Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Australia
Old 09-14-2009, 07:13 PM   #145
lunjiaow
lunjiaow's Avatar
Looks clean, what size are those rims and tyres? Would be nicer if the car was lowered some more.
lunjiaow is offline   Reply With Quote
Old 09-15-2009, 06:04 PM   #146
AND189
Drives: 2
they are 15"195/50 i have the trd struts and springs it is good fun to drive as i said looking for the performance mods thanks mate i thought if i put bigger wheels it may corner faster ??? i dont know
AND189 is offline   Reply With Quote
Old 09-15-2009, 06:56 PM   #147
lunjiaow
lunjiaow's Avatar
You would need wider wheels for more traction so you can turn corners faster. Also good tyres will help too. I havent done any performance mods on my car as i have the 2NZ so i dont think its worth doing up. Just doing suspension mods so i can chuck the car around.
Old 09-16-2009, 11:08 AM   #148
ruimond
Drives: Yaris YR
Got the lights in the courier today finally.
Kinda suprised the taillights ended up a lighter grey colour. Not as dark as was shown on by the seller.
Old 09-16-2009, 11:16 AM   #149
katsudon
katsudon's Avatar
Drives: Yaris HB
Send a message via MSN to katsudon
well hello.... hahahah
katsudon is offline   Reply With Quote
Old 09-16-2009, 06:06 PM   #150
1NZYaris1
1NZYaris1's Avatar
Dude , they are no good sitting on the box , they
should have been on the car already
but they do look nice
Old 09-16-2009, 07:09 PM   #151
lunjiaow
lunjiaow's Avatar
Yeah the taillights look lighter then the ebay pics. Hopefully its straight plug and play.
Old 09-16-2009, 08:03 PM   #152
1NZYaris1
1NZYaris1's Avatar
Just a quick heads up for those running , or want to run LED
indicators , instead of using Load resistors you can now buy this
just remove the old relay and plug the new one in .
Old 09-16-2009, 09:20 PM   #153
ruimond
Drives: Yaris YR
How does that change the indicator to LED? Wouldn't it be LED bulbs already in it? lol.
Old 09-16-2009, 09:44 PM   #154
ruimond
Drives: Yaris YR
Looks like its not just plug in and turn on. I was looking at the DIY and the connectors are more horizontally shaped. Not sure how they are on the Australian ones.
The shape of the one on the tails is kinda more square.
Might need to get new connectors hey vince. lol.
Old 09-17-2009, 06:59 AM   #155
lunjiaow
lunjiaow's Avatar
Its supposed to slow down the flash rate of your indicators once you replace LEDs globes with bulbs.
Thats no good, more modification with wiring harness. how fun. Would be swell if it was just plug and play. Will probably have to go to toyota to get the right plugs if they dont fit correctly.
Anyway i just found the plug for yaris tail light. Is the aftermarket tail light plug like that?
Old 09-17-2009, 07:49 AM   #156
ruimond
Drives: Yaris YR
I can't remember exactly actually. lol. Might have a look later. I kinda already repacked it. Haha.
Old 09-18-2009, 04:29 AM   #157
AND189
Drives: 2
lunjiaow
ok well i find that when i went to the wider tyres from stock , in the wet i had to slow down a lot or the car just slides of the road... so i should go to 15"/7" from what i have now 15"5.5" ?? i also have the 2nz and doing the same i have the TRD shocks & springs strut brace and sway bar & short shift what eals can i do
Old 09-18-2009, 11:47 AM   #158
lunjiaow
lunjiaow's Avatar
You are probably going too fast on that corner, or you are running low cost tyres. I would go 15x7 if possible but most rims you see are around 6 or 6.5. I have 17x7s and 16x7s. Seem to grip quite well. I dont speed around corners in the wet =P
Sounds like a great suspension combination you are getting. Im sure that's enough to have lots of fun.
You could get a Cold Air Intake and even an exhaust system to make the car sound nice.
Old 09-18-2009, 05:01 PM   #159
1NZYaris1
1NZYaris1's Avatar
Originally Posted by AND189 View Post
lunjiaow
You dont say what tyres your running , but i have the same setup almost .
My alloy's are 15x6.5x44et with 12mm rear spacers , with 185x55x15 tyres
great in most conditions except snow ,lol, tyre compund and pressure could
be your problem as well as fitment on the 5.5 rims deforming sidewall too much .
Old 09-19-2009, 04:18 AM   #160
ruimond
Drives: Yaris YR
Some photos i took after install today. Took like 2hours or so. Thanks to my friend for the assistance and help. Did most of it myself with his instructions, was kinda scared to. lol
Left headlight clip needed some heatgun action, as it didn't fit as well as the right side. But all good now.
Old 09-19-2009, 04:46 AM   #161
elijahsami
Drives: yaris hatch & sedan
Thats one hot yaris you got there mate.......
elijahsami is offline   Reply With Quote
Old 09-19-2009, 04:49 AM   #162
ruimond
Drives: Yaris YR
Thanks alot.
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
New Yaris Owner Kiteless General Yaris / Vitz Discussion 8 08-02-2006 11:48 PM
