Old 03-09-2007, 05:27 PM   #127
Kitt
Kitt's Avatar
Been there, done that: Add a capacitor and or replace the battery, get a bigger cable for the battery positive and problem solved, don't forget a good fuse...
Old 04-03-2007, 08:28 PM   #128
naossoan
Drives: 07 Yaris 3DR
What is the point of running so many ground wires?
naossoan is offline   Reply With Quote
Old 08-30-2007, 12:07 AM   #129
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
I bought a red kit cuz it matches my other upgrades. :) I'll be interested to see if it provides any noticeable difference in the car's performance.
OgDogg is offline   Reply With Quote
Old 08-30-2007, 02:09 AM   #130
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
OgDogg,
You may not notice improvements at all if you just randomly ground the wires.
IMO it's does wonders when you dyno test the ground wires so you can ground the wires at the best possible points.
Just a heads up because you maybe dissapointed when you don't feel/notice any improvements.
eijikikimaru is offline   Reply With Quote
Old 08-30-2007, 04:18 AM   #131
Edd
Drives: None
It makes your car go faster!
EDIT: In all seriousness though, if you draw more current, you will need less resistance in the wiring. Though this is somewhat debatable.
Edd is offline   Reply With Quote
Old 08-30-2007, 02:01 PM   #132
OgDogg
Gas Guzzler
OgDogg's Avatar
Originally Posted by eijikikimaru View Post
OgDogg,
I was just going to follow this DIY to install it. :) I'm more concerned with the looks and the constant shocks passengers get when getting out of my car. I'm hoping this grounding kit helps a little with that. Out here in the desert there is a ridiculous amount of static electricity, so we'll see if this helps at all. It could just be a pipe dream thinking this will have any effect.
Old 09-16-2007, 11:03 PM   #133
OgDogg
Gas Guzzler
OgDogg's Avatar
Well, I got an oil change today and decided to install my grounding kit when I got the car back. After taking my first ride here are my impressions. Might I also say that I was very skeptical that this would do anything for the performance.
It seemed like the rpms were much lower at cruising speeds than before which made it feel less like the car was struggling to maintain speed. It also felt much smoother shifting through the gears. No delay throwing it into the next gear. That was the most noticeable attribute. It could just be the oil change, but I doubt it. I recommend the grounding kit.
Old 09-17-2007, 05:21 PM   #134
KSIbucky
KSIbucky's Avatar
Some one told me that modern cars are grounded pretty well because I really want this but i dont want to waste my money
7 Color Tach
Fujita Intake
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
Old 09-17-2007, 05:48 PM   #135
BailOut
Steals terrorist's lunch
BailOut's Avatar
Originally Posted by KSIbucky View Post
i dont want to waste my mom
Translation?
- Brian
Share the Road
Old 09-17-2007, 05:48 PM   #136
KSIbucky
KSIbucky's Avatar
Translation?
sorry
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 09-17-2007, 08:57 PM   #137
OgDogg
Gas Guzzler
OgDogg's Avatar
Well, when upgrading a bottom end car such as the Yaris it's always going to be a waste of money. :) But if you want to slightly improve things and you enjoy working on your car, go for it!
Old 10-17-2009, 09:55 AM   #138
smartazawhipz
5-Speed love
Drives: red 08 liftback
I installed my kit today! Findings!
Ok, i've been into cars and electronics for years now, and I must say that after I installed the kit, I did notice a stronger "feel" to the acceleration than before. Also my transmission (manual), seems to again "feel" better, more accurate than before. I also have a radar detector that can measure my voltage, and I now run an average voltage of 14.3 volts, where as before, my car would run 13.9 volts. I believe because the negative electrons run more freely now throughout my vehicle, there is more of a balance between the stronger positive, and normally weaker negative power within the car to make all power using mechanics more efficient.
Moreover, a better electrical balance throughout the car. For $22.00 shipped, even it it's a facade, and my electrical readings incorrect, it just "feels" better.
Summary: GET IT, it's cheap, and I CAN see a difference with my volt meter!
smartazawhipz is offline   Reply With Quote
Old 04-14-2010, 06:35 PM   #139
captaincrunch
Chris
captaincrunch's Avatar
The grounding kit replaces your whole negative right?... So you have to have one of those wires on the starter?
captaincrunch is offline   Reply With Quote
Old 04-28-2010, 03:15 PM   #140
sternz
Drives: 08 Blazing Blue LB
Excellent DIY Thank you.
sternz is offline   Reply With Quote
Old 05-07-2010, 06:19 PM   #141
captaincrunch
Chris
diy guide said posted earlier said to keep the stock negative terminal how do you connect do did you connect the cable to the grounding kit?
Old 05-11-2010, 08:13 PM   #142
Richie836
Drives: 2010 3-Door Meteorite Metallic
For brand new car or broken in car?
I have a 2010 3-Door 4-speed auto with less then 500 miles.
I will order a groundwire kit this week.
Should I wait until after 1,000 miles (the break in period) or after the first oil change (5,000 miles) or should I install the ground wire kit as soon as possible?
I have the fuel saver magnet that covers your fuel line near the engine. That really works. I had it working with my late car (2004 Corolla S - 10 to 15 MPG extra city). So far, about the same increase MPG for my Yaris.
Richie836 is offline   Reply With Quote
Old 05-11-2010, 09:18 PM   #143
Palmer812
Drives: 2010 Meteorite Metallic LB
Another troll?
Palmer812 is offline   Reply With Quote
Old 05-19-2010, 04:58 PM   #144
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
This DIY helped a lot. Thanks!
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Bluetooth Kit Info so40 In Car Entertainment + Electronics (audio / video / alarm) 13 07-12-2009 05:13 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
