Old 10-11-2010, 12:23 AM   #127
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
for the high beam it's special because the light in the cluster does not come ON when i put the highbeam on!
and last question is there away to adjust the cut off ? because my friend told me my passenger side is lower then my driver side ...well he said that it'S less brighter...so my passenger side has no highbeam and is less brighter then my driver side
Interior:ALL red, black roof
Old 10-11-2010, 07:51 AM   #128
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
I can tell u on my that my highbeam will not turn on if my halo ring is not wire correctly hope this help
Old 10-11-2010, 12:39 PM   #129
packetrace
packetrace's Avatar
oh well this i probably what is wrong with my high beam thank you !
Old 10-11-2010, 12:49 PM   #130
were you careful to install the left side on the left and the right side on the right?
Old 10-11-2010, 12:57 PM   #131
packetrace
packetrace's Avatar
are parking light and DRL the same ? (the orange one)
Old 10-11-2010, 10:59 PM   #132
packetrace
packetrace's Avatar
DAMNNNN i didn't knew there was a side right and left...iknew for up and down...but not right and left :O I hipe it's ok :O maybe that's the problem:O where can we see the indication for right or left ? i feel like a noob...well that's what i am !! :P
Old 11-07-2010, 07:01 PM   #133
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
uuuffff cheveron yo le pinte los projectores de negro lol
Originally Posted by sw07gt
Old 11-29-2010, 02:25 AM   #134
crolandiz
Drives: Yaris Sedan '08
Hi, I bought proyectors on eBay, how can I know which one is the left/right side proyector? and How can I adjust the cutoff?
Thank you.
PS:Jumpman, tu auto esta de lo mejor, tambien pintare mis proyectores de negro, que pintura usaste? que le pusiste antes de pintarlos?
crolandiz is offline   Reply With Quote
Old 01-14-2011, 02:13 AM   #135
crolandiz
Condensation
Hi, I opened my headlights, paint and install the projectors. After 3 weeks, water or condensation appeared in the left headlight, remove the headlight for two days I let it dry and apparently went all the moisture so I went back to put silicone around.
Wash the car today morning and in evening note that the two headlights had moisture in and also the left angel eye is not starting.
What do you recommend or suggest? How can I solve this problem and prevent the more moisture?
Thank you.
Old 01-14-2011, 02:22 AM   #136
Thank you.
Make sure you push the lens into the housing all the way, and that the three screws all screw into place (one of my screws in each headlight won't screw into place, so I'm thinking that's what is causing my condensation problem). Also, the portion of the housing that engulfs the lens, make sure that's pinched down onto the lens.
Old 01-08-2012, 10:46 PM   #137
JumpmanYaris
USAF_SrA_E-4
I can't remember the size of the bulb for this projector, anyone
Old 01-08-2012, 11:08 PM   #138
D2H, I believe.
Old 01-08-2012, 11:49 PM   #139
JumpmanYaris
USAF_SrA_E-4
Wow so basically there is no replacement ?
Old 01-09-2012, 12:12 AM   #140
None in stores. I ordered mine here: http://www.theretrofitsource.com/pro...oducts_id=4126
Old 01-09-2012, 12:17 AM   #141
JumpmanYaris
USAF_SrA_E-4
Hahahaha yeah I see
Lol
Old 01-09-2012, 03:54 PM   #142
jamal1984
We sell them here in state of GA. It's called G3 bulb i believe.
The Beautification Of Car Enthusiast
Old 01-09-2012, 09:55 PM   #143
JumpmanYaris
USAF_SrA_E-4
G3 is the projector
Old 01-10-2012, 09:50 AM   #144
jamal1984
G3 is the projector
yes jumpmanyaris, it's also they the name of the HID Bulbs, i think ebay sell them for $20. Search G3 Bulb on ebay.
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-19-2020 11:35 PM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
DIY needed for amplifier for sedan install YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 2 02-27-2009 10:07 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-11-2007 11:02 PM
