Old 01-02-2016, 06:08 PM   #127
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Today was a nice day so I was going to take her for a much needed bath to get the shop grime off, but alas the battery not being used much didn't want to give me a start so put her on the charger for the night and will do it tomorrow. While out in the garage tho I did snap a few more shots under the hood.
Sent from my XT1575 using Tapatalk
Old 01-03-2016, 12:17 AM   #128
LTHatch
Drives: 2013 Yaris Hatchback L
That's a very thick radiator, who makes that for the Yaris? The radiator mounts on the sedan are the same as the hatch?
LTHatch is offline   Reply With Quote
Old 01-03-2016, 12:57 AM   #129
fnkngrv
fnkngrv's Avatar
It is the 90-92 Honda Civic EX 3 core. Fellows from the UK clued me in on it. Bottom lines up fine. You just have to fab an L bracket top loop mount for it and then use a straight section of hose for the top return line to the rad. So far it has dropped my engine temps by roughly 25° under normal load alone.
Here is a link to pretty much what I now have:
http://ebay.com/itm/3-ROW-CORE-ALUMI...-/350589900140
Old 01-03-2016, 01:19 AM   #130
LTHatch
That's awesome, thank you.
Old 01-03-2016, 02:07 PM   #131
fnkngrv
fnkngrv's Avatar
Not a problem. AFAIK it will fit both the sedan and LB the same if not very similar since it is a half rad.
Old 01-07-2016, 07:03 PM   #132
fnkngrv
fnkngrv's Avatar
Have to take the car 60 miles to the local stealership for the 3 outstanding recalls (seat rails, spiral cable, and window controls) tomorrow so worked on the Cold start a little more.
Today was in the high 30s, but still she starts hard. Working with all the air flow that has been increased in cold weather makes for an interesting start.
Cold Start 20160107
Old 01-08-2016, 08:30 AM   #133
Focus_Sh1ft
Focus_Sh1ft's Avatar
Oh man, that cold start definitely needs some work.
I'd definitely recommend throwing a resonator on to further reduce the noise. It will really help to knock that "raspy" tone down quite a bit.
Old 01-08-2016, 08:41 AM   #134
What's the AFR?
Old 01-08-2016, 08:44 AM   #135
fnkngrv
fnkngrv's Avatar
Originally Posted by Bluevitz-rs View Post
What's the AFR?
Pig rich tbh. Sitting in the 10s and 11s. The colder ambient temps aren't helping any that is for sure. Doing some work on it over the weekend.
Sent from m-o-b-i-l-e
Old 01-08-2016, 03:04 PM   #136
LTHatch
Sounds a bit off but mean as all hell, when you go to the dealership tell us the expression on the techs faces after they see/hear you pull in lol.
Old 01-08-2016, 05:59 PM   #137
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I'd love to see the expression on their faces as well. I've still gotta get mine in for all those recalls too :/
Old 01-09-2016, 09:45 AM   #138
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
I just love this car
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-09-2016, 08:19 PM   #139
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
fnkngrv, mad props for this crazy setup! I absolutely love the way it sounds as it sits right now! Keep it up!
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 01-09-2016, 09:52 PM   #140
fnkngrv
fnkngrv's Avatar
Did some tune tweaking and made another cold start test today that was much more successful. It was 22° out also so that was a good sign. Also got a confirmation that the likelihood of the Dyno being available this month is very slim which is a serious bummer.
Old 01-10-2016, 01:08 PM   #141
LTHatch
My apologies if its been asked already, are you tuning vvti also? Do you believe theres a noticeable power increase tuning vvti for your turbo setup?
Old 01-10-2016, 01:24 PM   #142
fnkngrv
fnkngrv's Avatar
No worries. Yes we are also tuning vvti. As for differences there is a long story to being able to notice if there are differences or not concerning the Dyno work last year.
The short version is that due to an initial incorrect wiring install of the AEM boost controller and then plugged cat my tune and work done to it was seriously hampered. We wasted so much time working on those two items that granular manipulation for many settings were reduced by a great deal.
Even though last year's build/tune were an improvement and edged up performance/speed it just was a horrible cost/benefit situation. When it was said and done just the shop work/time at Granite State Dyno ran me close to $1500. That doesn't include the cost of the trip and GSD sits 400 miles from home. I had budgeted for half of that. With those expenses ballooning the way that they did further work was obviously hurt. We did do further analysis/tweaking during the speed runs with logger data, but just plain ran out of time for any performance improvement over the spring based tune. I only ran c12 race gas for safety as we didn't even get to really tune for it over 93 unleaded.
This time around I am working to have JRT Customs perform the tune at a much closer shop (200 miles) on the coast of Maine. The travel costs will be almost the same because we will be trailering the car and we will be around 10mpg with the truck/trailer. The Dyno cost and tuning cost will be where the big savings will be. I will have the Dyno for an entire day for a fraction of the cost.
Old 01-10-2016, 01:30 PM   #143
fnkngrv
fnkngrv's Avatar
On another note this new replacement AEM fuel pump seems to be getting louder very similar to the original one. I will be reaching out to them this week to discuss what is going on. An aftermarket fuel pump will be louder than stock, but even with how loud my injectors are you can hear the pump over them. Depending on what happens I may ditch the AEM and move to an Aeromotive unit instead. I have considered a Deatschwerks unit as well, but those are definitely loud from my research.
Before anyone asks after talking at length with Walboro engineers I prefer to not use one of their units for what my design is.
Old 01-10-2016, 02:42 PM   #144
LTHatch
Is your AEM pump causing fuel pressure issues?
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
