Old 03-28-2011, 06:07 AM   #1423
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Originally Posted by duke_afterdeath View Post
tol ganito ung harness na kinabit kay storm iba lang ang socket nito, wala syang fuse, yung nakikita nyong white casing sa wire na pula na ikakabit sa battery ay connector lang yun para madali syang i-disconnect sa battery if ever needed...Attachment 40741
ayos!
EjDaPogi is offline   Reply With Quote
Old 03-28-2011, 06:08 AM   #1424
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
wala bang bababa sa inyo jan d2 may ipakikidala ung pinsan ko jan papunta d2
MAGKIKITA KAMI NI aldrin ka tropa ni jherton dadalhin niya yung decals duke kung gusto mo punta ka dito la paza maya mga 130 to 2pm ...para kunbg ano maipapadala mo padala mo na..pera bayan?..
rosco is offline   Reply With Quote
Old 03-28-2011, 06:08 AM   #1425
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
copy tol, walang fuse in between the battery and relay sa kinabit kay storm, cguro pwede ding lagyan para mas safe...
Thanks tol, baka si idol jonimac ang makakapag-bigay linaw.wehehehehe!
rye7jen is offline   Reply With Quote
Old 03-28-2011, 06:09 AM   #1426
syntax
syntax's Avatar
@ duke kailangan pa kaya ng harness na yan kapag naka HID?
Old 03-28-2011, 06:10 AM   #1427
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol ndi ako ang magpapadala ung pinsan ko nasa dammam pala may ipapadala pababa d2 sa riyadh
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-28-2011, 06:12 AM   #1428
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
tol normal lang yan wag lang mag aamoy sunog ant medyo nadidiform na ung terminal or socket ng headlight... pero cguro tol wag mo na hintayin un
Originally Posted by syntax View Post
normal yan pre' nagtaka din ako dati kung bakit ganun ang itsura nun na parang luma na malangis, pero nakita ko rin un sa ibang kayaris ay ganun din pala ang itsura...
Salamat mga bro's! Paranoid mode ako ngaun ah.hahahahahaha!!!! Toinks~
Old 03-28-2011, 06:13 AM   #1429
duke_afterdeath
nasan nga ba si idol para magbigay liwanag, haha.. idol labas jan
tol di na kailangan nyan sa HID kc may sariling harness na siya at may ballast na na nag hahandle ng power or load (ako malapit na maubos powers ko)
Old 03-28-2011, 06:13 AM   #1430
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@ramil, according sa harness na pinost mo e plug'n'play nga siya at hindi na kailangan ng inline fuse. THanks!
Old 03-28-2011, 06:14 AM   #1431
duke_afterdeath
Old 03-28-2011, 06:14 AM   #1432
stinger
You got me sTiLt
stinger's Avatar
Drives: 2011 Yaris Y sedan
Duke, what i mean is yung relay to battery.. nag-search na kasi ako about sa relay installation at naglalagay sila ng inline fuse between the relay going directly to the battery, yan kasi yung isang rason kaya natagalan ako bago ko na-install yung nabili kong busina. Worried lang ako kung ano magiging dis-advantage nito in the long run.. Pero nung nakita ko yung relay na kinabit kay pareng brosco eh wala rin silang nilagay na inline fuse..
Eto yung gusto ko tukuyin:
Attachment 40739
Paki-correct na lang po or baka may namiss lang ako.
Pre... yung fuse is for protection base on the diagram. Mas ok kung lalagyan mo kung hindi ka gagamit ng harness na ready made.
Kung yung harness na nasa post nila gagamitin mo ok lang na wala ng fuse kasi ginamit naman na yung dating socket ng headlight which is may fuse na.
Hope this will help.
stinger is offline   Reply With Quote
Old 03-28-2011, 06:15 AM   #1433
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
+1
Wahahahaha!!
Old 03-28-2011, 06:16 AM   #1434
duke_afterdeath
ako naman ang nagiisip ngaun if need pa bang lagyan ng inline fuse between battery and relay para mas safe
Old 03-28-2011, 06:17 AM   #1435
rosco
rosco's Avatar
tol kausapin mo si jherton..taga dammam yun ..kasi yung tropa nya manhik manaog ng riyadh -dammam
Old 03-28-2011, 06:18 AM   #1436
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Thanks tol stinger, mukhang hindi na nga kailangan ng inline fuse base dun sa harness ni tol ramil. Ok na rin yung malinaw para iwas confuse sa ating mga fellow kayaris.
Old 03-28-2011, 06:18 AM   #1437
duke_afterdeath
+ 1 ito nga ung unang explain ko kanina kay tol rye
Old 03-28-2011, 06:20 AM   #1438
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
"*ding dong**
(Paging joni idol)
Old 03-28-2011, 06:20 AM   #1439
duke_afterdeath
+1
Old 03-28-2011, 06:22 AM   #1440
EjDaPogi
EjDaPogi's Avatar
+1
fuse + fuse + fuse + too much fuse = CONFUSE!
