11
Blue_dragon_192
just kidding
Wait................These things have engines?
And here I thought they ran by magic.
Revsson, I am very fluent in sarcasm.......
From all the posts I read, CT Scott knows his stuff. I now have to get the courage to mess with the ECM and get the cruise working.
I am far more comfortable in a room full of servers, the car stuff is a little daunting, when dealing with an ECM!
Old 07-20-2009, 10:57 AM   #12
bronsin
bronsin's Avatar
I had the Yaris out this weekend for a trip to upstate NY and back. (about 250 miles each way) So the CC mod got a good workout. It worked very well indeed! The car got just about 40 mpg when I set the speed on 70 mph. I did the four switch version which gives you plus one and minus one mph at the touch of a button. It came in very handy and I recommend going the four switch route if you install this mod. Getting the Radio Shack really mini switches made doing the four switch really easy...
Old 07-20-2009, 06:43 PM   #13
TylerJ
Drives: Blazing Blue 2007 3dr HB 5MT
Unhappy Help with cruise control switches
I have been looking for a cruise control solution for a while, I am glad I found this thread
I have a 2007 Yaris 3dr Liftback with 5 spd MT, if I can't see the lit icons that you showed in the first few pictures does that mean I can't perform this DIY?
TylerJ is offline   Reply With Quote
Old 07-20-2009, 07:28 PM   #14
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
It just means no indicator lights - the actual cruise will work fine, if properly connected.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 07-21-2009, 08:15 AM   #15
You can do it on a USDM 07 for sure. You will need to run a wire from the switches directly to the ECM's pin 40 on an 07 or 08. Also, with a MT you will need to add the clutch switch and wire it to the connector in the under hood fuse panel. Check out the tail end of this thread for more details:
http://www.yarisworld.com/forums/showthread.php?t=16188
Old 07-25-2009, 02:16 PM   #16
TylerJ
I have two SPST N.O. momentary switches from radio shack and a pack of resistors I was just wondering what combination to use ... I have seen some people use 630 and others 660, I can do either with the supplies I have but was not sure about which is better CTScott mentioned I will have to hardwire the clutch switch into my under hood fuse box ... is this because we dont have the connector near the clutch pedal to just plug it in?
Old 07-25-2009, 03:07 PM   #17
216 to 264 ohms for one between resume and on/off
351 to 426 ohms for the one between set and resume
819 to 1001 ohms for the one between set and cancel
For the two switch method, the range for the resistor for the Set switch is from 567 Ohms to 690 Ohms. Any value in that range is fine. I would just stay at least 10 Ohms from either end point.
For the clutch switch, that is correct that the 07 and 08's don't have the clutch cruise switch connector, so you do have to hardwire to connector in the under hood fuse panel.
Old 07-25-2009, 04:02 PM   #18
TylerJ
is there one spot in the firewall where i can thread through the ECM wire from the switches and the two wires from the cluth cruise switch ? being that they are on opposite sides
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
